Home » Modeling » Modeling (top-level project) » CDO Repository Server Reconnect Failure(When connecting to a CDO Repository that is down it fails even if you start it out)
CDO Repository Server Reconnect Failure [message #654310] Mon, 14 February 2011 23:33 Go to next message
Nuno Santos is currently offline Nuno Santos
If found a possible bug when testing an app.
I Started the app and try to connect to a repository server that was down. It fails the connection with the timeout exception, but after i started the server and try to reconnect it still fails!
After a while i found the reason: it kept the connector in the repository plugin instance elements. It was necessary to manualy remove it from the instance elements to have it to work.
Something like this:
try{
   connector=TCPUtil.getConnector(IPluginContainer.INSTANCE, host+":"+port);
   configuration =  CDONet4jUtil.createSessionConfiguration();
   configuration.setRepositoryName(id);
   configuration.setConnector(connector);
   return configuration.openSession();
}catch(Throwable t){
      PluginContainer.INSTANCE.removeElement(TCPConnectorFactory.PRODUCT_GROUP, TCPConnectorFactory.TYPE, host+":"+port);
     throw t;
[Updated on: Mon, 14 February 2011 23:34]
Report message to a moderator
Re: CDO Repository Server Reconnect Failure [message #654311 is a reply to message #654310] Mon, 14 February 2011 23:44 Go to previous message
Eike Stepper is currently offline Eike Stepper
Hi Nuno,
Please ask CDO questions in the EMF newsgroup, which I've cc'ed.
I think this issue is fixed in 4.0, where inactive elements are removed from a container by default. Can you try that?
Cheers
/Eike
http://www.esc-net.de
Am 15.02.2011 05:33, schrieb Nuno Santos:
> I Started the app and try to connect to a repository server that was down. It fails the connection with the timeout exception, but after i started the server and try to reconnect it still fails! After a while i found the reason: it kept the connector in the repository plugin instance elements. It was necessary to manualy remove it from the instance elements to have it to work.
> [code]
> try{
> PluginContainer.INSTANCE.removeElement(TCPConnectorFactory.P RODUCT_GROUP, TCPConnectorFactory.TYPE, host+":"+port);
> throw t;
Previous Topic:what is the difference between EMF, UML ,Protege and MetaEdit+
Next Topic:[EMF] "@generated NOT" does not work
Current Time: Sun May 26 03:03:22 EDT 2013
Powered by FUDForum. Page generated in 0.01520 seconds
