| Possible Bug?? [message #651342] |
Sat, 29 January 2011 11:16  |
Nick Messages: 2 Registered: January 2011 |
Junior Member |
Hello All,
Hopefully this is the right place for this post. If not I apologize.
I am experiencing an interesting problem with the eclipse environment.
When I try to type:
The selection menu pops up and eclipse exits directly after rendering the menu...no warning, prompting, or any log entries in the .log file.
this is happening with:
eclipse-SDK-3.6.1-linux-gtk.tar.gz
On Slackware 13.1 (32bit) with java version 1.6.0
Has anyone seen this type of behavior before?
| Re: Possible Bug?? [message #652764 is a reply to message #652719] |
Sun, 06 February 2011 09:27  |
Junior Member |
Do you know why/how this could be a symptom of a corrupted install? Eclipse seems to be the only package on my system that gives any error what-so-ever and considering it is not part of the original distribution and written almost entirely in java (which doesn't come with slackware either) I would think there aren't too many dependencies on the actual 'system' rather the eclipse package dependencies, now Of course the 'packages' are dependent on the 'system' but, if the system was corrupt I would suspect to see this behavior from other programs, which is not the case. If you have more in site into your suggestion I would be interested to hear.
Looks like eclipse has this issue, my bug report got marked as a dup to this one.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317383
Although, I am SURE other slackware 13.1 users are running eclipse just fine...so perhaps it could be my system.
EDIT: changed 'I' to 'it'
[Updated on: Sun, 06 February 2011 09:28] Report message to a moderator
FUDForum. Page generated in 0.04194 seconds
