Home » Eclipse Projects » EclipseLink » Discriminator and caching(Problem with turning off caching and Discriminators)
Discriminator and caching [message #652347] Thu, 03 February 2011 11:13 Go to next message
Kevin H is currently offline Kevin H
We recently added <property name="eclipselink.cache.shared.default" value="false"/> to the persistence.xml to turn off caching of the query results. This change seems to be causing some issues with with entities that have Discrimitor Columns defined. The discriminator value is coming through as null now when it used to be set fine previous to this. Any ideas?
Re: Discriminator and caching [message #652553 is a reply to message #652347] Fri, 04 February 2011 09:16 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
I do not see how these two things can be related as the descriminator column should be read in from the database, not the cache anyway. Please provide more information on your entities - perhaps it might be better to file a bug where you can provide a small reproducable test case.
Can you show a particular query you are having problems with?
Best Regards,
Chris
Previous Topic:EclipseLink 2.1.2 on JBoss 6.0.0 Final
Next Topic:Discriminator value and char trimming problem
Current Time: Mon May 20 07:47:03 EDT 2013
Powered by FUDForum. Page generated in 0.01839 seconds
