Home » Eclipse Projects » scout » Unable to start client, Scout version 3.7.0.201102030625
Unable to start client, Scout version 3.7.0.201102030625 [message #653453] Wed, 09 February 2011 14:58 Go to next message
Daniel Egger is currently offline Daniel Egger
Hello all
I downloaded the Eclipse Classic 3.7.0 M5 and in it I installed the
Scout Runtime (Incubation) version 3.7.0.201102030625
and
Scout SDK (Incubation) version 3.7.0.201102030625
Without any modifications I was able to start the Test-server-dev.product (or so it seems)
But when I want to start the Client through the Test-swing-client.dev.product I can successfully authenticate but then a whole bunch of Warnings of the form:
warnImageNotFound(null:-1) could not find image 'bla...'
appear.
And the then I got a number of NullPointerExceptions, all with the same stacktrace:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at org.eclipse.scout.rt.ui.swing.window.desktop.toolbar.Navigat ionWidgetButton.paintPressedImage(Unknown Source)
at org.eclipse.scout.rt.ui.swing.window.desktop.toolbar.Navigat ionWidgetButton.paintButton(Unknown Source)
at org.eclipse.scout.rt.ui.swing.window.desktop.toolbar.Navigat ionWidgetButton.paintComponent(Unknown Source)
at org.eclipse.scout.rt.ui.swing.window.desktop.toolbar.JNaviga tionWidget.paintButtons(Unknown Source)
at org.eclipse.scout.rt.ui.swing.window.desktop.toolbar.JNaviga tionWidget.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JLayeredPane.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered( Unknown Source)
at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
at java.awt.Container.paint(Unknown Source)
at java.awt.Window.paint(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.seqPaintDirtyRegions(Unknown Source)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.r un(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Did I miss something in the downloads?
Thanks in advance.
Re: Unable to start client, Scout version 3.7.0.201102030625 [message #653613 is a reply to message #653453] Thu, 10 February 2011 06:23 Go to previous messageGo to next message
Andreas Hoegger is currently offline Andreas Hoegger
--------------000006060005070507060401
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Daniel
The behavior you described is due to the pack200 configuration we are
using for the automated build (required for eclipse projects). Pack200
scrambled the class to useless.
I changed the configuration for any future build. Since the 3.7M5 is
already released I can not provide you any fix for that release. Any
future release will be fine.
To get you able working on with Scout I suggest to switch to the nightly
update repository which has already been built with a proper pack200
config.
Go to the 'Help - Install New Software...' menu. Add a new update
location named 'Scout nightly' with the url
'http://download.eclipse.org/scout/nightly/update'.
-Andreas
On 09.02.2011 20:59, Daniel Egger wrote:
> Hello all
> and
> appear.
> stacktrace:
> Source)
> un(Unknown Source)
> Thanks in advance.
Content-Type: image/png;
name="scoutNightlyRepositoryConf.png"
Content-Disposition: attachment;
filename="scoutNightlyRepositoryConf.png"
iVBORw0KGgoAAAANSUhEUgAAAmYAAAKFCAIAAADpnrLxAAAACXBIWXMAAA7E AAAOxAGVKw4b
AAAAB3RJTUUH2wIKCxcQtTGOWwAAAAd0RVh0QXV0aG9yAKmuzEgAAAAMdEVY dERlc2NyaXB0
aW9uABMJISMAAAAKdEVYdENvcHlyaWdodACsD8w6AAAADnRFWHRDcmVhdGlv biB0aW1lADX3
DwkAAAAJdEVYdFNvZnR3YXJlAF1w/zoAAAALdEVYdERpc2NsYWltZXIAt8C0 jwAAAAh0RVh0
V2FybmluZwDAG+aHAAAAB3RFWHRTb3VyY2UA9f+D6wAAAAh0RVh0Q29tbWVu dAD2zJa/AAAA
BnRFWHRUaXRsZQCo7tInAAABAElEQVR4nOzdebxkVXk3+t+z1q7hzENPQEM3 MzRgA4KBoCJR
Iw44gCZqDJ8MnxujRo1Xo+hrTNDE14CJV5E33pjEJK/vTTAGFEFRNIomoIKA goDQ0N0IPY9n
rD2t57l/rKp96tR06pxTZ+p+vp9Ds2vXHlbVqbN/tdZee20SEVR5zTsfGhou mGKuemY+MABM
QABMgBlxOvMySiml1KLhVJo9JamrfpiAAHCYHDoYfe3GzdVPURaZr/id+9Zu 7D92rQ368rl8
UAAA2LwBUARMjgAEBADG0Awl46YlU0oppRZZdVxyIj7ROGkQVSHgYgYQpxSO hDv2xnufHr3j
X57nny1H5pX/USONWwAAAQBJREFU1/1rTh5cvdoEPTlrTC5ncyQUGABdJHlL ZAlthKVSSnWQ
fv9W7TCGmn1UxAmafJAaVjt9jvrgjFOKJ+KJA6Xt2ya+8g8XwEfmK37nvhPO GB7uF9sdkDWG
CJas8Y2xxhJl8dkmSbn9hZVSSqmF42uNzcTptKqgJFONtClYUiQT8cTeiSe3 ht/80kUBgFVD
uR5JgIBDBtgBFJALCIANbGIpBKwxpi41uT4ahXykKzUjgX5UlFILRYQBCAsY 4lA+3vhzkZIt
U54SCBzKy7vp0ZZwzpjVwzkA9Ja33T84aHuGupATAJSzfhkyhgKigMiWq5uN C1UdkGyEtX6p
2qWRqWbmZhfkRAAAAAEASURBVF5EqexgQqCpOQIBl4NQhJiERQwTGx+KDQ5A DuUUc5BKWy4l
SJPYlZL9B8IAQMEYSYRAyIkkLkvNapyyb7CtbFcAsM/nqc+0g9PjoGqbflLU TAT6LXxF6ina
VX25IIuM7I+9EmV+lgjgk4khkL2jackxqLzWmsH8GSd0F/OVCtv06zumbUSQ 5eZDT47vH3Wg
cpPnmlW5Mzb2FAuz28iDPx/ZtyPyLamOXXbas3zJSALJo0HXHkkFYF/RBKbq lNVhOa0ltlzl
1U+5aoNWIJQ6EnUVTG8+2L7LJSkciziIlCtv5ZqbABBmiEBY2IEdB5SefnzA qUSGAKwezB2/
uuuun7lIe1eUAAABAElEQVRSmMappCmYxTmA4MoVRwBInYhABEkqaeK6g+h1 zy9yKgfGWVjW
rMqdvSaK7r17vDTJSYw0BTtxDlTeivioTFMRgFnSlJMkznef8ZLXcljctyfy r8glqaQhypGZ
ShAyjEGu5oWDyAACx7DGxyT5F0yV4131Ua+Sl+S0Y62amTZIqBnVXDiuVoS1 /cG23S4foJBH
6sQZMIMZwiIyVZcTQEQY4hgOSGN5fOv4Oaf07U4EwOaTe779QDrQhaFuhDHC GKkj5yAsLGAp
R5MwOZbUSWIQgUohbvnPPb/zqvX7H58AsPnU3tI9d1JPn+kdoCiUKETq4Jww g1lECOILJ87B
pZIkuUlTTAAAAQBJREFUoEjC0jN33HLGVW8tR2ZVz9r6gQks/IlMqo49Aweq PpvZpH5ADJlF
11qllGpl+oFIrRCCNEHRAgAJCEKAAXHlWQjAgEAExCCUf6LIBVT5pYuEkQz1 EBEMyJIwAQRH
RCIGEMAADJDACBkSS7CE0bG4mJtqhuUwDPqGQAQyZIwYBhuQCBkShlC5SVYY QiADY4hMPDbW
lTfGWnYOASEpb68mMi3lYGAFYggn97jn9IZFF08k8uATBw9ELo5dGgRJb19u cMgUizXvkVKz
Qo3OBSilVjyBc0gdCMIMdmDxtUwSqVQ3uZJTQiwQCBERGcLUt6QoRhTDEJJU ktTXD+EY7MhX
FMs4af4AAAEASURBVB0LUJ7pBCxEVK7xkVQ2E8cSRyBCkkiSwqWSMly5rinM cA4QcQ7sa59C
ZMgYXw5jLQDkJE2BRrXMsosG43M3FEyh8PSeiUd3je4NOY7TKI5Lo+OlXXuo r29gw8bu4aGF
e8+VUkqtUCxImUjALI6JGcJggTB8TomUz0FWGmmJyJhyYpbP/zlGmMAAcYpP vmtt6z2+4YO7
RYSIrPFVVo+EncQhQJLE5770wo3nn/7VP/s82IljcSmcA6dgueoz12y7+8EH brpDRGAMGYtG
3+kDAAjIBykBxAaBHB/Emwa50JeLisXkcFLsyUVxEsdxGMVhFJdKUengyNjo 5IZzzy329tTG
Y5tHAAABAElEQVRs8XdedRyAL962ez5vd0NXvXRNMW/+9Rt7aqbVCqWnqZQ6 QhGEhMEgEV+V
9D8+JklE2LeIAiBAQIAQgUCmHJkEMFOSEkhcG/1jWIhARASaasAiAI6RJEIE 5zaefzqA133s
rV/50P8CO2In7MTx62/4IICTnn/+A//69XLe+v8FVDNEkAFgjEXl+ksAZGhz MUSY7DsY7tw7
EYZJaTKK4jiM4lIYl0phqRROhtGurdt2bd0GwBdwno1sL3/B8BtfPsOXiJ4u aytdlqun1YpF
+qM/+nME/ki5JRYCYRJU8tJnZzkiCSAREiEAlWZU3xpa3ohj31yKdi74F0DI 109p6hS40O9u
