Home » Modeling » AMP » Model Parametrization
Model Parametrization [message #653643] Thu, 10 February 2011 09:18 Go to next message
Lukas Schmid is currently offline Lukas Schmid
hello,
we have just been wondering how we can define Attributes in the model parametrization file which belong to an agent (and not to the global model).
http://wiki.globalsimulate.org//images/ParameterfileBug.png
Thanks for any reply!
Re: Model Parametrization [message #653685 is a reply to message #653643] Thu, 10 February 2011 12:29 Go to previous messageGo to next message
Miles Parker is currently offline Miles Parker
It probably doesn't make sense to assign parameters to agents at the parameter file level -- that's because there is a one-to-one relationship with the parameter file and the top-level model. What you should do is something like:
1. Create an attribute at the top model context called "Bug Size" or perhaps "Default Bug Size" if you want bugs to be different sizes.
2. In an initialization rule for the bug assign that default value to the bug's size attribute
For an impossibly technical and meandering discussion of some of the deeper issues of assigning initial state for nested parameters, you might be interested in this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318274
Re: Model Parametrization [message #653774 is a reply to message #653685] Fri, 11 February 2011 01:18 Go to previous messageGo to next message
Hi Miles,
thanks for your reply - we will do it this way!
Lukas
Re: Model Parametrization [message #653902 is a reply to message #653774] Fri, 11 February 2011 13:34 Go to previous message
lukschmi wrote on Fri, 11 February 2011 01:18
Hi thanks for your reply - we will do it this way!
No problem! After I replied to you, I remembered a thought I had for what might actually be a cool/useful feature -- and perhaps be simpler than the other solutions discussed in the above referenced bug. We could consider supporting some kind of XPath like assignment of variables. This would be directly supported by EMF, so wouldn't be incredibly difficult to implement. Then you could do something like:
Bug[*].size=0
Previous Topic:How to start gef3d sample application
Next Topic:Call for feature requests
Current Time: Thu May 23 14:11:44 EDT 2013
Powered by FUDForum. Page generated in 0.01635 seconds
