Home » Eclipse Projects » Eclipse 4 » e4 RCP application: (1) error log view (2) about dialog (3) app hooks
e4 RCP application: (1) error log view (2) about dialog (3) app hooks [message #653996] Sat, 12 February 2011 12:44 Go to next message
Karl Weber is currently offline Karl Weber
Member
(1) With 3.x one can use the error log view to display error messages in RCP applications. How can one display these messages in an e4 RCP application?
(2) With 3.x one can add an about dialog to an RCP application. How can one do this with e4 RCP applications?
(3) With 3.x, one can hook into the startup process of an RCP application, e.g. in the preStartup method of the ApplicationWorkbenchAdvisor. In one RCP application I am using this hook to display a dialog for the user to select a database connection. How could one do this in an e4 RCP application?
Re: e4 RCP application: (1) error log view (2) about dialog (3) app hooks [message #654158 is a reply to message #653996] Mon, 14 February 2011 07:46 Go to previous message
Paul Webster is currently offline Paul Webster
> application?
These are only supported in the compatibility layer at the moment. In
effect running a 3.x RCP app, with the down side it is hard to access
the e4 functionality.
The error log might be hostable from within an e4 app, but it would
require wiring up things yourself.
You can provide a Lifecycle Manager to your app. We currently support 4
lifecycle points in package org.eclipse.e4.ui.workbench.lifecycle:
PostContextCreate
PreSave
ProcessAdditions
ProcessRemovals
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:org.eclipse.e4.core.di.InjectionException: Could not find satisfiable constructor
Next Topic:Updating to 4.1 messed things up
Current Time: Sun May 19 12:33:57 EDT 2013
Powered by FUDForum. Page generated in 0.02519 seconds