5wAAAQBJREFUAJxK6pA6cXzrR7/gZ1/5iT9CpcOuz0sAt7zjY1TplkSoxO/0 MQmCyqGLYGCM
hYEBDebd5P7omUlJCrlDhyZ37jwcRkkYxqUwmgyjyTAslaLJUrRz6/aTNp+T Hf1ISMwc6w1r
hvJzW1GtXNqxQ6kjGAuo3D+WAPE1SV/FRKUPUOWSEyIA5eoXEU3lSOqEiPyo An/4iX1pKo7h
HFIWJ3AMx2DB165fx4LqFlmq7ByAuBREYIHIrR/5u9f+xR8CuPKT77nlvZ+8 6tPX+GVuefu1
EAEZMlS1GQAw1jLK9+cK/GPfjAwLsiSgwNKzzzkpDwSC/LFDa848LnXsWFLH zolzSJ+SlbEA
AAEASURBVB2nzOMjYwfTqhHyqs+4GgJw9avWjY6nvkY4UXJbfll6+MmJi5/T d8K6YrFg4oQf
3Tr58JMTV79qnV/p6lcf88Wv7wHwxpetyecMgGytquJT42ml1JFHh2Vficrx VEkeyvqH+ubI
acdtAUh8VXN6VBF8lx9jytknPnbhm0dp6jI1PxaCf0qovJAFOQJB0oScA5ny RS2Qr3z4b6/8
+DsAXPWp9/sNfOWdH6NyDZXLdVUp11drhj6odP8xRNY3rhIIAvTe89idu6Ox MAmjaDKMSqW4
FIaTpWgyDCdLUSkMS2EMG1z9gXdRpYGUmLhuEIP+3uCnj4/nc3TWyT2nbeh6 +MnCFNF8AAAB
AElEQVSJk9d3WUs/fnj03NN7Vw/mAHzx63t8avq8BPClO/cBeM6pPeed0Xvm id3TIlMpdfTQ
r8UrEIH8pZOUxaWfMuU2WTARIOy/EhEIIn4lAqjySyfHSBlT/XCqN0IgBvnU Yl+VJYYB+UtZ
iGDEMkBghktR7s7jyyJf+dANV37i3X6rX33Px6lcMIG/agXwUV7eEmDyASVF IAwAUGAoIALB
3+SLEMcyfsmmSwAWOBb29ctGtcxDXG7n9UM7mMrFm8ZMtf8+srUE4KyTe3q6 rDHGsVhL/b3B
zd89ULNkNv3K5w/191prCECxYBouUzOtlFJqOSBDAMlU9dL3hwUE5LvIGpAQ SPQdsgAAAQBJ
REFUGQj5ofIqtVEyMOQP7ERgELMP0Ep6GX8KtDyoDvnxdXzEGRL28wwRmcAy hAhgFnZUDgsh
ghi68uPvzkr7uk9/+NY//gsYCAvEd1gCiRCRsZaFKTDlAYfKtUwiQwQL34JL lg6yHfr5tvu3
Hrx3x+HJMC6VwslSOBlGk6WoVArDKAqjJIzi51/xsgtfeGx5t1nlufyWmWbT j20PN51U3HRS
9/q1hW07Ix+o1Uu+9tLBni779K7o7ofGf+vyVa23NvvfploudBB/pY5IZEjI +J49VGmNBfkz
meXgFM7O5ZGUg42EfBWz3CjqhJzASFbt9DU+8ZFJBDCBQEwA2JTPmDIIBh72 9jsAAAEASURB
VDBiOAARxF/g4lOThOh1H3uHL+etH/rUaz/xXgCv/Kv33/HBvyKQVLr5EgQG FMCkhm3l6sys
YVYMyJZrmWTML6T3ucV045qep/aPHjjk22OjcntsFIdRHEfpxjNPO/38c1A1 hHt1p1kyTacf
3R4+uj289Lze9Wvy55zS9ej2sGbJni4L4J6fT2QrttjaXH6fankg0+AGAEpV Ez2XuRIRCfkq
HkA4cdXUE9nUo7uZhASALXcLgvEXmZQbK4mIBT4yfeuolLdX6VTrg5UJvtup AXOl/lkehkCI
COIgDmIgBMJrr/1DX4Cv/ekNRPS1az75muven+sqvuYz19727o8AIiLocmuU AAABAElEQVQE
JjCIyFqyQAQH2FyAqe4/vsrrK8WW9tmepzg9cQ093xgT0E8ef3ayFJbCqBTG YRRHUbrxrFN/
5aWXDqweAirtyE6q47PF9GsuGShF8u37R9/84uHsWcdiDfnpQ2PpUF9w9inF Vf3lRD/7lOIj
28PqZaqnlVJHKtJryVaiSsOsmOy8YC2yRoTKvVodYEiYYYyxoFw5FB3DCdlK M6zACEQqJ0jL
lzaSH0kPDGJABOwbTn0bJAHswA7GQug1Hy3XL7/2kRuJ/AB5dPs1n7jiug8B ePUNf3HbO/+H
AfsRFqbqbAGyS00qF5lY8ldnGl/RJDwVDI1wYcOwveyC4nM3Hfu/VkLr1QAA AQBJREFUb71v
267IGqw/6fj1m04/47nn9A8O+nV94xoZqu7bVv1Br5neP+o2rs2/+cXDYcxP 7Ij8s8/uT/zM
m75/6FsPjF1+Qd/mk7v3j6aHxtOh3qCny5Kl7XviE9flLz23979+PlE9Pedf q1JKqY7z5wuF
kA1X0IAl8r1qGTAkTspX+IPIlrfiQCkjO//2Dx8YbrFTATGEK+dQKaic/hQG O0gKwdM/eWTj
hWff9mc3gqQ8JjsJCLd/4C+vuP5Pf3nPfQQRYfLj+AFkIQ5kLah8LpPe8rb7 N2wcst2Wuo0J
LOV9mQ1ZIWravSY7CSVcPVP0C6FSSh3lju+zP3rUBZaMFYPyENGBxs8AAAEA SURBVHjlSzAr
QxmwQDB1hxN2AucknnzB5sGdjgFcekb39f8eF/OUz0lgYAxBKheAAA5wICfw V2f625O4RDiO
ML7vz3/vpP/aMsFMl23uOfSP11OxC0GObFCuepaH6RMShjjitFwTTVM4x6mL Et4f4cx3/vn3
7h8DwLFLwyQ5PLFn9/j0MWat7+9rTEBZ3xpTd8E5ixhTTs3s9ibCMHpmUSml jnpEJAT21zgS
pkYm8PdSFpQHl61UQv3ZR38fETKVLrBEjjllGEciMOx71/pLVHxqihM4IedH fnfCIsJMEBgS
S2QBIhYml/jxEYiNH1ABAIRJmIRFmByDGSzCwiLOlzNrmLXLPlTeAAABAElE QVQwZBAQ6odl
J4KBtMjLqZmVgX6y7BTt/6iUUke9VJAPXOKTpzywj88pyWqZ5VH0ODvPKQRX yAOmfHPJKOW+
YjQZCRjWGEN+/co4CQDDMMBCzMJCwkDqyEUDPZJ1M4oSF3f3oTQBBll/D0t/ Eagf9JYNBOLv
tOJ8nZcdIgH1DYIAW3Wny1RQH5kiYCISZjbGgEUapma1rMY5tRHt5KaUUker w5PuzI3BL7ZP
xInj8rA6UhlFIGub9SP1SPm6TJFCwGed2Ld/giUAgCd3xb/xoq4vf3fP2Hhk rPU5J/BXkICF
GOXrJ4WZBQID5wa6+c0vXf/zp8vXLj65Mz7l8jc8c8d/te0KEAAAAQBJREFU RGOj1hoREiJI
+bbOVG6bZfIDxrMQxLFI7+DGV73p4SenLoBkU31dZjbXiQHEOSMkcBL4q0+Z qy+AZOGa4Y6m
zmuWRw5Uqi361UqpI9GEYxZz4ZkD2UgGZZUhZSWbX3UMSFM5NOlKYH+d5b7R RDh45xs21G5d
sn9l2hwAQBi5LTvjAxOpH1Vv3+FUeOCcq985u42E7omno/0HE9RVGMuRycKU CpgYMMa4RCgA
pYbAAMiSq12xspfqJ9j3NtLjoFJKHdUmI7d9vFluzCAbFWdflHzvQDKLFac1 eJbHb927z313
Tzw1u6pQ5VOrIlTTUNq84AEAF8bG5pgZvm+u9UO5E1mh7aYAAAEASURBVKwD KoP4oXJxaL2q
jBQBnEamUkqppSEQn4vVo+tI82ASiCmP6Q6eflGMCMMRAGbnkhS+6qqUUkqp 1sYnSgEApkAM
wHT9+05Z6iIppZRSS0kEqZM45SiWxMnf/L+/hM2xBep7zCqllFJHIWakzoUx UidJk4ZcjUyl
lFJHLxEkqXMsSUpxyq7lAAMamUoppY5GzknqXMoEIIqRtk5LABqZSimljioi YJY4dSwEkHOI
knYvjtTIVEoptaj27t+7d+/IEhbA5gobTlgPIIrFzWYsAY1MpZRSi+3+X+yc cRki8iO2Wjvz
9ZDOlYd8F/9fS8OD/euPWx+nsx4YXSNTKaXU8lIGkCjAAAABAElEQVQflrbl nbIci1/SOSYC
Y+bUnENeQiNTKaXUUtmxc/dtX/v+ou3ulS+/ZMOJJ8xnCxqZSimllsajj2z9 wPt+59znnEnE
xtiGyzA7EeNYWMoD2jkWdo6lfENNZmEWgaROADgnTkQYKbNvrU2chLF76uk9 Lzl3eMvTe+dT
4MWLTCKCHwC3MjHjkm3O73ghF3ovSimlMoW8LQT5ZqOYi+RY2A8twCz+UhDn LADHkvJUiCZO
fIImKbMIpQiMiZIUQDHfOI9nq63IXKFBQtN/AzMWviaSFyGhlVJKGUM9Xbns ZGV1D1Zm5wSA
8ZmZOslZcgK2kjq2lqwrd3llNtYIwCkIgCGya5a3ZAAAAQBJREFURCn8OU5u NprPrIvaka20
Q/w9PBdLFngZmule2UoppRafJaBy0CYiQ6ju62OrpolgqHFsmap1zIIl28y1 zOoGVSJqVglr
+NDzM1s3t1YvWf9U67UaLjDjK2pYPD9Rna8N25ObTTd8OS22MLfyK6XUEcMx DBlDqKnYGAIL
jLHMDW5faQyhbrahFne67IwFyWKfOlm1skX1rsWS2VP1W6ipQbbeRaYmwGrW zULLT1Q/bD/P
Wr+ceZZfKaWOPNaU78VMRESmMkG+upkxttVB0pQ3UU606jtldtYMkVkdJ7MN p3a0WHKeFa+s
tJn5bA1NXn7DuG22+iI3TSul1MoiwkSG6p4/TQwAAAEASURBVJpea9pm29ek EXfuZtf9p1p1
U22Lxsk5bLlT61bnU02r8gKZ1cvRmqVSStUwxCxtBV1gTTsDqXdWW5E5qyxs Pz7nHLQ1pWq2
8QUKyGzLrWucs0p0pZQ6mrHAwF8uQkBtEDbs7tpOXsr0RQjzvdSkVZjXd9ip iYrW/XoW0+LU
2Bq+xo68cK1xKqWOTlnw+WtLmp3nYpfNb7ARP8RBbUIugM4PZZA12M5zyRY9 aetXrM+t+qtK
sjOyM65bv5d2cnE+L1xrnEopxQLfdRaVBG3YXRYAN7r9CAsBAkDQaqic+Rxv W0VmO5Wq9ite
Db87zKreNuOKc9hO6/mt57Sz/KxmKqWrfot0AAABAElEQVTU0aO62pBFI6Pp hSWtNQzRjtMx
ZpVSSi0ZZicCJ1PdYrO8rDmF6VhEwNNbX/3Ys3XbBIu4Ss2keugfosZNu/Uc i3BtdVUjUyml
1FJiYXbEjS6+5Omx6fMyq1C6un5B9Xf0ctN7CRHKjbe1BCkLczmYm8WqRqZS SqklUN3xw7FY
Q9yoa6ybXousX4RFqpeZVQtt6sAizokP1hkroBqZSimlFlVUirNpx+IEti4a q/kkq26Srb/C
hFkcl2dyJfpSbtqHNk7FOal002235BqZSimllhKzOGqabdXVyuoapHNSfyKz us229SUn9Y26
7dDIVEoptQR83c6fa5wxv3wWNhy+a4iELQAAAQBJREFUwLFw2w2zLa4/aYdG plJKqaWUOg6a
j6vDzjDS7GFWOyzfJlOyh+U0FUh9DTKMO3OPE41MpZRSi6YcZl2FHIBid5Ep cE7qB8mrwtUR
WEnKclhWnwFNeaqKKVI+kVlzc+l5XhKvkamUUmpB+ZhiVN3i8ri1xVKcbly/ ZqivaC2hcjmm
VI3JTsTZwywpgWlhyVX/AhBIdY+f6itMkk6M4a6RqZRSaoFIJSmzLrIhgEJP NDiQG0Tu5JMG
169Ku2wYCQEFZje93ywBUh+TmJ6UvknWVzG5cq1I9XaqW2XnOfKaRqZSSqmF 4CphGQIQieNk
cs+BMIpk+44SgKH++LhVuVNPHofrQGoAAAEASURBVHI8abngnESGgCBOiaW2 JdarT0pUtcf6
OdmgPa6uWimY7xnNhYrMRbg55co1qzdnWb2Ty+GuNUqpZc9XLktA6JNyy/bS o1vGdh2MAazu
HU+lD8DdPx2LIvf9h39x1onDFz+3v6+713JhEgCCMEFSPZCPH/RHCNOTElUh 6ptkfdYKNz6R
OX9zjMxO3YVjnnmQ3eB6kQ/ic9jj0hayI3tfob8spdTiEiCpVC4PP7Kl9NAT JZLkuHX83DOS
