| Fedora 14 Web Page Editor - installation problem [message #653357] |
Wed, 09 February 2011 09:02  |
tomek Messages: 12 Registered: February 2011 |
Junior Member |
PL
Mam Fedore 14.
Chcę zainstalować "Web Page Editor".
Help->Install new software
Dodaję
http://download.eclipse.org/releases/galileo/
wybieram
Web, XML and Java EE development → Web Page Editor
i klikam next.
Ale dostaję odpowoedź - zobacz niżej Eclipse Output 1.
Tak samo dla:
http://download.eclipse.org/webtools/updates
Web Tools Platform (WTP) 3.1.2 -> Web Page Editor
Ale dostaję odpowoedź - zobacz niżej Eclipse Output 2.
Na Debianie nie miałem takich problemów.
Proszę o pomoc.
EN
I have Fedora 14.
I want to install "Web Page Editor".
I add
then select
and click next.
And I recieve message - see below Eclipse Output 1.
The same happens if I chose:
And I recieve message - see below Eclipse Output 2.
I have no such problem in Debian.
Please help.
Eclipse Output 1:
Cannot complete the install because of a conflicting dependency.
Software being installed: Web Page Editor (Optional) 2.2.2.v201001271707-43799oB5855B7A2242 (org.eclipse.jst.webpageeditor.feature.feature.group 2.2.2.v201001271707-43799oB5855B7A2242)
Software currently installed: Shared profile 1.0.0.1292415248356 (SharedProfile_PlatformProfile 1.0.0.1292415248356)
Only one of the following can be installed at once:
International Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu 4.2.1.v20100412)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090822 (com.ibm.icu 4.0.1.v20090822)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090415 (com.ibm.icu 4.0.1.v20090415)
Cannot satisfy dependency:
From: Shared profile 1.0.0.1292415248356 (SharedProfile_PlatformProfile 1.0.0.1292415248356)
To: com.ibm.icu
From: Java EMF Model Utilities 2.0.200.v200905140200 (org.eclipse.jem.util 2.0.200.v200905140200)
To: bundle com.ibm.icu [3.8.1.1,4.1.0)
From: Java EMF Model Utilities 2.0.201.v201001252130 (org.eclipse.jem.util 2.0.201.v201001252130)
From: JavaServer Faces Tools - Common UI 1.1.1.v20081209 (org.eclipse.jst.jsf.common.ui 1.1.1.v20081209)
To: bundle org.eclipse.wst.common.emf [1.1.103,2.0.0)
From: JavaServer Faces Tools - Pagedesigner UI 1.1.4.v20100203 (org.eclipse.jst.pagedesigner.jsf.ui 1.1.4.v20100203)
To: bundle org.eclipse.jst.jsf.common.ui [1.1.0,2.0.0)
From: Web Page Editor (Optional) 2.2.2.v201001271707-43799oB5855B7A2242 (org.eclipse.jst.webpageeditor.feature.feature.group 2.2.2.v201001271707-43799oB5855B7A2242)
To: org.eclipse.jst.pagedesigner.jsf.ui
From: EMF Utilities 1.1.301.v200908181930 (org.eclipse.wst.common.emf 1.1.301.v200908181930)
To: bundle org.eclipse.jem.util [2.0.100,3.0.0)
Eclipse Output 2:
To: com.ibm.icu
To: org.eclipse.jst.pagedesigner.jsf.ui [1.1.4.v20100203]
| Re: Fedora 14 Web Page Editor - installation problem [message #653635 is a reply to message #653466] |
Thu, 10 February 2011 08:44   |
Junior Member |
PL
OK.
Odinstalowałem eclipsa yumem.
Uruchomiłem tego pobranego z http://www.eclipse.org/downloads/
i mogę sobie zainstalować Web Page Editor.
Zauważyłem różnicę: w wersju z yuma w źródłach oprogramowanie jest release/galileo a w tym pobranym release/helios.
Wniosek jest taki - nie instalować eclipsa z repo - tylko pobrać.
Powiedzcie mi jeszcze gdzie najlepiej mam umieścić rozpakowany katalog z eclipsem, czy dodać jakieś zmienne do shella ??
EN
OK.
I uninstalled eclipse with yum.
I run version downloaded from http://www.eclipse.org/downloads/ and I can snagless install Web Page Editor.
I notice difference: in version installed with yum in software sources I have release/galileo but in downloaded version I have release/helios.
My conclusion is - do not install eclipse with yum - but download it.
I would like to also know where should I put eclipse catalog best, should I add some shell variables?
[Updated on: Thu, 10 February 2011 08:53] Report message to a moderator
FUDForum. Page generated in 0.04035 seconds
