| Ubuntu 10.10 + ATF xpcomerror [message #653014] |
Mon, 07 February 2011 19:58 |
basmatte Messages: 1 Registered: February 2011 |
Junior Member |
I'm realy frustrated not getting to run the Ajax Tools Framework on Ubuntu 10.10.
The installation works fine, But whenever I want to open an HTML File in the Browser View. I get a xpcom error:
Unhandled event loop exception
XPCOM error -2147467259
An extract of my system configuration:
Ubuntu 10.10 64bit
2.6.35-25-generic #44-Ubuntu SMP Fri Jan 21 17:40:44 UTC 2011 x86_64 GNU/Linux
Eclipse Helios
Version: 3.6.1
Build id: M20100909-0800
I use the Classic Edition with WTP installed
Installed Software in Eclipse
Toggle Spoiler
AJAX Tools Framework Mozilla IDE (Incubation) 0.3.0.v201006041600-17K-DZRDIXEjJiCROLD org.eclipse.atf.mozilla.ide.feature.feature.group
Mozilla XPCOM for Java 1.9.1.0_v20090825-1855-27801aw311A193502411 org.mozilla.xpcom.feature.feature.group
Mozilla Xulrunner 1.9.1.0_v20090825-1855-57Z379OhF77g7cFR37gN7 org.mozilla.xulrunner.feature.feature.group
AJAX Tools Framework Webtools Integration (Incubation) 0.3.0.v201006041600-15-7zCN3GbYIN_PmMjDSPME org.eclipse.atf.feature.feature.group
WST Common UI 3.2.2.v201008091400-7C78FPhEdhO_mXde7kbap_K7X1Qt org.eclipse.wst.common_ui.feature.feature.group
CXF Web Services Tests 1.0.0.v201005241530-2--7w312114333422 org.eclipse.jst.ws.cxf_tests.feature.feature.group
Dali Java Persistence Tools JUnit Tests 2.3.2.v201008242310-777D2AkF7B77UEK9A87 org.eclipse.jpt.tests.feature.feature.group
Eclipse SDK 3.6.1.M20100909-0800 org.eclipse.sdk.ide
Eclipse Project SDK 3.6.1.r361_v20100714-0800-7Q7m6DDaKf5o2z-L9LxPSe6ygafz-KKIqk1rr_3j4dn7J org.eclipse.sdk.feature.group
Equinox p2 Provisioning 2.0.1.r361_v20100903-897HFZFFZRuSD2LMtVxyz0Vr org.eclipse.equinox.p2.user.ui.feature.group
Graphical Editing Framework Draw2d 3.6.1.v20100908-1100-4507w31211A2403131 org.eclipse.draw2d.feature.group
Graphical Editing Framework Draw2d SDK 3.6.1.v20100908-1100-7A7G18yE5F-8K8N4I8E558B48x42 org.eclipse.draw2d.sdk.feature.group
Graphical Editing Framework Draw2d Source Feature 3.6.1.v20100908-1100-4507w31211A2403131 org.eclipse.draw2d.source.feature.group
Graphical Editing Framework GEF 3.6.1.v20100908-1100-777B181A3Bz-6B663E7974242 org.eclipse.gef.feature.group
Graphical Editing Framework GEF All-In-One SDK 3.6.1.v20100908-1100-787D17PhSyGcDBx8Zy_MhtyNUO45 org.eclipse.gef.all.feature.group
Graphical Editing Framework GEF Examples 3.6.1.v20100908-1100-7G7T1BgJ9E99iCg4FPEO org.eclipse.gef.examples.feature.group
Graphical Editing Framework GEF Examples Source Feature 3.6.1.v20100908-1100 org.eclipse.gef.examples.source.feature.group
Graphical Editing Framework GEF SDK 3.6.1.v20100908-1100-7G7R2A5WNcBQPZgXAHiSXMXYaKPI org.eclipse.gef.sdk.feature.group
Graphical Editing Framework GEF Source Feature 3.6.1.v20100908-1100-777B181A3Bz-6B663E7974242 org.eclipse.gef.source.feature.group
Graphical Editing Framework Zest Visualization Toolkit 1.2.0.v20100519-2050-67808yE5F-8HAH4HECF4242 org.eclipse.zest.feature.group
Graphical Editing Framework Zest Visualization Toolkit SDK 1.2.0.v20100519-2050-67908COKMFAKPYIEUdUVWhXYN8VN org.eclipse.zest.sdk.feature.group