oYEYoFwuB7vWmLV7D6RPPbH/J1u3/veDT28+tftVLzmlO1g1CeScSaaPTgAg rTt5WR2TzpUP
LY6lxQgG8zSXyFw+R71lUoyuSDDVAAABAElEQVTlbzm8UcuhDEqpBVbOS5HR OJm8675ocnxy
w7rccWuDwI4B+aqTmgAwWOjZtGHgzFWnPrJr108ef+wTf/fw77761ONPGEah 3zFKMWVVTZ5+
FrM+LBmSVS4BOMe+iulPZMbpMrvIpOa+0y3mt3OH6mZbq3kqC+/qjbS5LprX exqWsOGraHbP
7RabbVbIFsVutkCzctYXsuaNav3SZtzj4vyylFIrEPu8HBuf/OFDEYDTTurO BWHiENjaRVPO
c1jOoNMGj91w9nE/fuaRG/7tvre8+uxzNyHJdUdpHkCaMqq6wk5diOkEgJPy KD/VYYnpTbKd
ykvMLTKr795cHRJ+Tuvp1lhRuAAAAQBJREFU+iBpfTvJmuWbVXBn3HuzpxoG W/1i7cxpvdma
V9ribWm47qzeyfpCzuqltbNw6/22eCHNll8+TRdKqbly/vxlnJTzctWQAThJ i7kgnLYg5QLb
NRkLAJmguIRonABcdMLZff3mn7/yw7fmTj9t4wlxgCS1JZdloT8KwffuqalT +onqpOzU8AXV
5ljLbBgSDZdsNr+1FmvNeGyd1R4bbmq2Za5ffg5H/7m9UZ3dQsf329lfllJq GRPA+fOXDz+Z
FLu6CjmbOoSYLAYpgFLc3ZWfzJZOXdFEZjJClpcACr1y0Zozx0ZL/3TLQx9+ 2+D4ZGnn4a4D
Y9HI2GTDXUZJg1CMSrEOxmEAAAEASURBVFH1w45cjpnpWMNssyPj3MKjvu2x emut+23Ov7Iy
2y10pHo0z420eNMW1JL/spRSy4Nvko33HaKJsNDfWwQQRUnqukNMAuWK5kTU 21MYL68QBjIx
ddAo9Eq+C9Qjr37peU+MPHvLNx9/+1vOO2FtPo76ojhquMuG6q8tyWzfMzLH F1fR+YtMmlUs
OtjyVt0yPIeStG+2W1gOHVOXm9n+so6wl6/U0aFcxSSafHZnsb/XFHO5hFEo TE9Nazk5EI0f
piBPNJ4cklw87KuYWV4WC8gX7W+/4oV/9rl/f8n23cXCwOGR5NAYRVFsGw1D G+TyAKIoLhTy
AEqlUldXl59TiqKLzIE6AAABAElEQVTergKAiVIMoKcrH8Zpg03Mxhx7zGbT 2Smuhv046ufX
zMkeNlur2a4bLl+9QdTVYFo8NdvF2txjs1XmsNP238kWe2yzqLNaeIF+WUqp laZcxRyL4w2r
hpxjw5wijwIk5th1h5jct3unS/d2FybIrpHkQGnfeDSy98T1m/rWSBaWQRdM gNMHhy8858T/
vHv3VS8fMKYLCJkdUNeDCHjy0S2P/WL7pjNP/P7dP1m7avWmM0988KHHt23f dcmvnDc43P3j
+x4CcNHzNgP48X0PnXjiuuc978L5vMimg8e3IFXqZ2YPG85vuGT94bLhLmbc S7M9zrh6+4u1
s8fWm229wYZvgdVJvAAAAQBJREFURbMFGr6TDd/bdora4rfQzuvq1C+r2V6U UstYuS107/7J
/t5iwZhcLpfPBYUCFXO5oKsAYMtTBw+NT516dOP5aIQA7Bp/FED/gO0esl2D KPRIruDIxs89
+4R7H91fKFC+C8VCAoDZ1f+sPW5dd5+95Wt3nXjiuqHBwVu+dld3X++ll16w a++eB376xIkn
rrvoeZsf+OkTfnqeeQkdME8ppdS8lVtlR8eCtesKQT4wTpw1ZFxkOed4z+49 1tBE3Atgz8jQ
WChRur+f+049rtA9IKP2ibVDp1rDziVR6AAwJ+ee1h/H6e6dh03XKgCOpeFJ SmvMxRf9ykUX
PQ+ACM694AjtTDUAAAEASURBVEz/tfuss07Nltlw4gmdep0amUoppeZjqmXo wEh46snFfGAR
wLFIYAPhsJQC6CsSEDxzoBvAZCkEwkPJ+DH5VT09wUQysmdn0DPQAyD1V5Kw A7BqsOehLQeG
+0ef2Dby5Nbdo1HccPcW+N03X7HhuLU185kbnzNy87jLtEamUkqpDjhwIAbQ 113wD/3NvJyY
aDLsygfIBxNxAuDMk9f8+q+evXXngf9z6w9/+tTIxTkCsBu71xeOrdlgf2/x 4MjkcP/ARMKH
J0uTYdN+s/3F3JrhQRF/wWY5Ev1JnuoR3v2gB5Vn5xKcGplKKaU6I4riQi6L lcDHUlhwQ4Vu
AFvjQwDo/n3cAAABAElEQVQu2nwKgJOPWzXU37t73whQ9EuTKffu8VXMTFdX 0NdlBru7crZB
9x8AtqNXXramkamUUqoDYubYkUvKD50DQJwiiuzhMQYQWAvgxw899eu/evZP H3320Oh4f28h
CLoABEHBkAXA4rLs9IpWevNmoKsnyDUOrDSZ76Uj7dPIVEop1QHHrimmbmzv aNybzzODHeIY
AGhicLJ0YORQGo12Iz/5wCPPPPDIM1GSRpHbfFL5qo18V5GMFXY+OL0Dhycv Onudf3ZwOAkm
G9cy09B99Y7/Ghh80AY2COw5m04/54yN2bPsWl0YYgAnjTfbkEamUkqp+Zjq ZRNYe3j/uBkY
9g/dHbn/UAAAAQBJREFUuBtPLWBd3DM2emhi3Pb39hX6oigtDPVFawfMmsFe AIWCWTO8ihBk
lz0Ku4kw3XtwfHjwhCAoAmExn2+2+3FMO8e57ZfPnnbCscHUMPBTzbz1tVFj irN6qRqZSiml
5sn6U5JrhrBzx/4BOwDAh+XoKADkgrUT46MA+gYmTlyLgYGeNA0mJib8yqvW rA8sOQdCIEgB
kLEPPrKzmLer+ruf3TN6aH+0e/fhZvueSKOB3u7sYRQnP3n4F+efcVKz5Y0N yFoE1loSARHa
7wmkkamUUmqeDACR7lOOH73tBztPOO50AD4sx0YTAIcP2WOPOUPML7oK5XQK ggIwAeC440/o
69huhMkAAAEASURBVO4BnLUOgHMBAEH6g/u3nnfm0MTExO49Y0/veHbHjhEA SVK+I0ouV64d
5gILoDoyAezaf/DMY4ZtbmoO2W5jxBgim/N5GQCEoMl1KE1pZCqllJq/PFH+ 5I39gz1j27fv
GB5eD2BsNAkjCScDAINDrqdvbe9ADkE40DUEoG+g2F3otjYQpM4FPjKtdc7Z Ldt2P7Z178f/
6IJn94xOTiRhbLqKOVQC0gsCY2wAgF2D7j8PPr3nnGPK7cO5Qs5iEqaLbM7m C0FgyebgT5rO
8koTjUyllFLzRL5tVqT7gnOGb7vr4V8J1gLI8rLYnfb0jfb3TxZ6g8G+1b3d /dbmRsZsGE5X
KCywAAABAElEQVSyOAtbk5r//q3HL9682iWTu/eM7do9OTk27m807QWBAeDz Mm8trE1DN3J4
vLe74Ac7sPlcPDa5vxisHuy3gbE55ArdNt9FhXwAUFCc8+0fNDKVUkrNn/EV zXNO73rw0e6H
nnno9LXPyfKyWCAAQYBibir5ckE+xCQA4fKFJc5Za92Xv/nQtmcPfOZDl0xG ufNOXX3KulIU
nVa/PxvUdoUN7LRE6+vryhVy+e4um8uXK5dB0RDNZxhrjUyllFLzR5VOQIO/ 8crk7/7tqSf2
YkPv+T4ve/pG8n2hDaTmmktr887FbGAYMCAEP7j3lzd/+xcf/6MLhgaHuyPb n6cwmmGkpZmc
SQAAAQBJREFUAuamIWhzeWODXCFPNmdMB/JOI1MppVRHGCAPoJAb+M1XnvjP X3n2kYkfXtD9
vJ6+EQBF4pxNDBVyQR4AkTUmR8ZWXQOCf/v6vbd//6n3Xr3pnE0npa6YK3TD uHwv2Lkme5wm
bbSUD0syQGXAvPnQyFRKKdURBOQAEPUfsxr/9+/af775l9977GsXn3TWyZv6 gwC2UNs/NbCU
JhB2Tz578Iu3/Xz/4cnr/viS8zevj+MBoQBcHvDH1Y0Ti6rBY/3/BQjKY8yy wGD66LKdopGp
lFKqU0gkRwSi/kIOb3vzKd+/d9dtdz36o224YNOxZ2zIr1+/Pls0F9g9B8KH Htt/97L5bi4A
AAEASURBVM+eeXzr7ssuXP/J91/S19sdxwMp12aTJQLgRLL6oqncoJ4hAGiq 96up/I/Q6eDU
yFRKKdUxIsRsRfLODTgnF5937PlnDj74i8PfuWf7t+6OgZ/39xaHh/rGJ8Jt z+4H0NddeMF5
w+944yWrh/vDhEoHIPFInJZPeZINANhgKqqMtQCM9XlZWYysVI9CtGA0MpVS Ss2XiCQpJ2ka
xhyFcRqF4AQIARTyuXNOWXXOKatyOffE0yNVKx2z/pjBvDEA0sgcPoAk5DAe TUIHwFjrxyIg
2x0EsMb4sPQdZWui1D8lhgz8SAhZFbTDNDKVUkrNFzMcS5JKkjiXpi7lKHIu SYskl5fsAAAB
AElEQVR5m4Q2VwwAFPLpCatWT1stwUQcAEhCCePUJUiiBJVcdAl8ajILwKhE YyZ1CKaPqc5I
DQICZ82znaWRqZRSar6spaIJCrmgu+gcF5ldGLNjTuM0sBHHKepG2kkq97lM nHNEuQJyBRR7
YU3lZKS11XVK1FUrAZDJCSemsoDA0qyH9JkFjUyllFLzlaVUYG1gAQRdBfgR dvxlkyJc/ZAr
95F2AnYzZBxLYCgVCtDoQhGWcsSWO/osXGBqZCqllOqA5kFlCCwgKp9fNIAI 28rAAoEIAmSj
EbBMnYTMrsY0gL98pbrH7JJYkNZepZRSR48FuABymdLIVEoptTTmNjb6EprW 61KhvAAAAQBJ
REFUMHvzlz6/VOVQSimllqWXZFPTIvP1b3zrohdFKaWUWr5+/ImnsulpkXlg 7+OLXhillFJq
Oasae2gJS6GUUkqtIBqZSimlVFs0MpVSSqm2aGQqpZRSbdHIVEoppdqikamU Ukq1RSNTKaWU
aotGplJKKdUWjUyllFKqLRqZSimlVFs0MpVSSqm2aGQqpZRSbdHIVEoppdqi kamUUkq1JZh5
EaWUUkcrxy4JI8epiCzOHtM4WriNB/mCnyAiIjJkc8WCNbbd1ResYMvFZ29/ eqmLoJRSK8a7
rthY/TAJI2PM335j65d/sGXLjpGlKlXHrR3qvvL5J3/0t58rzkEjs9q1v29h KL4AAAEASURB
VP+ypS6CUkqtANd+4c6aOSzub29/Ysvu+O8/+FsvOu/kJSnVQnh0+55rv3Dn Z2997N1XndP+
WkdFZCql1NFp1yG3b5SiMI0TThwBYBbHjsX4hlZmw8Ipy3NOyp1ybL7hRr78 gy2fv+bNl557
0qK1zS6CTRvXvOPKX33rdTe99zfOF+E219LIVEqpI9a+URrspiifixN2QgDE CXM+ZbAwAMfk
HOKEn3omahiZIrJlx8il554owiIAjpDUFJGLTl+3ZceIsTmXtnv2VCNTKaWO WFGYRvkcO3aO
nAOAlElEUgcwAXBA6gCALDXcAhEBcI6PmLAEAEgSx0kcovIC26SRuSxv3ija AAABAElEQVQQ
0ZHU4qGUWibihH39MnXioxGAOIkScjwVFQSYlonI7I6kyBQRdqlL09muuEiR uXrdmfv3/GJp
t5BZufk0z5L71Vfuy1dKLRVmn7cLcujo7u6bnBxrPaezRITFMc86MmcxlMHq dWfOON0pfpsL
seWjmSalUkebxFGawjk4JmHxPyA4JhERERYWEZYZs0Dm+dPd3dfd3dfk2frt d2CP7f3MzjId
/adTFcpm/EWsmN6Knc3J1CzfsMm75qn6zTZbrOEGZ9x1m2s1fKrhRlqsq5Ra 6ZjFMYRFRD7+
yevJEBkaCw0LC+SzN17HIIHIzOEh89RiK/XzO7C/9sz2/exkZK5eWC9DZAAA AQBJREFUd6b/
yR6irqbY7GGztWo2WP2wfmvta/1mZe9mljQ1czINn6pv+axerMUG6+fXrNis 5O0Ur+HLb/HS
lFJHgMRJ6uAc/eV11wH4y+uuCxPJ59gRbrzxegB/e+N1DALg/21GROaTYj09 A+Pjh8fHD/f0
