| mirror update sites with b3 [message #650787] |
Wed, 26 January 2011 09:44  |
David Gonzalez Messages: 23 Registered: January 2011 |
Junior Member |
Hey everbody,
I guess my problem is quite simple. I just want to mirror the Galileo Update Site and the Eclipse Project Updates for 3.5 to my local repository. That's why i don't understand i get an error verifying/building this one:
| Quote: | Cannot complete the install because of a conflicting dependency.
Software being installed: all.contributed.content.feature.group 1.0.0
Only one of the following can be installed at once:
OSGi System Bundle 3.5.2.R35x_v20100126 (org.eclipse.osgi 3.5.2.R35x_v20100126)
OSGi System Bundle 3.5.1.R35x_v20090827 (org.eclipse.osgi 3.5.1.R35x_v20090827)
OSGi System Bundle 3.5.0.v20090520 (org.eclipse.osgi 3.5.0.v20090520)
OSGi System Bundle 3.5.1.R35x_v20090806 (org.eclipse.osgi 3.5.1.R35x_v20090806)
OSGi System Bundle 3.5.2.R35x_v20100105 (org.eclipse.osgi 3.5.2.R35x_v20100105)
Cannot satisfy dependency:
To: org.eclipse.equinox.p2.ui.admin.rcp.product 0.0.0
My .b3aggr file looks like this:
<?xml version="1.0" encoding="ASCII"?>
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0" description="Aggregates the eclipse dependencies" label="Galileo + Delta Pack" buildRoot="${user.home}/test">
<configurations/>
<configurations architecture="x86_64"/>
<contributions label="Galileo 3.5">
<repositories location="http://download.eclipse.org/releases/galileo" mirrorArtifacts="true"/>
</contributions>
<contributions label="Galileo Updates">
<repositories location="http://download.eclipse.org/eclipse/updates/3.5" description="Need this for delta pack and latest versions" mirrorArtifacts="true"/>
</contributions>
</aggregator:Aggregator>
Also I really need only version 3.5.2, so i tried to work with exclusion rules, but it didn't work. And to add a bundle (OSGi System Bundle with Version 3.5.2) means to have only THIS one in your aggregated repository. So - any suggestions?
Greets
[Updated on: Wed, 26 January 2011 09:45] Report message to a moderator
| Re: mirror update sites with b3 [message #650961 is a reply to message #650787] |
Thu, 27 January 2011 05:27   |
Simon Linden Messages: 35 Registered: July 2009 |
Member |
| Gonzo wrote on Wed, 26 January 2011 09:44 |
....so i tried to work with exclusion rules, but it didn't work.
| Hello,
I tried to aggregate / mirror p2 update sites with ExclusionRules, too. Look at my Posting "How to exclude IU from aggregation maybe by ExclusionRule" a few days ago. I had the same experience as you. The ExclusionRules didn't work as I expected.
So I added the IU which I need via contextmenu -> "Add to parent Mapped Repository As" -> "Mapped Feature" or via contextmenu "Add to Custom Category" -> your custom category
hope that helps...
[Updated on: Thu, 27 January 2011 05:30] Report message to a moderator
| Re: mirror update sites with b3 [message #650973 is a reply to message #650787] |
Thu, 27 January 2011 06:02   |
Junior Member |
Hi Simon,
thanks for your suggestion.
To add the feature or bundle means to mirror only them, right? Well, that's not what i want, I want to update site completly mirrored.
The reason why I want to do this is quite simple. I have several plugins and products and I build them with Buckminster. I use a mspec, a cquery and a rmap. In my rmap i have the possibility to use the update site URL or to use a local repository. And i want to use a local repository to minimize the downloads and also the time it takes to build those components.
So i tried to create an aggregated repository - and one part of it should be the Galileo update site.
[Updated on: Thu, 27 January 2011 06:03] Report message to a moderator
| Re: mirror update sites with b3 [message #651874 is a reply to message #650973] |
Tue, 01 February 2011 15:43  |
Member |
| Gonzo wrote on Thu, 27 January 2011 06:02 | Hi Simon,
| Hello,
actually I don't know how the b3 aggregator exactly works but yes, it seems so. By adding a feature or a bundle mirrors only this feature.
The task I have seems completely different - sorry - I have no idea how you can solve your issue.
good luck & best regards
[Updated on: Tue, 01 February 2011 15:44] Report message to a moderator
FUDForum. Page generated in 0.01697 seconds
