Home » Eclipse Projects » Linux Tools Project » importing files as links
importing files as links [message #655222] Fri, 18 February 2011 11:47 Go to next message
No real name is currently offline No real name
Member
I have a header file (DataLogger.h) and and implementation file
(DataLogger.cpp) in one project, call it Project1.
From another project, Project2, I used the import wizard to get the
equivalent of a soft link to the DataLogger files.
The result was an entry in the .project file(Project2):
<linkedResources>
<link>
<name>src/DataLogger.cpp</name>
<type>1</type>
<location>/home/rgeddes/Project1/DataLogger.cpp</location>
</link>
<link>
<name>src/DataLogger.h</name>
<type>1</type>
<location>/home/rgeddes/books/Project1/DataLogger.h</location >
</link>
</linkedResources>
I could also see additional resources in Project2 (Project Explorer
View) that looked like project source/header files but with decorations
that looked like arrows (I assume representing links)
I was expecting the preprocessor to see these links as well, but it
balks at:
#include "DataLogger.h" //No such file
I can get through compilation if the path to DataLogger.h is specified:
#include "../Project1/DataLogger.h" //OK
Is there a way to get the preprocessor #include to work with the project
link.
Making sym links through the os works ok.
Richard
Re: importing files as links [message #655873 is a reply to message #655222] Tue, 22 February 2011 18:56 Go to previous message
Jeff Johnston is currently offline Jeff Johnston
The key thing here to note is that you are creating links via Eclipse and compiling with gcc.
gcc knows nothing about Eclipse so doesn't know about .project files or Eclipse locations. It accesses the file system so as you already know, sym links via the OS work.
What you can do is add your Project1 to the include path for the compilation. You can do this a number of ways depending on what kind of C Project you have.
Previous Topic:Cannot rebuild opxml, undefined reference to dlopen
Next Topic:Error loading control flow pane
Current Time: Wed May 22 13:34:16 EDT 2013
Powered by FUDForum. Page generated in 0.05481 seconds