DFTP9D+obLp+zgKb9fs5i8jcv+cXWZ7VTGcT/qc65Krri3M4H+k3WD1dvf35 k+nh1GyxWVXF
Gm6nPsxmW19soXUtc87rKqWOGB+55oN+4q8/dT2Az332ev/w7e/6QDurzz+a aiZ6ewfHxg75
Hz+zfs4imO3buLANs23mZXUGz3n7C2o+b3G2enUyNdvgHHbUrIgMdZAAAAEA SURBVCrZcL/N
yjbnl6aUWs5ERFiYmZn/5L3ldPSpiUpeCombua/D/E8ZNpvIpuvnHMXnMjtb O+wgmU0n0vnU
xhruotkGO1jtW4SXppRanhyTk/JPYOiDf3JN9tR73vuBQq48LZC05QA486nJ 9fUNA+jrG84m
ZPrZSlQOUzVzFsFs38/ZRaaPPV+3q56e1eod3ODcMlhmqnhlbZXZb65mTv2m 2mzXbb3B+vnV
c5qVvGaZFvutf/ltll8ptUI5gWOApn4+8CcfBPCu910zkWIiRUpICSmjdadZ kbn/ABgZOZD9
+K1Vb7PZHBH096/KZjabnmfZZqVj12VWx2GL2JtVLmbb7HhviI6YAAABAElE QVQDbHU8NAzC
Fsu3fqrhkjNuMHvY/pLtFK+dvWhSKnUES1NkIxhUqkjy/j+5JhTkAgKQMtJU ANAMrZTVzadz
ULOijIzsHxhY1XpOo3WbTc+hPHNpmJ11ZFanV02StXjY5lrVPX2aTTSbqZRS aoFk7V5zWPfw
4X3VK2YPDx/eV7P9hnOydZtNz4H4y25mv4VZRGbrVtCVm17tVOOUUmqF8rVM a8Qlle6HVhxI
WAD4e3gwi+FWhz6RudTJvMHBtfUzDx/eO7etdYaIMAv8+duFGWN25YaiUkod nZjZsRMyzFOZ
54SExQ8WJyzMQsKtawtpkvjhDgiYVcYA2L9vZ6MNznqwSGpxzgAAAQBJREFU uk4RCLs0iaM0
SQDQAkWmUkqpleW8k4MnnwmFyVUFg0CcZDcukYBFRDZtaBwHBFo71P3wk8+e ckwvCxNW/GXc
IsLs0iTZsvPw2qFuYwMk7a6rkamUUkesU48vnHp8YT5bMNa+7pKTP/nvP37z C0+64OShThVs
CQkEIk/uHvvcHU+84dJTjc3NvE7FURGZ137hzqUuglJKrUhBLvc/f//iz3z1 oY996cEtO0aW
ujgds3ao+zdfdPpfve1lxtj21zryI/NdV2xc6iIopdRKFQR5Y3MfeNMLP/Tb LyEyNLtzf3Nh
bH7hNs4uzvZDBBEpTR5of/UjPzKVUkrNmQi7NHJptKfxlqIAAAEASURBVNQF WRaW6c2/lFJK
qeVGI1MppZRqi0amUkop1RaNTKWUUqotGplKKaVUWzQylVJKqbZoZKoVbznc unz1ujMXoRhH
xi5mu69ZFWn1upuyf+ep2Ubq53dkd347ndrUQuvU+7w4fzgdpNdlqmWkxR3I l7PqQq6IArev
gy/Hb6rNDXZ0vzcB2L/nTbNaZVbLt18Mr+HGq3e6EAVoURi/u4XeaaNirLw/ Fo1Mtby0vgmr
WmQdfP9X0K9yIfJykdOohfrCLJ+yLX8amWpZy6om2Zzq+lyzVbIl/XT9Kn5O Tb2n5tlm22y4
ZPWOsunqLddPdKokzSq4c9579eptvv/t7Ldm721zMN9UAAABAElEQVS+0tZv eP2K/uhfX12r
n6iZWb16TajUPNtwTuv5DTXbbHWRqit/DSfqi93s2dYlqdnpjK+65n2uLFD7 kZjxg93it9x6
3dafydl+bNqnkamWl2YH4ppgqImKmo20PmTXP1U9UTPd+mE23bCoLcytJA1X nK3W70Ob+239
/rfW4tfa5mIdbwlv3SJa/2zD5Vu0rPokq95aw4VrVplDsVt/M2hWmNbvw6ya bWf7wW74e5zb
ujP+nXbko6KRqZaXRW6+q/kba7bYfP7Ymv09z60k9Wu1Phy0ebBonZdz0MGD VLPtz23Fhqfu
Wndjab+TS4sl53mesmFu1e+u9bOzKkzDXk5zdUGjagAAAQBJREFUKHn7H+xO /VG0WGX+H0iN
TKXKmv0t1TcnztOMVbRF/t5Qv/fl3y+jneLV9OpsdsRvnZ3tJysW96TgjAWb Z2EaVkDn0Jdq
+kba/d4222fbWaUjf8h6kYlStToVY9XZM7ccauebdbMtz2fvNecvZ2X+r3pW WpfTn3XLzr1l
MxezS+o8VZd2biWfZ2Fm7Os7p23OrrrZ/rMzrjLPmqvWMtWKNIdjevUqzQKm 4bM189vcTouc
aF341tuff/+F1tufQyHntvcZqxQtFmvzJbRdpDe1bsNscSFmm+cI61OnxcLV z7aIqPaLPWNh
6nfa8ORrs9JO3/hc/sTm+WzDZepX6chnhu7EMO0AAAEASURBVN7ytvuPPWaA egmQa65O57wh
pdSSWPJG1CUvgFomjtRPwnX/GIAoPHD4l9sOaS1TKTUXHaznddBKGT3nSHJU XdapkanUyrZU
ibWskjJzVB2+l5vl+ZHoLO3+o5RSSrVFI1MppZRqi0amUkop1RaNTKWUUqot GplKKaVUWzQy
lVJKqbZoZCqllFJt0chUSiml2qKRqZRSSrVFI1MppZRqi0amUkop1RaNTKWU UqotGplKKaVU
W1rdyeSztz+9aOVQSimlloN3XbGx2VMz3Pzr2t9/WacLo5RSSi1T137hzhbP asOsUkop1RaN
TKWUUqotGplKKaVUW5YsMm/+0udv/tK5TUtsAAABAElEQVTnqx8uVUmUUkqp dswiMjuYajd/
6fOvf+NbX//Gt9Zsdg67mO0qms1KKaXmZukbZn1wKqWUUsvc7CIza02trxr6 p+qbW2vmtN4U
pjfY1qzecPl2VqmZblYkpZRSqoUZrsus0bpGmD3r2139v9Vz2tlUw1Wy6frt tF4lK0b1U1qv
VUopNQezi8xMwyiqN8/KXP3qM6Zdw1VaF1IppZRqxxwjs03zDKo5rK7RqJRS aoHMvfvPrGpv
Ha9utr9KVhueTwGUUkqpWdQys+BpFpNZLPkFqoOqzWSt3kWbq7deJQv1LOBn fBVKKaVUQ/SW
t91/7DED1EuAXHN1Wv3cZ29/usWwfLT6eQAAAQBJREFU7DVVTD1fqJRSaqW7 9gt31tzJ5Lp/
DEAUHjj8y22Hlv66TKWUUmpFmNe5zBYPlVJKqSOM1jKVUkqptmhkKqWUUm2Z ocds6/tTK6WU
UkePVpFZ02tIKaWUOpppw6xSSinVFo1MpZRSqi0amUoppVRbNDKVUkqptrTq /vPZ259etHIo
pZRSy0GLrq8zXWTSfIxZpZRS6gjT+tLKme9ksn/fk50rjFJKKbUYLNxsVxla c0brBfRcplJK
KdUWjUyllFKqLRqZSqkl8+SWx1avOXWpS6GONAv3udLIVEoppdqikamUUkq1 ZV6RuWbtaWvW
nlb9cN7lUUqpKfM8wuhBSXWW1vrLi7YAAAEASURBVDKVUkesfXu3LHUR1BFl 5usyW9u3d8ua
tafVfC6zb3Z+fvVDP50tX7OkUkrNqP4IU30gqjng1M/E9NqnHnxU++YbmQ1V J6Kfrv5ko+4j
Xv2UUkplsgNFzdHDP1s/s+GRpOEqevBRc9CByKyvaLZ//kDPNCilZqv+uFFz /NEIVAuk87XM
mi90rRfWT7ZSarZaHDeq21318KI6rjPdf7KTlHOm1U2lVEMNO0x4zY4bGpZq gXS+ltl+fFYv
qR9xpVQ7Wh83Gj6lhxrVKfOKzJoPZcPp6octJpRSqplmh5T6hzMefGZcRakW FqTH7NHm9z86
OTRcMMVc9cx8YACYgACYNt73u9rgAAABAElEQVRmThemcEota5v/5UdPA7mZ F1RVOJVmT0k6
7Y5XCQgAh8mhg9EX/rx7wUt2pNPInJer/+TQ2o39Z53ZHfTlc/mgAACweQOg CJgcAQgIAIyh
1ptibvo3oJRSmeq45ET8cYaTBgeQEHAxA4jTrnAkfN9n471Pj37xr4cWq6RL 5tTTNu3f96Rd
gC3PHJml8dEF2O+R4N0flxPOGF692gQ9OWtMLmctCQUGQBdJ3hJZQhth6S3E b1ephaNf8haI
MdTsvRUnAILqZ/Plw0uaa3CcKSaCvAmBPBgDxRMCM1yQP/jQyA0fbuugdBQa WjPDAjNH5vj4
RGfKcmR5718XTzhjeLhfofK1tQAAAQBJREFUKCBOGSSOOTEGMZvAxEQ5Yh+f QFtHFkl5QQus
lDoC+FpjM3E6LQslmWqkTcEwlO8O1q8J/uCD4f/zp/FCFfGINnNkTkxMLkI5 VpxVQ309kgAB
hwywAyggFxAAG9jEUghYY0xQexkP10ejkP/yqBaCtPeVRanlTIQBCAsY4irf w0WAqe/kIuUp
gcChvLybfsBJOGfM6uHcxMThxSn5EWbmyLzw4ssXoRwry2+//YHBQcrnjCRO 4ChnAUgMSg0F
5OBIDAAETb4SVgckG2HXYBnVIRqZC0U/tgsj+8QSaGqOQMBwWDOcP+OE7mKh 8l1cpGbl8n9S
mRYAePDnI3v3RABRAkyzaL8AAAEASURBVAOs7sKnP9f3f/7lkkV5QUeU5d79 50eP/OxT3zn0
rYd2jD+7G0Dv8cdcvnn9e186dPHZ5y5twQrGSCIEQk4kKadmDU7ZEMFWmkqc AGD/EZ863Dg4
PawvJH1rF4ZATyUsjKmDAxGRrzv6hqjVQ8HZq8Lo3v8eL01yEiNNwU6cAxGc Q7miKUhTEYBZ
0pSTJM53n/GS13JY3LcncuzQvLetmtGyjszP3XHPOz/9w9e/8oKb3n3ZC04Z EsHdWw/9011b
nv/e79z4nom3v2KJvyIlkDwanEWXVAgMW/kaWKlTVofltJbYcuOKHoAWhlaG 1IriM5KIsmlx
IiwANp/aW7rnTurSJiRFAAABAElEQVTpM70DFIUShUgdnBNmMIsIQeCnnYNL JUlAkYSlZ+64
5Yyr/mDfngiAS1JJwyV9iSvYIkXmhtd/rJ3Ffnnzn2XTn7vjng/+x7bbr3/T 5ZvXR4Jj/uD/
A7D779/y8s3rv3nZaW+64S4AS5maqQQhw5j6K8qIjEDgmKzxMUk+H6ly+K4+ iFfykpz2YVsQ
WoNfICL6xi4kB7FVpyQ9EQ7DoG8IRCBDxohhsAGJkCFhCJWbZIUhBDIwhsjE Y2NdeQtAq5jz
tHi1zO9d/5t+wpRZawNrbRAE1lpj7Dm/d0O28I8e+dk7P/3DLC+rhYLLN6+/ 6d2XXfGBm87f
0NNOC23WuLFgyTz8ZwAAAQBJREFULABrzSm9/Jy+pMjxRCIPPnHwQOTi2KW5 IOntyw0NmXyx
cfEYorf6ViuNrwapznN1E9XiWOIIREgSSVK4VFKGK9c1hRnOASLOgX3tU4gM GVP+dQWEZJFe
xxFpsRtmm+WlMdNC41PfOfT6V17wsqq8PPgPb4mzb1rAyzavf/0rL/jUdw79 +9m1u6j5S+5s
WDZKX0s5GNiLhqLzNhRNofD0nolHd43uDTmO0yiOS6PjpZ17qK9vYMPG7uHp FxHrF76FR40a
z5VazmqaRkgIgJAAJOwkDgGSJD73pRduPP/0r/7Z58FOHItL4Rw4BctVn7lm 290PPnDTHSIC
Y8hYgIy1AIz0yjsAAAEASURBVJCTVMcam6tFjcwWeWnMtO4z33pox03vvixr jfCtsgB2//1b
UAma36s0z9bIzgQsRM1yaptB+fNHgGFzXDE8a1AKfbmoWEwOJ8WeXBQncRyH URxGcakUlQ6O
jI1Nbth8brG3p36zL75w+IR1xWf3hN+7t3HP76teuqaYN//6jT3tzL/61cdk 03HCB0eSb//w
0Dxe9Ax+42VrAHz5zn0Lt4v50PZDteJM6yubzRQiAI6RJEIE5zaefzqA133s rV/50P8CO2In
7MTx62/4IICTnn/+A//6dQIIQPl/ar4Wr0GwdV7W1DLHn939KycPCWCBoJKU GRGI4KKTh3w3
2nZQRbOJtJTBAAABAElEQVQ5fqL6Yc3y1YsBMMYiIPJ9fAjnFiOEyb6D4c69 E2GYlCajKI7D
