Home » Eclipse Projects » EclipseLink » exception while paging data with eclipselink jpa(exception while paging data with eclipselink jpa)
exception while paging data with eclipselink jpa [message #651715] Tue, 01 February 2011 07:04 Go to next message
obinnahenree is currently offline obinnahenree
hi i have the following method that does paging in an ejb. (dont mind the string params, not using them yet)
public List<DatamainMst> findAll(String srchCallup, String srchSurname, String srchOthernames, String srchInst, String srchCourse,int first, int pagesize) {
List<DatamainMst> mst = em.createQuery("select o from DatamainMst o")
.setFirstResult(first).setMaxResults(pagesize).getResultList();
return mst;
my database table has about 61868 records. the whole paging works well until "first" argument is 61200, and irrespective of the page size, i always get the following exception:
WARNING: java.lang.NullPointerException
at nysc.entities.DatamainMst._persistence_set(DatamainMst.java)
at org.eclipse.persistence.internal.descriptors.PersistenceObjectAttributeAccessor.setAttributeValueInObject(PersistenceObjectAttributeAccessor.java:46)
at org.eclipse.persistence.mappings.DatabaseMapping.setAttributeValueInObject(DatabaseMapping.java:1367)
at org.eclipse.persistence.mappings.DatabaseMapping.readFromRowIntoObject(DatabaseMapping.java:1258)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildAttributesIntoObject(ObjectBuilder.java:331)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:660)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:582)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:551)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:491)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:443)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:635)
at org.eclipse.persistence.queries.ReadAllQuery.registerResultInUnitOfWork(ReadAllQuery.java:838)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:464)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:997)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:675)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:958)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:432)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1021)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2857)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1225)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1207)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1181)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:453)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:681)
at com.nysc.setup.MobilizedEJB.findAll(MobilizedEJB.java:37)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1056)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1128)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5292)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:615)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:797)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:567)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:157)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:139)
at sun.reflect.GeneratedMethodAccessor100.invoke(Unknown Source)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:858)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:367)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5264)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5252)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:190)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:84)
at $Proxy139.findAll(Unknown Source)
at com.nysc.view.MobilizedMBean.populateLazyDatamain(MobilizedMBean.java:46)
at com.nysc.view.MobilizedMBean.access$000(MobilizedMBean.java:21)
at com.nysc.view.MobilizedMBean$1.load(MobilizedMBean.java:64)
at org.primefaces.component.datatable.DataTable.loadLazyData(DataTable.java:644)
at org.primefaces.component.datatable.DataHelper.decodePageRequest(DataHelper.java:53)
at org.primefaces.component.datatable.DataTableRenderer.decode(DataTableRenderer.java:47)
at javax.faces.component.UIComponentBase.decode(UIComponentBase.java:790)
at javax.faces.component.UIData.processDecodes(UIData.java:980)
at com.sun.faces.context.PartialViewContextImpl$PhaseAwareVisitCallback.visit(PartialViewContextImpl.java:472)
at com.sun.faces.component.visit.PartialVisitContext.invokeVisitCallback(PartialVisitContext.java:175)
at javax.faces.component.UIData.visitTree(UIData.java:1194)
at javax.faces.component.UIComponent.visitTree(UIComponent.java:1457)
at javax.faces.component.UIForm.visitTree(UIForm.java:324)
at com.sun.faces.context.PartialViewContextImpl.processComponents(PartialViewContextImpl.java:368)
at com.sun.faces.context.PartialViewContextImpl.processPartial(PartialViewContextImpl.java:246)
at javax.faces.context.PartialViewContextWrapper.processPartial(PartialViewContextWrapper.java:179)
at javax.faces.component.UIViewRoot.processDecodes(UIViewRoot.java:939)
at com.sun.faces.lifecycle.ApplyRequestValuesPhase.execute(ApplyRequestValuesPhase.java:78)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:312)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1523)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:343)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:215)
at org.primefaces.webapp.filter.FileUploadFilter.doFilter(FileUploadFilter.java:79)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:277)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:188)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:641)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:97)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:85)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:185)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:325)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:226)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:165)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:791)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:693)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:954)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:170)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:135)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:102)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:88)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:76)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:53)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:57)
at com.sun.grizzly.ContextTask.run(ContextTask.java:69)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:330)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:309)
at java.lang.Thread.run(Thread.java:619)
WARNING: A system exception occurred during an invocation on EJB MobilizedEJB method public java.util.List com.nysc.setup.MobilizedEJB.findAll(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,int,int)
javax.ejb.EJBException
at com.sun.ejb.containers.BaseContainer.processSystemException(BaseContainer.java:5119)
at com.sun.ejb.containers.BaseContainer.completeNewTx(BaseContainer.java:5017)
at com.sun.ejb.containers.BaseContainer.postInvokeTx(BaseContainer.java:4805)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2004)
at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1955)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:198)
Caused by: java.lang.NullPointerException
... 55 more
i dont know what the problem is, it seems like an eclipse link problem?
what can i do?
Re: exception while paging data with eclipselink jpa [message #652307 is a reply to message #651715] Thu, 03 February 2011 09:28 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
Does your DatamainMst map any basic types (such as a Char) that might be null in that row but not in the preceeding rows?
Could it be related to bug 336192 ?
Best Regards,
Chris
Previous Topic:Could not define uni-directional @OneToMany mapping
Next Topic:EclipseLink 2.1.2 on JBoss 6.0.0 Final
Current Time: Sun May 19 20:56:39 EDT 2013
Powered by FUDForum. Page generated in 0.01667 seconds
