| BIRT Report Viewer Problem [message #652993] |
Mon, 07 February 2011 16:01  |
PeteW Messages: 2 Registered: February 2011 |
Junior Member |
I'm relatively new to Birt, but I've created several reports that take advantage of the web service datasource capability. Recently when I began experimenting with "report parameters" I encountered an unexpected problem when moving the reports to the report viewer environment under Tomcat. The reports that use a report parameter do not render any content. As an example, the chart is blank. No error message occurs.
The parameter portion seems to work, because I have a title that displays the selected parameter, but nothing else in the report renders content.
It works fine using the "preview" under Eclipse.
Any ideas?
Thanks in advance.
FUDForum. Page generated in 0.03095 seconds