KC6FcakUlkrhZBjtemrbrq3bytsB+R//cKAnANDf0/QbTE+XtbbBR77ZfABf vG33F2/bPTKe
HrO6cMWlq1q+PR3z8hcMv/HlaxdnX20j/dGflfRjqelgYAJwKqlD6sTxrR/9 gp995Sf+CMwQ
gZTzEsAt7/gYoXxikwAiorrLxNVsLXJkNs3Lmsj0/G/bdyTlOHFJAsACDPAs GzWlIovGmjnZ
zGbP1iMQDIyxxtBgPp3cP/H0jrHdu8d27RrdufNwGCWlMC6F0WQYTYZhqRRO lqKdW7fXbYLE
oL83TR1XhgAAAQBJREFUAMr/dtY3//sggKGBBRz2+st37suqmGuG8vnc8vqz JNIf/VlJP/5j
6y9Oy2ZXf6TFpeJSn5G3fuTv/MwrP/keEb7q09f4h7e8/VqwAzP5vKysW26b VXO1eA2zrfOy
JjJ7jz/m3q2Hfu2cbqD8207DyE8yAAEI92491Hv8MfU7alN9Fla34M3YtcFY CyIyBhZiKLDm
2eeclAcCQf7YoTVnHpc6diypY+fEOaSOU+bxkbGDKaH6IhPChWf2AYgTzufM BWf33f/YeLaX
q168uqfLxknl+pPKcLXN5k8v4tRM58Q/vOKFw0P9OQCHRpPb/+ugf/bqV63L CjBRcrd8d7+f
X+9if9EAAAEASURBVL/wxc/pO2FdsVgwccKPbp18+MkJvy6AL359TzZ99auP +eLX97Te3aHR
pKfLfunOff61/PTx8YefnHjOqT3nndEbRvzl7yzTZl41RceYXRj+2CMCWPId 6cUyORIICJIm
5BzIQPwxS77y4b+98uPvAHDVp97vt/CVd36MyFcqGOKrmvrL6ozFi8zWeVkT mZdvXv9Pd235
tXPWA+WAjEfHAbCUP08k+Ke7tly+ef2cy9P6FFdbJ8AMkfVfAEmA3nseu3N3 NBYmYRRNhlGp
FJfCcLIUTYbhZCkqhWEpjGGDqz/wLgBUaU0lpuH+HICDI+kxq/N+2rvihcM9 XfbZPdH3fnLz
qRREAAABAElEQVQ4S6MW8xv69YuGAOw7lKASYM/uiUqRO21D9xUvHM5iDMCX 7tz3axcOHr+u
4Oe//JKhof7c9p1hkvJpG7pffsnQN+85dPL6Lmvpxw+Pnnt67+rBHKYnZTbt 87LhFrLdjYy7
/YcTADv3Radt6F6/Nv/wkxPr1+YB+PlquWvvfgNqDgwMgw1bDlIRkDNi2R9q wAyXwliAfFsb
Qb7yoRuu/MS7/bpffc/HycDHKwAuVzqkXGUFTD6gpAjopZlzsZiR2SoviaZF 5ntfOvT8937n
9y477UXnrAfQ94q/8fP7Xvk34994nwB3/XzHzd+4/+5PvXT+BWvdUajZsxQY CohAsESW7flm
IwAAAQBJREFU4ljGL9l0CcACx8K+ftmolnmIp16pMAMY7AsA7DmYHLM6P9gX ZN8efDvt9x8Y
zeb4iWbza2RJtv9w8p/3jRhjshUBnLahu783qF7RGPP9B0bf8oo1fv7wQA7A 3T8b8wsPD+SM
MY7FWurvDW7+7oGa/dZPN9xCtoyfb4y595GJjccWB3oDY8xAbwBg57644StS 6mjBMDAwYmDB
hAAMQUpEALOwo/IfiBBBDF358Xdnq77u0x++9Y//AgbCAgFJ+V8igiEKjB8n SM3N4kVm67ys
aQi9+Oxzb3zPxJtuuOumd1926dnrR7/+vuwpFvzgkR1vuuGuG9/zq3MeNq/6 JGV9IpUGV50A
AAEASURBVLZ+tozIEMGCCCAcdHbo59vu33rw3h2HJ8O4VAonS+FkGE2WolIp DKMojJIwip9/
xcsuvOzYqcutjBGIHy7ykW3huaf3FAum8scAawgAVYWHn242v8a/fuvAi87v W782by1Vr/iW
V6zJtt9wI35+zV78zMe2h5tOKm46qXv92sK2ndEjW0sNy9CwnM12B2DX/mTj sYUXnNfvW4af
3BE3fEVz47+XKLWSGBAMyoOCCQDDAQKACMIQRjk1SYhe97F3+JVu/dCnXvuJ 9wJ45V+9/44P
/hWBRBgM8qMCGRgybPV05rwsai2zzbz0/Mg+V3zgpte/8oLfu+y0S89eD+AH j+y85TfEAAAB
AElEQVT4p7u23PyN+298z6+2HvqnOuoaTtdkYeuHjTdlQLZcy3yMey8ophvX 9Dy1f/TAId8e
G5XbY6M4jOI4Sjeeedrp559Dlqo7jl+0qXzNyW9dXu7UetHZPfc+NgnAsVhD VNX85aebza9B
hn7ws/HXvGBgqC/w2/Qr/tu3DzZcMZt2LGSoZi9+5qPbw0e3h5ee17t+Tf6c U7oe3R622FTD
LTRc/p6fTxy3Jrfx2AKA/SNpw5czZ2T0ALEgRM9lLjyCETAYMJVR9MRBHMRA CITXXvuHfsmv
/ekNRPS1az75muven+sqvuYz19727o/4jo8EJjCITMEiggNsblkPlbqcLWr3 KCy1SQAAAQBJ
REFUn/bz0nv7Ky45f0PPp75z6E033FU9LPvdn3rpkg/LXr4ok2DIwNA+2/2U pCeuoecbYwL6
yePPTpbCUhiVwjiM4ihKN5516kW//qLB1UPi04LLQ0cODwQAnt4T3fPIxCVn 92xcVxgeCHwX
89EJN9QXXHp+7w8eqnQIajm/lgWAR38ZPve07hOPK9z7xOT+kXTdUO7FF/al To4Zzh0ac9++
f7R6+Us39/rtw+LQmFs9EFyyuSewBODQmIPFay4ZKEXy7ftH3/zi4dr9WqAS k3664RZqls8c
HHPrhgyAex6d0NttrwjU5OomNV9MWW8dYZnW4kIAO7CDsRB6zUfL9cuvfXEq Q+IAAAEASURB
VORGIj9AHt1+zSeuuO5DAF59w1/c9s7/YcD+tib+mygF0EtN5mPxIrN6PLz2 XXz2ufXj+ywT
ZMlfnWkskaWnaOAwFzYO28suKD5307H/+9b7tu2KrMH6k45fv+n0M557zsDw oHC5t7dvKyRD
vV0WwL6RlCztG0k3riv0dll/MPrWA2Ovvmhg/er8Gy4dyvbYYn598QA8tTse 7g9OObbwqosH
vnHf6K9t7l09EFhDSSo7DybVK77h0qFcQIfG0289MEaWvvPTscsv6Nu4rgBg /2j6nZ+OkaX9
o27j2vybXzwcxvzEjqh6dT/97P7EL3DT9w813ELN8pln9sXrhnKHxlMrmPPt AAABAElEQVQ9
EKujXNZtB/7PhMlXMcGVhll2kBSCp3/yyMYLz77tz24ESXlMdhIQbv/AX15x /Z/+8p77CCLC
JAwRKm/QgvRc5twtUmRWj7d+xDBk/Dl6Kp/RNAfzXYeox3QDg7jk7WfVNBwz w3dyEoaptD3e
/MOR8kfZ0FN7kqf2HEZVo+Xt941Wb2HG+d6X/mvaRn7yZOknT5b8nLt+PtFs xVt+OFIz884H
x2uW/NHjkz96fLJmZvXusgX8w/ot1BfP6+22AA6Ou862yiq18vjqYNbubUH+ AksLMoAwOBVH
AH5263d+dut3yvfGFCmf5hSG8O3v+3OkaeXidgEBRCZvOXba1Xk+v98JAAAA AQBJREFUtEV7
3qzvvW1MQFmnFlPX2swixsD3RMl6B1dn55Jbwqz6zecPAEhSuf+pUCNTqUz5 FruWyIKcgIiF
ySVEJACxAVWuuRQmYRIWYXIMZrAIC4s4f2dBn8QWhgwC/SubI43MDiCCgbTI y6mZpnLvzEp2
inbnBACMldz2vXo5plJlZKjcwarS9QFAlLi4uw+lCTDIOpABCL5JVgTCBgJx YPFD/4CZHSIB
9Q1OG0FIbwE2VxqZHSACJiJhZmMMWKRhalbLapxTG1m6/oe+pXQJLXkBlFq+ qo4MW3bEp17+
hmfu+I9obNRaI0JCBCnfPJBESBjCfsBPsBDEsUjv4MZXvenhLSZLNxwAAAEA SURBVOVTKmz0
XObcaWTOFzsxgDhnhAROAiIy5ROXWcc0zvr9lGWVS5+U+pVvAem1EGplIlfp OMsEQED7Dyfg
gXOufmftopL9K9PmAADC0D3xdLT/YAptjp03jcy5Y2FKBUwMGGNcIhSAUkNg AGSb9kuT6ifY
d2rTw7pSakrtEByVR3v3xt/dG5cfVB1J/PlKEaGa5iutUnaURuYcuTA2NsfM 8DfssYaMHz/P
wV9xXO4I2+R7XVVGigBOI1MpVUsgPherb2YizQ8XAjFcXpJrh2dhOALA7Fyi 95ieI72mVSml
jjrjE6WZF1J1tJb5/7d371FyVIedx2919cxI8x5pNJJADyRWqZGQAAABAElE QVSBLJ4SEEDG
iyQM4WBjEoQh5mFlE7IGhQT72M4a7MRryO7hcVgnJhwbsA3xBicrwBycGFsO Z2OwTkysgDCI
hx4jJCwkNJJmpBnNaDQ93VV3/6hRUarn7eqq7p7u7+fo6FRXV926t7q7fnOr qm/HMXtWh2zV
DCHvvNk+68HpDwCTwANPNJgMsBUXvUwAAJQQmQAAKCEyAQBQQmQCAKCEyAQA QAmRCQCAEiIT
AAAlRCYAAEqITAAAlBCZAAAoITIBAFDCGLMA6pdhGvmxnGEWpCzTrwkVxnPp FZ5tbLImNE3T
NC2j6Q1TmvQMQ8omhsgEUL/yY7lMJvOdn+18ZkNv796hU8jSugAAAQBJREFU SlcnMT1dzas/
tvCez54nDUMQmckhMmvcw8//ttJVAKrIHZ+a73xoSuM7z2/v7Rv/3l03rVy2 sFK1Stw77+2/
+4kXHv7nLZ+/9qxK16WmEJm17+5brqh0FYCqcPcTL3hnPrOh97t33rhi6YKy nZstg9Pnz7h9
9UdvfWDdl64/V0qz0tWpHUQmgPolpezdO7Ri6SlSmlIKIWokNaWUFy2e2bt3 KKM3GIUUr57W
GyITQP3SNE0IYRhmzYSlEEIImR8fz4+PieMNRFKITAD1zjSNWopMKaVpFIxC odIVqUFEJipA
07SQ60bhzwKJM01DCFH+1GxubhsdHU68WCmlKQ3TJPQhgj4AAAEASURBVDKT x1AGSeqeuaR7
5hLnwwpWJoTmELuEBBcrakkgBTLGv+bmtngrOv7F3HQx5SNJ9DLrTjn7cHQW MUnIePf+lP4O
T+MzIo9LvGQQmQnr37+1e+aS/v1bnTPt7qY13/nQmraXdy1pzXGVlga7k2d9 zLwP7Y+fPW0t
4/xYOnuKrhV9n3I+9Bbou1EgDROBWfx7zLVKa2unNTEyMug7x7tAmpGZeMEg MsvCm392djon
nOmYXlJKKUMSUShnle/8yMDzTcrYBywgEYlEZltb1/DwYWu6tbVzePiwc461 pGuBeBtVqRWZ
mRIiM3nejqb6RU3vkmkE56TovVnRbv9f6eqgtkm086z3AAABAElEQVTH/zFW 9H3oU2Zb27Qk
NqpSK65lpoLITJ2r7xi+cBnOwQJwSerErPOht8z29ulHjgzY0+mdXKGXmR7u mE2FfZEyNnv1
qr3ttgzoYqI8pIzzz7Wi86E1rb5Ae/t0+6mg6Xg1RLLoZaZOPT6dS6bX3fTe ieO6uum92Omc
Y8/33v4TxLt6yDIEJCoh5jnSjo7p1sTQUP/QUL/zoRDSNcf50G+j3pO63mlF nJhNC5GZJGfO
BU07H4ZMBK1buvDbdoKWKXaO66RT0G2xvstMikutqCXxzpEODh50lWDPsYty zXGtMjh40J7v
XMV3upjmmJyYTQmRmSTf3iSXJ4XfjbJA9ZAy50iZCAAAAQBJREFUgT5ZZ2eP a87g4IESy4xJ
SmmaUlg/YMIgIUkiMpNEOgaJl5TkK8qjkM9LIcVEvMTMmP6DH3iKrcCQdVJI 0yjkx3OFfF4I
oRGZiSIyAdQvTWg9Xc1v7tizaFarKU1NxB9FskpIKU3TKOTzvR8M9nQ1Z/Ss yFe6TjWEyKx9
vj+rC0AIkdH1ay5e+ODTG2+8ZMH5C7sqXZ0ESCGFlDv6hh9Zv/26Fadm9IZK 16imEJk17o5P
za90FYDqlW1ouPeW5Q/9ePNfP/Wb3r1Dla5OYnq6mv9g5eL7116RyeiVrktN ITIB1K9stjGj