Graphical Editing Framework Zest Visualization Toolkit Source Feature 1.2.0.v20100519-2050-67808yE5F-8HAH4HECF4242 org.eclipse.zest.source.feature.group
JAX-WS DOM Tools Tests 1.0.1.v201007072248-7710BgJ9E99SINIMGN org.eclipse.jst.ws.jaxws.dom_tests.feature.feature.group
JAX-WS Tools Tests 1.0.0.v201005241530-3--8s735339777955 org.eclipse.jst.ws.jaxws_tests.feature.feature.group
JSDT Tests 1.2.2.v201008170101-781F8UDZRDKDDz-J0EPT_ org.eclipse.wst.jsdt_tests.feature.feature.group
JSF Tooling Tests Feature 3.2.2.v20100827-7E7WA9FBBoPbPQOiYa3454 org.eclipse.jst.jsf.tests.feature.feature.group
JST Enterprise Tests 3.2.100.v201008190400-7A77FA5BgJ9E99SIMCNHS org.eclipse.jst.enterprise_tests.feature.feature.group
JST Server Tests 3.2.2.v20100908-530AkF7B77PCY org.eclipse.jst.server_adapters.ext_tests.feature.feature.group
JST Server Tests 3.2.0.v201005241530-418Z8s7353387E org.eclipse.jst.server_tests.feature.feature.group
JST Web Tests 3.2.2.v201009091746-784FeJDZRDKDDz-LZIiOR org.eclipse.jst.web_tests.feature.feature.group
Releng Tools Feature 1.1.3.v201005292024-2027w312116411549 org.eclipse.wtp.releng.tools.feature.feature.group
WST Common Tests 3.2.2.v201008242000-7B7BFMYF7RZHPQI-TmKrVZ org.eclipse.wst.common_tests.feature.feature.group
WST Server Tests 3.2.2.v20100908-530AkF7B77OER org.eclipse.wst.server_tests.feature.feature.group
WST Web Services Tests 3.0.403.v201008211657-77-FJXCcNBHBBcMFGiNY org.eclipse.wst.ws_tests.feature.feature.group
WST Web Tests 3.2.2.v201008242000-79-F_cEVVFNFG9Q-Ln_i org.eclipse.wst.web_tests.feature.feature.group
WST XML Tests 3.2.1.v201008211651-7D-G-8FAFkNZNOJgnWIoE org.eclipse.wst.xml_tests.feature.feature.group
WTP releng test feature 1.1.1.v201005241530-5159-AAOxDKDMANLK5C8G org.eclipse.wtp.releng.tests.feature.feature.group
Releng Fixup Tools Feature 1.0.2.v201005050319-2-17w312116161414 org.eclipse.wtp.releng.fixups.feature.feature.group
XSL Tests Feature 1.1.202.v201009091745-7I77DKF8NcJTJK-U7T1oz org.eclipse.wst.xsl_tests.feature.feature.group
I already tried to install the same xulrunner Version 1.9.1 instead of 1.9.2 in ubuntu. But that didn't help. I read that the atf plugin is independent from the native xullrunner libs installed on the system.
I have no clue, where to look for additional error-logs or things, which could help solving this problem.
Other things I tried were:
- setting the org.eclipse.swt.browser.XULRunnerPath to /usr/lib/xulrunner-1.9.2.13/
- deleting ~/.mozilla/eclipse directory
this gives me a stacktrace about a NullPointerException within the browser panel (or where the browser should appear):
Toggle Spoiler
at org.eclipse.atf.mozilla.ide.ui.netmon.MozNetworkMonitorAdapter.connect(MozNetworkMonitorAdapter.java:177)
at org.eclipse.atf.mozilla.ide.ui.browser.MozBrowserEditor.createPartControl(MozBrowserEditor.java:598)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:331)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMenu.java:179)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
My problem is closely related to that one: https://bugs.eclipse.org/bugs/show_bug.cgi?id=312350
[Updated on: Tue, 08 February 2011 06:56] Report message to a moderator
FUDForum. Page generated in 0.02071 seconds
