Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » How to generate JAR file which runs on mobile phone?
How to generate JAR file which runs on mobile phone? [message #654052] Sun, 13 February 2011 13:03
HuaZhang  is currently offline HuaZhang
Hi, I developed an java application using MTJ and eclipse and sun_java_wireless_toolkit-2.5.2_01-win.exe. The application run on the emulator correctly. When I generated the JAR file and downloaded JAR to mobile phone, the JAR couldn't run. I was told that the bootclasspath which is used by compiler javac should be set "d:\midp-fcs\classes" in order to change the default JAVA SE class to JAVA ME class. Is there anybody to tell me how to set the bootclasspath in eclipse IDE? Thanks.
Previous Topic:Project properties Java ME->Library: how to add libraries?
Next Topic:How to generate JAR file to run on mobile phone?
Current Time: Wed May 29 02:47:58 EDT 2013
Powered by FUDForum. Page generated in 0.02105 seconds
