| Application vs. Product [message #651108 is a reply to message #650584] |
Thu, 27 January 2011 14:19   |
Nepomuk Seiler Messages: 77 Registered: December 2010 |
Member |
I discovered some strange behaviour with Eclipse RCP and EclipseLink Gemini JPA.
A "Eclipse Application" launch configuration with the parameter "Programm to launch" set to "Run an
application" works perfectly if gemini.jpa is set to auto-start.
Otherwise if "Programm to launch" is set to "Run a product" I get really strange errors.
With auto-start of gemini.jpa
http://dl.dropbox.com/u/2654300/stacktrace_autostart.txt
Sometimes the application is running afterwards, sometimes not.
Without auto-start (start manually via the OSGi-Console)
http://dl.dropbox.com/u/2654300/stacktrace_manualstart.txt
The application always crashes completly
[Update]
Even with "Run an application" it get those errors sometimes. I has to be the way
the bundles are started.
Eclipse.registry seems to have some problems.
Greetings,
Muki
[Updated on: Thu, 27 January 2011 16:21] Report message to a moderator
FUDForum. Page generated in 0.05879 seconds
