Home » Modeling » BPEL Designer » BPEL Installation(Installing BPEL Plug-in Eclipse)
BPEL Installation [message #653241] Tue, 08 February 2011 19:00 Go to next message
No real name is currently offline No real name
Shocked
Hi All
I am new starter in BPEL.
I am following tutorial found in the following link:
http://people.apache.org/~vanto/HelloWorld-BPELDesignerAndOD E.pdf?bcsi_scan_A4C9E8056B19D97F=0&bcsi_scan_filename=He lloWorld-BPELDesignerAndODE.pdf
few Questions:
a) While using Eclipse version-3.50 - Galileo: I was unable to download BPEL Plug-in, completly. Giving following errors: link used : http://download.eclipse.org/technology/bpel/update-site/
Cannot complete the install because one or more required items could not be found.
Software being installed: BPEL Visual Designer 0.5.0.v20101202-1444-H38-CI (org.eclipse.bpel.feature.feature.group 0.5.0.v20101202-1444-H38-CI)
Missing requirement: BPEL Visual Designer 0.5.0.v20101202-1444-H38-CI (org.eclipse.bpel.feature.feature.group 0.5.0.v20101202-1444-H38-CI) requires 'org.eclipse.emf.compare.ui 0.0.0' but it could not be found
b) As above Eclipse version did not worked, so I started going to Eclipse Europa version 3.3 to download as per doc, but I was unable to download Eclipse Europa 3.3, looks like some issue with it.
Could any one please direct me the right document or provide me the right Eclipse version to be used for BPEL.
Heaps Thanks in advance.
Gangadhar
Re: BPEL Installation [message #653247 is a reply to message #653241] Tue, 08 February 2011 21:12 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Hi Gangadhar,
Please try the latest version of eclipse (helios 3.6). Grab the Eclipse IDE for Java EE Developers - this should have everything you need.
You may also want to read some of the other posts on this forum if you get into trouble Wink
Bob
Re: BPEL Installation [message #653257 is a reply to message #653247] Tue, 08 February 2011 22:55 Go to previous message
Hi Bob
Yes, I tried with helios 3.6 few hours ago, and was alright, initial set up looks ok.
BTW Thanks for the info.
Yes I will try to follow other posts, if I am stuck.
Ganga
Previous Topic:Link to CVS on developer page broken
Next Topic:XML output of BPEL generation.
Current Time: Sun May 19 02:50:22 EDT 2013
Powered by FUDForum. Page generated in 0.01691 seconds
