Home » Eclipse Projects » Eclipse 4 » Bug e 4.1 m5 application creation wizard
Bug e 4.1 m5 application creation wizard [message #653395] Wed, 09 February 2011 11:08 Go to next message
Holger Sachse is currently offline Holger Sachse
There is a small bug in the e4 application project wizard. If you create a project "testme" with an activator the packages "testme" and "testme.handler" are created and starting the project everything runs fine.
Doing the same without an activator the package for the handlers is named "handler" instead of "testme.handler". Also the package name in the generated handlers is named ".handler" and because of that they show syntax errors.
Holger Sachse
Re: Bug e 4.1 m5 application creation wizard [message #653399 is a reply to message #653395] Wed, 09 February 2011 11:16 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Can you please file a bug for this and cc me on it.
Tom
Am 09.02.11 17:08, schrieb Holger Sachse:
> syntax errors.
> Holger Sachse
Re: Bug e 4.1 m5 application creation wizard [message #653409 is a reply to message #653399] Wed, 09 February 2011 11:36 Go to previous message
Hi Tom,
done with Bug 336730, I hope component "runtime" is the right classification.
Holger Sachse
Previous Topic:Changes with e4 4.1 m5
Next Topic:Updating to 4.1 messed things up
Current Time: Mon May 20 02:51:21 EDT 2013
Powered by FUDForum. Page generated in 0.01823 seconds
