| Tests using Virgo Test Framework [message #646309] |
Thu, 23 December 2010 04:45  |
Lorie Pisicchio Messages: 44 Registered: October 2010 |
Member |
Dear Virgo team,
I am trying to implement integration tests over the Virgo test framework.
Is start a very basic unit test :
import org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner;
import org.junit.Assert;
import org.junit.Test;
import org.junit.runner.RunWith;
@RunWith(DmKernelTestRunner.class)
public class IntegrationTest {
@Test
public void RunFirstTest() {
Assert.assertTrue(true);
As simple as it is, I am not able to run this test. When starting, I get the following error :
java.lang.NoClassDefFoundError: org/osgi/framework/launch/Framework
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
at java.lang.Class.privateGetPublicMethods(Class.java:2547)
at java.lang.Class.getMethods(Class.java:1410)
at sun.misc.ProxyGenerator.generateClassFile(ProxyGenerator.java:409)
at sun.misc.ProxyGenerator.generateProxyClass(ProxyGenerator.java:306)
at java.lang.reflect.Proxy.getProxyClass(Proxy.java:501)
at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:581)
at org.eclipse.virgo.test.framework.plugin.PluginManager.<init>(PluginManager.java:28)
at org.eclipse.virgo.test.framework.OsgiTestRunner.<init>(OsgiTestRunner.java:42)
at org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner.<init>(DmKernelTestRunner.java:41)
at org.eclipse.virgo.test.framework.dmkernel.DmKernelTestRunner.<init>(DmKernelTestRunner.java:37)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.junit.internal.builders.AnnotatedBuilder.buildRunner(AnnotatedBuilder.java:31)
at org.junit.internal.builders.AnnotatedBuilder.runnerForClass(AnnotatedBuilder.java:24)
at org.junit.runners.model.RunnerBuilder.safeRunnerForClass(RunnerBuilder.java:57)
at org.junit.internal.builders.AllDefaultPossibilitiesBuilder.runnerForClass(AllDefaultPossibilitiesBuilder.java:29)
at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:24)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init>(JUnit4TestReference.java:32)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassReference.<init>(JUnit4TestClassReference.java:25)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.createTest(JUnit4TestLoader.java:41)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests(JUnit4TestLoader.java:31)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: org.osgi.framework.launch.Framework
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 30 more
I tried to look around for the bundle exporting the class org.osgi.framework.launch.Framework, but didn't found it. Maybe this is where the error come from...
Any help would be appreciated.
Regards.
FUDForum. Page generated in 0.07272 seconds