N3zlhku++tnLNC2jpX/tL6M3ple4aYzb25+4YWsAAAEASURBVNE0IaU8NjqQ 3ubqEJEJoH5J
aRqFnFHIVboimBwY/QcAACVEJgAASohMAACUEJkAACjh9h8A9cswjfxYzjAL ZRtqqjCe4q1G
2cYma0LTNE3TMpreMKVJ53smySEyAdSv/Fguk8l852c7n9nQW2Pfy1z9sYX3 fPY8aRiCyEwO
kVnjHn7+t5WuAlBFXIN7mNL4zvPbe/vGv3fXTSuXLaxUrRL3znv7737ihYf/ ecvnrz2r0nWp
KURm7bv7lisqXQWgKvgOHvnMht7v3nnjiqULaulnAE6fP+P21R+99YF1X7r+ XCnNSlendhCZ
AOqXlLJ379CKpadIaVo/mlnpGiVDSnmhiNBrAAABAElEQVTR4pm9e4cyegMD NSSIyARQv6zf
LTEMs2bCUgghhMyPj+fHx4Tjp2qRCCITQL0zTaOWIlNKaRoFo1CBX+useURm 3dE0LcFrNs7S
vCWXvq14JcRYK9ndEkN6FSi25PDlS3k22bUSZJqGECLZ1GxubhsdHU6wQHVS SlMapklkJo+h
DJLUPXNJgiWUXpoi56mbOj+NUwPNV29CGksmq4zblYr/mpvbmpvb1BZ2F6u8 YoL/kDB6mdWr
f//WSleh7tTSPZOR6qqxUWRR9/4o7jrXYkePDpVnn8vjyrCtekNkpsvuKdr5 55oTtED//q3d
M5f4LuPsfTrXUo9Y+4935zlV+6E9O/tmOQAAAQBJREFU7fwb3/fsa8h0+Bbt hV0TvlsMr7Pv
nKJa7W1dUMNdTfCtZ0h7nY11le+793w3FLQnxYk707tAyEZ9n/JtfvhL751Q 3KVB+83bFtez
SZkIzKhiW1s7R0YGhRAtLR3WhDXHnt/a2mktaS/mfOha2Fmga8XSm0NipoTI TJEzxqxpb7B5
M8+1gLcQ37WK4j3YOT9evtPqV5u8R//w652RdQua9h6Uw4/FIctHVsO1sPoV 3Mg4Caln+MOQ
+kfOj/xbJ/wdEo/K6xX5KnunE6HeRnsZe6K1tXN4+LCUsq2ta3j4sPNZ+6G1 jO+GXCvaS5bY
HDIzJURmhSV1wbJsZ3ET/ByqRH3Go8YAAAEASURBVFf46qku713dlV5Fra7e xorfC6PCfuES
v5ss9rOlkY7/VZb8cGJ4+JB3pt/DiU0MDx9qa+saHj7U1jbNXretrStgrXi4 lpkWIrOSXD3I
ylZmcgnvq/kq5cjuPeGZUqp5N1Q/Il/T9HaIymva3j5dCNHWNs162NY27ciR AeHpMnqL9d2E
66FVlG8hMdDLTA93zNaIitxeG5uzd5J4T8XJt7axm+BbSbu0BPtAk+Jgl+oL Fy7x7qaU0f+E
EENDA/Y/ay3nuq5yvE/Zc4aGBtrbpw8NDXiXbG+f7poImVapM5JFLzNhzlt1 rIuX9kNx/KYe
3wXsmfbtP645IrWzr/bdGdZi9uw9AAABAElEQVRfpoo3XARdW3Ld6+GaE+8I 6y0hfCvFluDb
OudTRa2r/qy9raCreq6iitoPipEWvt+8ZQYtE/4eCG9a0Fq+78zwasSleGLW 97zrxMyhof6O
jun2tGd57yaCVvQ9zRs0HVRPTsymgshMkjfSIueELOCd8D4MWiaE73mkoJNL vkf8ojahMiek
Gr5PlbiVkGeDNlfitoIeenMlckPx9oNv9byN9eaidxnfv5PCN5fUnMqemB0c POhcwHronWkX
6HzKu3DIit4FQlYMaI7JidmUEJlJ8nYZK1UTVLM0e0txVFt9yk/K6D5ZZ2eP d+bg4IF0alQa
KaVpSmH9gMmkH52jqhCZS4NoiAAAAQBJREFUSaqxjAw/gJbnz/+KSLs5kR3H lDZU4mLha6m/
W6pQIZ+XQoqJePHPmP6DH/itWHWD0kkhTaOQH88V8nkhhEZkJorIBFC/NKH1 dDW/uWPPolmt
pjQ1oaX5VZZykFKaplHI53s/GOzpas7oWZGvdJ1qCJFZ+3x/VheAECKj69dc vPDBpzfeeMmC
8xd2Ra9Q9aSQQsodfcOPrN9+3YpTM3pDpWtUU4jMGnfHp+ZXugpA9co2NNx7 y/KHfrz5r5/6
Te/eoUpXJzE9Xc1/sHLx/WuvyGT0StelphCZAOpXNtuY0Ru+csMlX/3sZZqW 0dK/9pfRG9Mr
3DTG7e1ompBSHhsdCMYtZMgAAAEASURBVFsBRSIyAdQvKU2jkDMKuUpXBJMD o/8AAKCEyAQA
QAmRCQCAEiITAAAlRCYAAEqITAAAlBCZAAAoITIBAFBCZAIAoITIBABACZEJ AIASIhMAACVE
JgAASohMAACUEJkAACghMgEAUEJkAgCghMgEAEAJkQkAgBIiEwAAJUQmAABK iEwAAJQQmQAA
KCEyAQBQQmQCAKCEyAQAQAmRCQCAEiITAAAlRCYAAEqITAAAlBCZAAAoITIB AFBCZAIAoITI
BABACZEJAIASIhMAACVEJgAASohMAACUEJkAACjJhj999xMvlKcek82i0ov4 9Zv9r7ze+/b2
9+05p8ztOWPxvN8bzjglAAABAElEQVRbtbD0wgFFhmnkx3KGWZBSlmeLhfFc eoVnG5usCU3T
NE3LaHrDlCY9ozuXqcMm++LwHkNYZN7xqfllq8fkcv8jJa2+8c3+p5//1fw5 s1YuX/rFz13X
PHXiHb/13T2//I/Na7/+9FWXnX/1qgRSGYiUH8tlMpnv/GznMxt6e/cOVbo6 ienpal79sYX3
fPY8aRjixPyowyb74ggfQ0QvE4l7av3bb23b8+Xbrv/IwpMNw5BSvv/BASHE rBldi+bNXLzg
yk9/8r88+sOf3v/Y7rtuu7TSlUXtM6Xxnee3P/vzd5/67l9Vui4Ju/HWex9u m/r5a89yzbea
3Ns3/r27blq594cTqQAAAQBJREFUrHZO6rzz3v67n3jh4X/e4m0ykkJkltVT 69/etbv/vrtu
aWzQ+w8N/fylTVvf3WM/u2TRnCtXnd/Z3vKXd9zw3X9cf/9jL5KaKINnNvQ+ ct+XDw0cq3RF
Evbt+774p//zm1+6/lwpTddTz2zo/e6dN65YuqBs52bL4PT5M25f/dFbH1jn 22Qkgsgsn3//
Td9b2/bcd9ctDdnMocHhv/v7fxkbG3cu8MY7O7ft3HPrTVfO7pl2682f+Nb3 n3vi2ddu+fR5
laow6oGUsnfvkCmlENrHT28UokYi5BfvjAtN6907lNEbjMIJlxKtJq9YeoqU ppSiZpospbxo
8UzfJiMpRDjZ/ZMAAAEASURBVGb5PPfzjV++7frGBl1K+ez6Xx0aHBZCnLl4 3qrl50xpatiw
8a1XNveOjuWe/7f//OPrf1cIsXbNVZ//+iO7D5wzr4eXCWnRNE0IYRhS06Rp GpWuTlKkKYUw
pTjeQKfjTTZrJiyFEELI/Ph4fnxM+DUZSeFYXCavbT08/+SZixeclM/nhRCb Nu8QQnS0NX/q
sgtnzegSQtx0zapfvbpFCHFwYGhk9Fh7a3NDVv/Exy94+dVt8z55ZmUrj5pn GFLTRM1EppSy
YJjhuWGaRi1FppTSNApGoVDpitQ4IrNMfvP2rhXLzykUJu5r/9bdn3tn+/uN DXpHW7M15/19
/YVCQQizhoT1AAABAElEQVRhGKZhmFLKQqFwyYVnfe2BJ24gMpEyw5RC1FRk GoYQoZl5vLHV
lZrNzW2jo8MxVpRSmtIwTSIzXURmmbyz/f2bV19udTGFEJoQZy6ea00bhrF9 195Hn1xvmKYQ
4ozT5jY1Zg3DEEJ0dbQ0T53y5ruDZy/qrFTNUQ8KhilkWmfzmpvbrYnR0SP2 HN/p5MhCIfLG
Hun4Pw67XcLRtCTEq5I8/g8pIjLL5Ohorqu9ZWRkxPvUxte3//C5l6zpMxfP u3DpaUKa4+Pj
QohMJtM9raOc9UR9KhhSaiKNu0dbWjqOHp347mNzc7s9bZ1csZ5N/LZVKWXB jCxTlnLvj7Nd
dlmJNDeHnAAAAQBJREFUiFeUPC6pasAXkVk+pmkWPFcaDg2O/OhnL1vv8ytX nnvx+R9pa2my
FzMMI5XDGHCiQsGUmpAy+vvvRWlt7RwZGbSP4yMjgy0tHSMjg0IIKaXr2QRN RGZowROBGWvr
QTVvbZ04G2S10X5ozwlZxl6gtMiMsSqKEBaZdTislHKTpxe79ZbmpkODI41Z 96C+7+7uGz2W
E0J8/OJzVi4/q+X4SEATdc5mDx460tHWWuzmgKLkjfj5Ec5bpjWntbVzePhw SscWKWUhH3GW
spTIDFpxePiwNWG1zjunra3LniOldD60V6GXWc3CIrMOh5VSbPJfXL622I2e Mrdn+869S0+f
59w0Z3AAAAEASURBVHpPHxqcOFU7d/b0tpaprrUGjxztPzTEl0yQtoJhapqW zpUwb5ky+KnE
NlowIs/Mlngt02fFtrZpoeX7bLGtrSuhKnEtsxzCjsV1OKyUYpP/+z3vFrvR C5aeuunN3ovO
XZzLndCTvvryCy+9+BzDMHRdz2RO6IPquv7r17dcuIzBZpG6giGEMKVM/qeN gnqZR44MtLVN
O3JkIPEtiokvmcjwM7OJ9zLb26fbzWlvn+4t33eLzj1QSpXoZZZHxCfkmQ29 t6++2BpWqmZY
w0o9vWF7Vm+I1+QYO3r52TO27Nj97m/7dF3XHPb2DXzjm//04GPPjRwd005k Su3nL756xYoq
8FpfAAABAElEQVRlMTYHFKVQMAt5KaVI9t/Q0EB7+3T7YXv79KGhAesD5H02 2X+FgmkUwiMz
sXZZ/5xlWtPhc1wPrQJLrBiJmbawXqasv2GlUm3yJy87/4fPvfi1P/+MszP5 xpb3Rsdyo2O5
X7y8ec21H44o29TU9PhTL/TMaJ8zI+E7MgAvw0jrtN7QUH9Hx3R72nVW1np2 aKg/6c3KghHZ
nJJOzDrbZT10zfE9MevaGwE7hxOz1SssMutwWKlUm3zZhXPe2fb+P/74xZtX X6prE6df5p00
QwgxpanxjNPm2vVpamp6edOWTZu3f/Orv594NQAvw5Qi7hmUSIODB60Ju/zB wYO+00mRQdY4
/wAAAQBJREFU0jRMmeqJWeFol12Oa45vM117w/swXpWkNGOfA4O66PtK6nBY qfSafMeaj97/
2Iv3PvzUlz63uqOt2TCMc89a9Oh9f3b06FhTU6Omabqu5wvm99f9K3mJcrKG 0aidT7qUhmmK
jPU3qP8QDVLWVp9MSmmaUlivI2PMpkUxMkVS763Yw0GFF6herFQYVirVkbTu uu3Sn7y04wvf
eHTF8rM/seqCuSd1G4YxdcqUTCZzaHBkw8bX1r/46oJ5M8hLlJN1oM3n85oQ k/2AK4U0jYIp
9Ilh2QOaU8jnrW5ozTQ5P54r5PMiuMkoncq3F4o4va42glR0USFjaFmbOPHZ oi4AqMNvKiUA
AAEASURBVJzx9y/Qbt1f3L1DbVv+rl516tIzTnnjnff+5ns/Ojhw5IzT5gkh 3ttzQNPkhcsW
feX2a2Z18lt3KBNNaD1dzdb0ExtK/N5F9Zi4A6CnqzmjZ0X+hOesJr+5Y8+i Wa2mNDWhTfaf
/pBSmqZRyOd7Pxj0bTKSohSZijfCKI4gpXi2PXwx57NFXZNQu+s1sMlWA7/x 4EHvU0WZ15Od
13Pq0jNOGRq2h9BbcnwgWfIS5ZPR9WsuXvjED/7P4mX/ZU7D2ZWuTpJ+8coj 1604NeO5Md5q
8oNPb7zxkgXnL+zyXXdykUIKKXf0DT+yfrtvk5GU6MgsNpBcc4KGg/LOd81p aemKGYm9AAAB
AElEQVRwPmsvYz/rKrDIyIxuhe9CyV5dn9eTFT2Mt45KyjY03HvL8oembV73 iw0/2fuTSlcn
MT1dzX+wcvH9a6/IZNz3nE80+ceb//qp39TYIC1BTUZSkozM4eHDduxZIz8F DQflne8aR8ou
wbtde45rIsFeZtkiE6i4bLYxozd85YZLvvrZyzQto6V/ISyjN6ZXuGmM29vR NCGlPDbqHi2h
