I start runing tomcat and birt on my server.
but i have problem with export my raport from the website.
- org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userExcept ion
faultSubcode:
faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
faultActor:
faultNode:
faultDetail: {http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.rep ort.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDum myException(ReportEngineService.java:1096)
at org.eclipse.birt.report.service.ReportEngineService.renderRe port(ReportEngineService.java:1543)
at org.eclipse.birt.report.service.BirtViewerReportService.rend erReport(BirtViewerReportService.java:369)
at org.eclipse.birt.report.service.actionhandler.BirtRenderRepo rtActionHandler.__execute(BirtRenderReportActionHandler.java :65)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.doService(FramesetFragment.java:222)
at org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.service(FramesetFragment.java:86)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Viewer Servlet.java:181)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:215)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:210)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:875)
at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:685)
at java.lang.Thread.run(Thread.java:636)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:308)
at org.eclipse.birt.report.service.ReportEngineService.renderRe port(ReportEngineService.java:1537)
... 28 more
Caused by: java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11.XToolkit
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:186)
at java.awt.Toolkit$2.run(Toolkit.java:849)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:841)
at org.eclipse.birt.report.engine.layout.pdf.util.PropertyUtil. getScreenDpi(PropertyUtil.java:322)
at org.eclipse.birt.report.engine.layout.pdf.util.PropertyUtil. getRenderDpi(PropertyUtil.java:294)
at org.eclipse.birt.report.engine.layout.pdf.util.PropertyUtil. getRenderDpi(PropertyUtil.java:305)
at org.eclipse.birt.report.engine.nLayout.area.impl.ContainerAr ea.getResolution(ContainerArea.java:770)
at org.eclipse.birt.report.engine.nLayout.area.impl.ContainerAr ea.getDimensionValue(ContainerArea.java:866)
at org.eclipse.birt.report.engine.nLayout.area.impl.ContainerAr ea.validateBoxProperty(ContainerArea.java:906)
at org.eclipse.birt.report.engine.nLayout.area.impl.BlockContai nerArea.initialize(BlockContainerArea.java:174)
at org.eclipse.birt.report.engine.nLayout.area.impl.BlockTextAr ea.layout(BlockTextArea.java:58)
at org.eclipse.birt.report.engine.nLayout.LayoutEngine.startCon tent(LayoutEngine.java:488)
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter .startText(ContentEmitterAdapter.java:147)
at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter .startData(ContentEmitterAdapter.java:163)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.st artContent(ContentEmitterUtil.java:71)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEm itter.startContent(HTMLTableLayoutEmitter.java:146)
at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBu ffer.startContent(HTMLPageBuffer.java:116)
at org.eclipse.birt.report.engine.layout.html.buffer.TableBreak Buffer.startContent(TableBreakBuffer.java:287)
at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.st art(HTMLLeafItemLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:139)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l ayoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLGroupLM.layou tChildren(HTMLGroupLM.java:117)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange Render.render(RenderTask.java:602)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:284)
... 29 more
{http://xml.apache.org/axis/}hostname:192.168.0.1
{}:org.eclipse.birt.report.service.api.ReportServiceExceptio n: Error happened while running the report.
... 28 more
... 29 more
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(Bi rtUtility.java:761)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:94)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 25 more
... 28 more
... 29 more
On 2/3/2011 4:16 AM, Bartek wrote:
> Hello,
> AxisFault
> faultSubcode: faultString:
> faultActor: faultNode: faultDetail:
> Servlet.java:181)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:151)
> ssor.java:875)
> nderTask.java:308)
> ... 28 more
> at java.security.AccessController.doPrivileged(Native Method)
> nderTask.java:284)
> ... 29 more
> Servlet.java:181)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:151)
> ssor.java:875)
> nderTask.java:308)
> ... 28 more
> nderTask.java:284)
> ... 29 more
> rtUtility.java:761)
> Servlet.java:181)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:151)
> ssor.java:875)
> ... 25 more
> nderTask.java:308)
> ... 28 more
> nderTask.java:284)
> ... 29 more
> What can i do to solve this problem?
