| Crosstab inside of a table [message #653465] |
Wed, 09 February 2011 15:41  |
Originally posted by: remkus.wideopenwest.com
My application constrains me to using BIRT 2.2.1.
I'd like to have a table of data with groups defined.
In the detail row, I'd like to have a crosstab which is filtered on data
from the table.
I've tried setting a filter on the crosstab .. no luck.
<property name="level">PerformanceView/DEVICE_NAME</property>
<property name="filter">
<filter-condition-element>
<expression
name="expr">dimension["PerformanceView"]["DEVICE_NAME"] </expression>
<property name="operator">eq</property>
<simple-property-list name="value1">
<value>data._outer["DEVICE_NAME"]</value>
</simple-property-list>
</filter-condition-element>
</property>
When I run the report, I get a message
"org.mozilla.javascript.EcmaError: TypeError: Cannot read property
"DEVICE_NAME" from null"
Any suggestions?
| Re: Crosstab inside of a table [message #653729 is a reply to message #653711] |
Thu, 10 February 2011 15:38   |
Jason,
I had been thinking along the lines of setting a variable in the row's
onCreate, but it didn't dawn on me that I could just access the variable
from the reportContext when building the filter expression!
It works ... I'm not sure if you just made a typo or if there's a
concept I don't understand between get/setGlobalVarable and
get/setPersistentGlobalVariable, but I had to use persistent variables
to make my report work
Thanks a ton!
On 02/10/11 13:43, Jason Weathersby wrote:
> Dave,
> Not sure this will work but can you add an oncreate script to the row
> containing the xtab. In that script get the column value device name
> and use reportContext.setGlobalVariable("dn", yourvalue);
> Then in the filter put
> reportConxtext.getGlobalVariable("dn");
> instead of
> Jason
>> from the table.
>> <expression
>> </property>
>> Any suggestions?
>> Thanks
| Re: Crosstab inside of a table [message #653732 is a reply to message #653729] |
Thu, 10 February 2011 15:57   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Dave,
It was not a typo. Persistent variables are written to the rptdocument
allowing the separation of run and render task in two java processes.
It should be fine to use persistent. I am a bit curious why the
standard global did not work.
Jason
On 2/10/2011 3:38 PM, Dave Remkus wrote:
> Jason,
> Thanks a ton!
>> Dave,
>> instead of
>> Jason
>>> from the table.
>>> <expression
>>> </property>
>>> Any suggestions?
>>> Thanks
Jason Weathersby
BIRT Exchange
| Re: Crosstab inside of a table [message #653922 is a reply to message #653732] |
Fri, 11 February 2011 16:20  |
Jason,
I must have typo'd something when I was trying set/getGlobalVariable ...
now that I have the report working with persistent variables, I went
back and tried standard globals and they work fine! (:doooh!)
On 02/10/11 15:57, Jason Weathersby wrote:
> Dave,
> allowing the separation of run and render task in two java processes. It
> should be fine to use persistent. I am a bit curious why the standard
> Jason
>> Jason,
>> Thanks a ton!
>>> Dave,
>>> instead of
>>> Jason
>>>> data
>>>> from the table.
>>>> <expression
>>>> </property>
>>>> Any suggestions?
>>>> Thanks
FUDForum. Page generated in 0.02362 seconds