DpuMpCR8LXN4+JA10dbWZU0HDQelMExU0BZlwETq1zKL2QowOUhpGoWc6wvK ta0Om4ykJHxi
1rti0HBQkcNEebfY3j5dOEZxtEfbopcJACgDlcj88P+iuFbs6Jg+NDQQOd+1 QrdqTAAAAQBJ
REFUuou1pL2iaxgqxVpFDisVUiCJCQB1K8kTsx0d3fa0NfhT0HBQ3vlB40h5 RtLyPXlbvhOz
Vq1K/JIJAGAySvLErHf4KBE8HJTvGFquJV3bdQ0lZT10/h9ZQyGUhpUKarJd w//1rdq5yw4A
oEgxMpXSqLOzxzVncPBAnEqlSmFYqaAm2w2klwkAdSg6MtWHleo/+IFn3bBx 6cpPcVipoCbb
Dbz/26NpVxUAUG1Cf8mk/oaVUm5yit+yAgBUp7DIrMNhpZSbPDPVegIAqlBY ZNbhsFKKTf6L
y9emXEcAQNUJjcz6G1ZKscl/9UDiPyIPAKh2YZFZh8NKKTZ5X9/R2bM6tGRA lacAAAEASURB
VKmZB55sEEKK8fDFAaA6aJpZZXdlTi4qQxnAR25kSIxELwYAqBlEZky7dx2u dBUAAGVFZMbx
0D0tQrRUuhYAgLLKVLoCAABMDmG9zJde/GXZ6gEAQDVYdenKoKfCIvPTn7k1 hcoAAFC9Bg5s
C3oqLDJDVgMAoN5wLRMAACVEJgAASohMAACUEJkAACghMgEAUEJkAgCghMgE AEAJkQkAgBIi
EwAAJZWPzO41RqWrAABAtJiR2b3GsP+FLxb7WQAAqkr838vsf1K3JrrXGPZ0 vBIAAKh+CfzE
dP+Tup2adsfRGaj2Q9ezrqz1rgsAQPWIjsw9+/qEkPbDObNnBy3pjEDJ2UHT AAABAElEQVR7
2pl/IR1T367qnn37IqsHAEDJNE2TJ88KDDhLRGTu2bcvk2k4aWa34jZLvLTp Ss2QeAYAIEH7
DvTv2bcvPHfCInNvX18mo6vnpQg9p+rqg/qu6DyLCwBA2czu6d53YGBvX9/J s2YFLRN2x6yU
4qSZPZGb8T2nGu9uWMISAFAps3umOy9EeoWfmA1b03u3jnUfkHOmPaf/Sd35 rEppAACUmQzL
vbh3zAYFm3e+7+0/zofeu4QAAKhClR/9BwCASYHIBABACZEJAIASIhMAACVE JgAASohMAACU
EJkAACghMgEAUJLAj38BAFBVMtm2rmknqS8/MPCBMIYjFyMyAQA1avzHhgAA AQBJREFU6MiR
/sbGKYVCXgghpbT/F0JIadoPDSM/Pp7L5Y62NTdGlsmJWQBADTKMgmma8gTm 1q3vSGnPNK3s
FELkcsdUyiQyAQA1KJc7ls/nTNMwTaNQGC8Uxrdt2yqE2LZtq/XQMApWrAoh RkaGVMrkxCwA
oAbl8zldz2YyH/YMFy5cYE2YpiGOn5g1TdMw8oplEpkAgBrU2dkzPHxI07Sg BY5HptHePv3w
4f0qZRKZAIAatHdv79GjR6yLlPY1S69MJtvcvG/OnMXcMQsAqFNzTjpVE0Jk Mpolo2c0TWh6
JqMJ8eEz1sKDhw8EhqoDkQkAqEGt7dPVFzal0mJEJgCgBvG9TNNz4IMAAAEA SURBVAAAlPh+
L/P4v5jfy6SXCQCoQbncsUxGt6YNoyCE2LFjh/XQ/raJON7XHBkZ6u7qiCyT XiYAoAbl87nx
8TFr1AKrQ2kl5cKFC6zxDayhDAqFPN/LBADUNd/vZc6de1I+n7Om+V4mAABC 8L1MAABUmIXh
GdM6Z0zrVF1BIS8F1zIBAFBEZAIAoITIBABACZEJAIASIhMAACVEJgAASohM AACUEJkAACgh
MgEAUEJkAgCghMgEAEAJkQkAgBIiEwAAJUQmAABKiEwAAJQQmQAAKAmPTK1M tQAAoApoobkX
FpmaJj7YfyDh6gAAUJX2HRgI7yuGRebJs2aZpvHB/v6kawVFIsRmAAABAElE QVQAQHXZd6Df
MMZPnjUrZJlseBFzZs/es69vz759iVYMAICqommanDN7dvhCEZEphJgzOyxy AQCoE9wxCwCA
EiITAAAlRCYAAEqITAAAlBCZAAAoCbtjdtnadSpFvP7oDQlVBsAJ+AwCVSXi SyYvP7TGmtC0
jEXX9UxGt/7PZDKn/+Hfpl9JoH699OBnrInMhx/BrK7r2WzW+hie+UcPVbaG QP1QOjEblJeZ
TMTq3TOXJFHJaEVtKL2Fa0D3zCUJNjmoKO/8RDaabOWrSlBeRn4GfVV8L1W8 AonUoTytsLai
sq1q2Ks1L/rz5puXy358njXPtbB1zKrCI1fi9al47qZU5dCunQAAAQBJREFU Zv/+rf37tyZS
VOmFFLtFu/LV9vYrUUheuj6DroarH21dYq8YWWZ6y1chxSbUQEvrR8SJ2aC8 FEJ4/8K1jlkp
VhYOVb6rq7x6k0h4Xqr0MmO8Frx8iWA31p6IyLQ+rBe/sOKVq37tzEvrKS38 V1KEEI4/oOx3
j2uOHbTeiaBCnH+UOZd0rhhUiKuEoFqpN0SxQOfCIbX13Tm+z4as4t05Qa0L b1TQYuo1j9yQ
SpVCqhFSeXs65A2mvrdF5YTnpUpkelvkfMqa8L4K3vdtyP53vW3CX1z1z6D6 u1HlVfN9KnL1
kDmufeWadhZuz1E5PoS/8SLrg1RFR6au60KIC366/BN+fqwAAAEASURBVPVr XrPzcusNWzRN
c31cnW8O++V0vZnCU82X7yrFFiJOfP/FqJViHbwFerdeVEtD/pIIWiWyMirr hre92GWK2nu+
5YQ89K28yg5X3NuVPX0SnpfeyAw6gLpa5J2j/tK7drhrp6m8SXxLjv1uVHzV It9axX6a1LOq
qONDSBPCDzVkZxlERKb1EbWmvXmpae6Pa+yjTOSHTYVdQoxyIt9t4Qv4/v0e Xgff2nrLCYkN
dSXuWFetFGseUkK8JUtphe8bI3Jvx9tWssLz0huZRTWhqDYW9SLGeKUUy4/9 qgU9Fb56ZK3i
HXZCFk7qo4Q0RPYydV3XffuXmqZ0YnayCH+vR2b5Sg+qAAABAElEQVSD79+M zpMtpVejxDJj
rGhRycXwZYr6Qzi8gxK7FV7FvqaVEp6X3j9bi5LUm9O7WLGvlOKbJParplh+ eK8usPZFCtlF
k+VtWbciPm/2B/Wt6zYLT14mEpnOv84S7GjGLqHED4Zz9chqhNRW5S/ioiT7 SSt9P0dK6nhR
+hussn/Xh+dlUn+2Jt7drPiRPcEPcqR476sSdxHdzYqI7mXaN+xF5qVKWvT7 Xe8MF2OVkEKC
ro6Eb6L/xGv4rgK9q7sehm9dsRq+T6nsnKAFFHest+3FLuP7bLHNCdqlvpVX 2eHqda7s0T+p
vAx5D4uot73vmzxI5PstxkcsZDHFFhX7Nva+M3MfawAAAQBJREFUzdTLiRRy fCi2gYnUB+q0
m9dumj2rQ2vVhJB3rik4n1u2dt2Wf/ii/Vn1zcu5195TVYN1pd31Acpp2dp1 b//gC+F5WW2f
wTrEYae2PfB4Vmja2MDg7l2HI3qZjIeX4MUzIIaixsPj6heQqrDInIx/uiZ+ dOBwgwoq9jPI
27Ui2O31gx//AgBACZEJAIASIhMAACVEJgAASohMAACUEJkAACghMgEAUEJk AgCghMgEAEBJ
2Og/y9auUyliMg4SBABAsSLGmH35oTXWhKYd/0ETXbd+RNMaJ5pBaIEqVLaB wrtnruvfX9If
zaWXoL4VlW2Vpz6YpJROzAblpfcX4ScdftgrkVcAAAEASURBVDcHk5TzrRs0 rV5CjNXLpnum
0ukuxcWUN7rE+pdgmagB0Znnm5fLfnyeNc+7vP1WS/zdZhVYzW/iaq4boKIK RxivSJ/P+ulK
fo0SLhEnZoPyUhz/9WnX8qmeDqrCDzNQtbw/thw0x/nJsj/Cwb/1ve74/Buc M52nPb3LhMxx
luCddhZuzwkq1noYVIfwViTbSUWtiohMKy8vfmHFK1f92pmX1lOuH4X3zUtr ZtDn0LmKvaS9
ruezekIhQQXaD12Hg+BDQESVwhd2lRlSN+eckPrbuyu8JqhzrveJ9z3jffOE zHEJeb+FB5tr
vj3tmuNaRrnJgYW4Fgipp28Ng+rD5w600qceAAABAElEQVQu0ZGp67oQ4oKf Ln/9mtfsvNx6
wxZN0xSvZTqjTiUDIpfxXcB1FHBttJTNeRsSsm5I3VxzgurPpxQpKeocY9D7 MCjhXPGpuJZz
dfU7dJzFBi0cvkWVnOaTCK+IyLR6lta0Ny81zT8yXT2nVN92Rd3soFIT3z/Y 42093lUQZy9B
vSZAOO9fbCG8p3OOr6jUOwzv1RVd9dCtOE/Gqm+Re2IRT2QvU9d13bd/qWnu E7M21ynHVClm
SdAhoBSRxyByDqly/jmVxp9Wpd/8UlSXsdgupnOt4qs2IWSLfH7hpdTLzGQy b123+awfnePK
S1dkVrY/pLJpxUNA4g2JXRpdTCTFmQme5AAAAQBJREFU++b3Xu+3BV34V8kn 5zL2hUzXWiXm
3PFK+m+lf/8N4eWr1FBwYhZ+tJvXbpo9q0Nr1YSQd64pOJ9btnbd2z/4Qub4 PbPW/T6uvJx7
7T2u0X9cd7i43naRd8SUfvtP0LXMoDJ9Nxd8Icf/9h/XnBJv//FtNVDbGEMA 1emBx7NC08YG
BnfvOqx0x2xQXvoKukHG96HiHNd85wJB5bsmIst0UrlXSKXyIc8G/xVPXqJ6 pf1NjOr5pgfh
DV8RkVnUeHhcz4sUlJTApECQoM6FRWax460nEgPVkCXp1aHYkqthbwAALJN+ kFgAAMqDyAQA
QAmRCQCAEiITAAAlRCYAAEqITIoWHH4AAAEASURBVAAAlBCZAAAoITIBAFBC ZAIAoCRs9J9l
a5XGeyx2kCAAACajiDFmX3rwM9aEPT67rmd1Xc9ms9bvgp35Rw+lX0kAACpP 6cRsUF5mMhGr
l+dXppPaUPfMJWWrcLGKqph34aptFwBMItGRGZKXmYzuWthKnWrOniDWz2x5 fwWzqqRXMcWS
k61AgqWV/yWr2jcJgPSo/l6mb166epn8uGPa2L1B2DMAykAlMgPzMvLErPD7 hUjXHDtovRNB
hTj/wHcu6VxRvRBXxZzP9u/fGlI934YEPVtUcyIbqNgW79Yja6VY+aL2QGQ9 i325vS+093/F
cuyHrpqovOV8Kw+ghkVGZlhlNjcKAAABAElEQVReuiLTPu4Ix3HE99DmnBNZ Rd9VSikkskyh
dhz0luCb+t4aqjQnPPtjFBijVuGLFbUHgor1jeRSXu7wlyBojmutotYFUD8i IjM8L729zGKT
zOY9VMXg7Wd4NxGvZN9ivVezwp9VeSp29RJfMl5pkXkWr1jvVoJe6KRijEuV ALwiIzMsLzVt
0oyE4DrdWnqB3l6U7xZjrJh4TVRqlfZ2i9p6NfTeqqEOAKpNROaF56WmaaXX wNlXSLCjGfRs
+atXnf2Vytaq9O5m6W8VRdX58gGoiOhepnpeBt204uR7vTNcjFW8XCWEl+m9 GSS8VkXV2XdF
9ft3vIUrFqhYK1eBiot5HBbk1wAAAQBJREFUeZ/1Fuu7nxN5uUssR2VdlTcJ gBqj3bx20+xZ
HVqrJoS8c03B+dyyteve/sEXwvNy7rX3VNWAeeXpeSRL5QafSa3GmgOgrjzw eFZo2tjA4O5d
hyN6mYyHh9gS6SwCQPUIi8yq6j4qmoxHZ99TrxWpSbJqoxUAYJs0t7wCAFBZ RCYAAEqITAAA
lBCZAAAoITIBAFBCZAIAoITIBABACZEJAIASIhMAACVho/8sW7tOpYjJOEgQ AADFihhj9uWH
1lgTmjYxJrv12yb2L5yc/od/m34lAQCoPKUTs0F5mclU73lda0zwEn/ssDp/ K7E6a2Upcbd3
z1yivm7F90OMChTVQJBn39sAAAEASURBVADVJjrzfPNy2Y/Ps+Z5l7cOCukd +6rhiBOvDomk
eFHbSmOVVEu2foYz3lZKl/ZGK95AACWKODEblJdCCKuj6VqeX0YMUc49E2Nb VfXCVaQyVbUH
