Home » Eclipse Projects » Target Management » Requests(Filter Regexpression)
Requests [message #651931] Wed, 02 February 2011 01:19 Go to next message
Caleb Jeffery is currently offline Caleb Jeffery
HI I am currently working on a project which uses several file name formats to distenguish between functions and subroutine.
unfortunately some of the files are not meeting these formats
I would like to create a filiter which selects of files that doesn"t contain the glob pattern.
Is this possible?
Re: Requests [message #652047 is a reply to message #651931] Wed, 02 February 2011 09:06 Go to previous message
Martin Oberhuber is currently offline Martin Oberhuber
So you want to hide files with a certain pattern?
As far as I know, in RSE this isn't possible directly, our filters only allow SHOWING files with certain patterns (well you could list all patterns that you do want to show).
If your remote server is "nearby" with a fast connection, you could set up an Eclipse Project with a Linked Resource pointing into an RSE filesystem (EFS). Eclipse 3.6 and later support very powerful resource filters that allow both the positive and the negative form, ie you can hide certain files using the Core Resources filters. Just select Project Properties / Resource Filters.
HTH,
Martin
Previous Topic:Forum Usage Tips
Next Topic:Pending Changes
Current Time: Wed May 22 05:09:27 EDT 2013
Powered by FUDForum. Page generated in 0.07514 seconds
