hi all
i have a query like this:
public List<Pais> findAllPais(){
return find("select p from Pais p");
but when she's executed, it throws a error like this:
[EL Severe]: 2011-02-15 10:32:32.421--ServerSession(2572110)--Thread(Thread[main,6,main])--Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.2.v20101206-r8635): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:postgresql://192.168.0.10:5432/ti_fiscal
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:309)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:138)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:94)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connectInternal(DatasourceAccessor.java:327)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.connectInternal(DatabaseAccessor.java:291)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connect(DatasourceAccessor.java:415)
at org.eclipse.persistence.sessions.server.ConnectionPool.buildConnection(ConnectionPool.java:155)
at org.eclipse.persistence.sessions.server.ExternalConnectionPool.startUp(ExternalConnectionPool.java:118)
at org.eclipse.persistence.sessions.server.ServerSession.connect(ServerSession.java:495)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:627)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:230)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:389)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:164)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:221)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:209)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.invokeProxyMethod(AbstractEntityManagerFactoryBean.java:423)
at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean$ManagedEntityManagerFactoryInvocationHandler.invoke(AbstractEntityManagerFactoryBean.java:485)
at $Proxy8.createEntityManager(Unknown Source)
at org.springframework.orm.jpa.EntityManagerFactoryAccessor.createEntityManager(EntityManagerFactoryAccessor.java:116)
at org.springframework.orm.jpa.JpaTemplate.execute(JpaTemplate.java:176)
at org.springframework.orm.jpa.JpaTemplate.execute(JpaTemplate.java:146)
at org.springframework.orm.jpa.JpaTemplate.find(JpaTemplate.java:306)
at org.springframework.orm.jpa.JpaTemplate.find(JpaTemplate.java:302)
at br.com.germantech.repo.JPADao.findAllPais(JPADao.java:16)
at br.com.germantech.repo.JPADao$$FastClassByCGLIB$$dcf8016c.invoke(<generated>)
at net.sf.cglib.proxy.MethodProxy.invoke(MethodProxy.java:191)
at org.springframework.aop.framework.Cglib2AopProxy$DynamicAdvisedInterceptor.intercept(Cglib2AopProxy.java:617)
at br.com.germantech.repo.JPADao$$EnhancerByCGLIB$$9ccc57c9.findAllPais(<generated>)
at br.com.germantech.commands.AbrirEditorTeste.execute(AbrirEditorTeste.java:21)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at br.com.germantech.application.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
and yes, i DO HAVE postgres driver added as a dependecie from my bundle
here's all the stack trace:
http://pastie.org/1566055
as you can see here: [EL Config]: 2011-02-15 10:32:32.421--ServerSession(2572110)--Connection(1349553)--Thread(Thread[main,6,main])--connecting(DatabaseLogin(
platform=>PostgreSQLPlatform
user name=> "postgres"
connector=>JNDIConnector datasource name=>null
eclipselink tries to instantiate a datasource, which i don't use, i never used at all
my config files:
appContext.xml
http://pastie.org/1566048
persistence.xml
<persistence xmlns="http://java.sun.com/xml/ns/persistence"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="
http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd" version="2.0">
<persistence-unit name="Fiscal" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>br.com.germantech.modelos.GrupoAcesso</class>
<class>br.com.germantech.modelos.GrupoUsuario</class>
<class>br.com.germantech.modelos.Usuario</class>
<class>br.com.germantech.modelos.Estado</class>
<class>br.com.germantech.modelos.GrupoTelefone</class>
<class>br.com.germantech.modelos.Municipio</class>
<class>br.com.germantech.modelos.Pais</class>
<class>br.com.germantech.modelos.Telefone</class>
<class>br.com.germantech.modelos.TipoLogradouro</class>
<class>br.com.germantech.modelos.ClienteFornecedor</class>
<class>br.com.germantech.modelos.Contabilista</class>
<class>br.com.germantech.modelos.Departamento</class>
<class>br.com.germantech.modelos.Empresa</class>
<class>br.com.germantech.modelos.EmpresasEndereco</class>
<class>br.com.germantech.modelos.EmpresasResponsavel</class>
<class>br.com.germantech.modelos.EmpresasSocio</class>
<class>br.com.germantech.modelos.Escritorio</class>
<class>br.com.germantech.modelos.GrupoResponsavel</class>
<class>br.com.germantech.modelos.InscricaoSubstituicao</class>
<class>br.com.germantech.modelos.Nacionalidade</class>
<class>br.com.germantech.modelos.NaturezaJuridica</class>
<class>br.com.germantech.modelos.Responsavel</class>
<class>br.com.germantech.modelos.Sindicato</class>
<class>br.com.germantech.modelos.SituacaoEspecial</class>
<class>br.com.germantech.modelos.TipoSocio</class>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.target-database" value="PostgreSQL" />
<property name="javax.persistence.jdbc.driver" value="org.postgresql.Driver" />
<property name="javax.persistence.jdbc.url" value="jdbc:postgresql://192.168.0.10:5432/ti_fiscal" />
<property name="javax.persistence.jdbc.user" value="postgres" />
<property name="javax.persistence.jdbc.password" value="admin" />
</properties>
</persistence-unit>
</persistence>
if i hardcode the entityManager, eclipselink doesn't use connector:
[EL Config]: 2011-02-15 10:50:49.656--Connection(20348456)--connecting(DatabaseLogin(
datasource URL=> "jdbc:postgresql://192.168.0.10:5432/ti_fiscal"
[EL Config]: 2011-02-15 10:50:49.687--Connection(4167406)--Connected: jdbc:postgresql://192.168.0.10:5432/ti_fiscal
User: postgres
Database: PostgreSQL Version: 8.4.3
Driver: PostgreSQL Native Driver Version: PostgreSQL 8.3 JDBC4 with SSL (build 604)
[EL Config]: 2011-02-15 10:50:49.687--Connection(13506221)--connecting(DatabaseLogin(
what am i missing?
thanks