AFShiMi08vLiF1a8ctWvnXlpPWX/0LQlKC9dv5vo/PvaXt75A/fe31n0LcH7 s8yutXxr4iyz
f//WkMqEFx5eYd8V7a0X1VhvUSFt8f4f3jrnJlRWUam/r6J2l3r9vTvEtZND Gq6yAyPL8a1/
SEu9+8G1Le+Eq8DwugFIVXRk6rouhLjgp8tfv+Y1Oy+33rBF0zSVa5neA5M4 8QjimuN91pvE
vgcIb5mKQjbne8hlYh2JAAABAElEQVQLaoJ300E1CVk35M8OxUN20L4KaV14 9cL3v+JuV9ld
wu+VLar+3sgpquEllhPy6oe/z0N4SwipW2RpAEoUEZlWz9Ka9ualpqVy+08p VwpTEl54URkW
uW4ph7+UjpshVaqqa3KuxCp/OaW8dr5/oHi3nlQbAcQQ2cvUdV337V9qmvvE bCKK6g2UuFZS
hQcdJUNOIwetq7JKmYVUKdXdXqKk9p56OYm/drHfeABSEtFNtL9P8tZ1m4Un L12R6br4VIdK
Oa4FXWKsElVYJUVJvScVy4mxo5ydy5CT86XXDUCJonuZmeP3zIbnpcV7y4Zz TkhPy/7b3Ju7
rhKcCwdtN4jvxILUPwAAAQBJREFUYq7qhVcgvMLeTph3fvi6QUWp1EpFjLWC 9o/vixW+UcX3
g0pR6oupv6zxyrGFLOl7jTayPxpewxL3JIAYtJvXbpo9q0Nr1YSQd64pOJ9b tnbdln/4opWX
1v2x3ryce+09k3rAvHq+b6Ju2163DQcQwwOPZ4WmjQ0M7t51OKKXWdR4eFxu mRTomgBAPGGR
WWz3cTIegidjnUtUh012YQ8AiKd6B4kFAKCqEJkAACghMgEAUEJkAgCghMgE AEAJkQkAgBIi
EwAAJUQmAABKiEwAAJQQmQAAKCEyAQBQQmQCAKCEyAQAQAmRCQCAEiITAAAl RCYAAEqITAAA
lBCZAAAoIfzhIVgAAAEASURBVDIBAFBCZAIAoITIBABACZEJAIASIhMAACVE JgAASohMAACU
EJkAACghMgEAUEJkAgCghMgEAEAJkQkAgBIiEwAAJUQmAABKiEwAAJQQmQAA KCEyAQBQQmQC
AKCEyAQAQAmRCQCAEiITAAAlRCYAAEqITAAAlBCZAAAoITIBAFBCZAIAoITI BABACZEJAIAS
IhMAACVEJgAASohMAACUEJkAACghMgEAUEJkAgCghMgEAEAJkQkAgBIiEwAA JUQmAABKiEwA
AJQQmQAAKMk6H7z04i8rVQ8AAKrSZfbUCZH56c/cWvaqAABQvTbe9649fUJk DhzYVvbKAABQ
zT4MSq45ezVDAAABAElEQVRlAgCghMgEAEAJkQkAgBIiEwAAJUQmAABKiEwA AJQQmQAAKCEy
AQBQQmQCAKCEyAQAQEk2ehE1v36z/5XXe9/e/r4955S5PWcsnvd7qxYmtQkA QPmNF8ZHh44U
CjnTlOXZYu7YSHqFN01ttSYyGU3L6Hom29zR3phtVFk3gcjc+Gb/08//av6c WSuXL/3i565r
ntpkzd/67p5f/sfmtV9/+qrLzr961aLSNwRMRu/v6RsfH690LRIlZTabnT// ZHtGPbTRpb//
8PDIUdM0y1mptLW2NM+c2e2dPzp0pLGx6X//y44XXt29s+9I+SuWku7OqZef O/eb/+13zPFx
oRaZ2f7AyAAAAQBJREFU2s1rN82e1aG1akLIO9cUit3kU+vffmvbnj/9w6s/ svBkwzCklH0H
DwshZs3oEkLoun5ocOTRH/50dHT0rtsuLbZwYLJ7f0/f1KnN06Z3t7S0Vrou icnlxg7s7zt2
bHTunFmiPtro0t9/WGh6TTZZSKO7u8v11MDBvr99/r2Bo5k/u/ZjK5fVzonD d97bf/cTL0xv
kf9jzbkhvcwHHs8KTRsbGNy963BJvcyn1r+9a3f/fXfd0tig9x8a+vlLm7a+ u8d+dsmiOVeu
Or+zveUv77jhu/+4/v7HXiQ1UW/Gx8dPnjOvlg6sQoimpinTpnfv2rnDelgP bXQZHjk6/5SF
NX21820AAAEASURBVNnk37630xuZQogXXt39+NduWrF0gZRlOjdbBqfPn3H7 6o/+yb3/994/
+ZhpKvUY40fmv/+m761te+6765aGbObQ4PDf/f2/jI2dcGbmjXd2btu559ab rpzdM+3Wmz/x
re8/98Szr93y6fNibxGYjGrswGpxNaoe2uhkmmatNtn3VLM0jZ19R1YsPUVK U0ohRI2kppTy
osUzd/YdyTZMGc8pXT2NH5nP/Xzjl2+7vrFBl1I+u/5XhwaHhRBnLp63avk5 U5oaNmx865XN
vaNjuef/7T//+PrfFUKsXXPV57/+yO4D58zrSeyeIwBA2rSMLoQwDLNmwlII IYTMj4/nx8cR
n2UvAAABAElEQVSEEJqm+uWRmOn12tbD80+euXjBSfl8XgixafMOIURHW/On LrvQuop50zWr
fvXqFiHEwYGhkdFj7a3NDVn9Ex+/4OVXt8375JnxNgoAqBTTNGopMqWUplEw CgUhhNA0xbVi
fi/zN2/vWrH8nEKhIKWUUn7r7s/detOVa669tKOt2Zqz+4ODhUKhUCgYhmkY ppSyUChccuFZ
r7zhf20AQBn86Nl1la4CklH+l9I0DdM0TdOoqn9TpjTHX10aipcwbTF7me9s f//m1ZdbXUwh
hCbEmYvnWtOGYWzftffRJ9cbpimEOOO0uU2NWcMwhBBdHS3NU6e8+e7g2Ys6 420XgM15MZLT
mgAAAQBJREFU0Lzu0zdUsCaxWU2wK/+jZ9cpNkR9yarlyrzrPn1DUKOqprHS 8X8czc3t9vTo
aIJfVolXJXn8XxFiRubR0VxXe8vIiM/10o2vb//hcy9Z02cunnfh0tOENK3v bGUyme5pHfG2
CMB76IwRNrVtcu2HoFczfLHKkaXc+9PS0nH06JCrrETEK0oeV9Ra8e/EMU2z UHB3aQ8Njvzo
Zy9bdbhy5bkXn/+RtpYmezHDMEQN3aAMlI2rNxa5pDgxTV1zRDVFi2/vylVn 5wL2tO8+sUrz
zp8UrKZ5Tx64muyc73yYtonAjHUMb23tHBkZ9K7b2jpxxnFkZND50J4Tsoy9 QGmRWXZKBVEA
AAEASURBVNxaMSOzpbnp0OBIY9Z9KfTd3X2jx3JCiI9ffM7K5We1HB8JaGJj 2ezBQ0c62mrw
5mwgJeEB4D1ouqLFNxqrJy99eQPSbojzqfA+2aQIzqBT674nDyp+jqGUyAxa cXj4sDXR2tpp
TbvmtLV12XOklM6H9iqToJd5ytye7Tv3Lj19nmt7hwYnTtXOnT29rWWqa63B I0f7Dw3xJRNA
UeShMKjvVUqZ5eeNdm8rQi71BZUpqrKxTsXWrdLNKfFaps+KbW3TQsv32WJb W1f4AsXUp1zX
Mi9YeuqmN3svOndxLpdzzr/68gsvvfgcwzB0Xc9kTuiD6rr+69e3XLiMwWYB VcWFkEzFAAAB
AElEQVSeZnR1SkLKrOYgEUn0DidFL7MoFe89J97LbG+ffuTIgD3tLd93i/Yq JVYpXi8z5pdM
lp89Y8uO3e/+tk/Xdc1hb9/AN775Tw8+9tzI0THtRKbUfv7iq1esWBZvi0B9 sk9LJvilAtcF
s2oQVCV7pvc6XxBrX1n7LeFaVoEKNkrK+P+Ghgba26e7ZjrLtKbD57geWgWW WLEyXcsUQnzy
svN/+NyLX/vzzzg7k29seW90LDc6lvvFy5vXXPvhiLJNTU2PP/VCz4z2OTP0 2FsE6lbQaUbX
tUxvqDjnuK6WVW1f01tnu6p2tYP631XbqNKV+WYfPyWdmB0a6u/omO586Jrj 0e5cfgAAAQBJ
REFUe2LWuYxrlaGh/vKfmC3pl0wefvI/pk/rvHn1pbo20TV+/e2d3/6Hn05p avyv1338d845
zVqsqanp5U1bnnz2/33zq79fVPnAZPfuzt1nnV2bZ1beevP1RQvnifpoo0u9 NXngYN9H1j4/
9NO7RKJfDqksKc1Cfnx8bOzkmx4b/tmXc8eGgpZM7JdM7ljz0fsfe/Heh5/6 0udWd7Q1G4Zx
7lmLHr3vz44eHWtqatQ0Tdf1fMH8/rp/3bR5O3kJJMv3HpmK1CQ23xOtk64V 8Uy6l0/Kovtk
VU1KaZpSWMPQqw6YV+rNq3fddulPXtrxhW88umL52Z9YdcHck7oNw5g6ZYFl 5PYAAAEASURB
VEomkzk0OLJh42vrX3x1wbwZ5CWQuCo/wqqogSbENunaXsjnpZBiIl5UM6Y6 SSFNo5AfzxXy
eSGEVrbIFEJcverUpWec8sY77/3N9350cODIGafNE0K8t+eApskLly36yu3X zOqsqR8uB4og
ZS431tQ0pdL1SFguN/bhjRP10Ea/Z2uzyX4yQuvunPrmjj2LZrWa0tSEpimP Y16dpJSmaRTy
+d4PBrs7p+rBvy/tksxXJOf1ZOf1nLr0jFOGhu0h9JYcH0iWvET9ymazB/b3 TZveXUs/r5jL
jR3Y35fNThw96qGNLq0tzbXa5NaWZu9T2YbGy5bNffDpjTdesuD8hT6ZsYuc AAABAElEQVQ/
QD3pSCGFlDv6hh9Zv/2qixboenkj0zKvJyt6GG8d+ND8+Se/v6dv187a+gEf KbPZ7Pz5J1uP
6qGNLjNndvf3H/7tezt9f5B58mptaZ45s9s7v6l56rfvWHHPD1/5xj+9trMv weHUK6y7c+rv
fXTRt7/0+5mM6lc5GIgHSNfcObMqXYXU1UMbXbq7u7q7a6G/pWLKlJZsQ/OD f3r139zRpGla
Mdf+YspkUswm+we/NJERmpBSjo7sV1yXyAQAhDFNYzw3PJ4brnRFKi/m6D8A ANQbIhMAACVE
JgAASohMAACUEJkAACghMgEAUEJkAgCghMgEAEAJkQkAgBIiEwAArkHZkAAA AEVJREFUJccH
zDM0oYsHnsyK8YpWBwCAqqJpZn5iWFrHGLPF/dAmAAD1JSuEyI0MiZHIJQEA qGtZIcTuXYcr
XQ0AAKrd/wcfh73PAKNwiAAAAABJRU5ErkJggg==
--------------000006060005070507060401--
Re: Unable to start client, Scout version 3.7.0.201102030625 [message #654005 is a reply to message #653453] Sat, 12 February 2011 13:55 Go to previous messageGo to next message
Arthur vD is currently offline Arthur vD
Member
The image for those using the forum and not NNTP:
http://wiki.eclipse.org/images/5/52/ScoutNightlyRepositoryConf20110211.png
Re: Unable to start client, Scout version 3.7.0.201102030625 [message #654029 is a reply to message #654005] Sun, 13 February 2011 04:39 Go to previous messageGo to next message
The nightly build of scout worked.
Thanks for the help.
Re: Unable to start client, Scout version 3.7.0.201102030625 [message #654036 is a reply to message #654005] Sun, 13 February 2011 07:10 Go to previous message
Thank you Arthur Wink
Previous Topic:failed to show the data.
Next Topic:Scout and Data Tools
Current Time: Fri May 24 20:30:44 EDT 2013
Powered by FUDForum. Page generated in 0.12068 seconds
