Home » Modeling » M2T (model-to-text transformation) » [XPand] questions in using AROUND
[XPand] questions in using AROUND [message #650857] Wed, 26 January 2011 17:05 Go to next message
Thomas Lauria is currently offline Thomas Lauria
Hey there,
first of all: I am new here and if I am violating the netiquette somehow, give me a hint please.
My Problem: My AROUND Statement in a XPand Template won't be weaved around the code.
I try to use an AROUND statement similar to the following, all in one file:
«DEFINE foo FOR FooType» FOO «ENDDEFINE»
«DEFINE foo FOR BarType» BAR «ENDDEFINE»
«AROUND foo FOR FooType»
ABC «targetDef.proceed()» 123
«ENDAROUND»
«EXPAND foo FOR FooType»
I am expecting as output: "ABC FOO 123" but I am getting only " FOO ", so IMHO the AROUND is not applied.
I tried also the AROUND with the fully qualified name bar::bar::foo and with wildcards "*foo*", but nothing happens.
Can't I use AROUNDs in the same file as the DEFINE?
Has I to prepare something in the workflow to use the AROUND statement?
Or is there another common pitfall in using AROUNDs?
I am using the Eclipse Helios Release.
Thank you,
Thomas
Re: [XPand] questions in using AROUND [message #650860 is a reply to message #650857] Wed, 26 January 2011 17:51 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
yes you can have the advices in the same file but this is a bad bad practice
but your advices have to be full qualified
«AROUND templates::root::element FOR test::Element»
//this is the element «name»
«ENDAROUND»
and if cource you have to prepare something in the workflow
    <component adviceTarget="generator"	id="reflectionAdvice" class="org.eclipse.xpand2.GeneratorAdvice">
		<advices value="templates::root"/>
	</component>
	<component class="org.eclipse.xpand2.Generator" id="generator">
		<metaModel id="mm"
			class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
		<expand
			value="templates::root::Root FOR model" />
			<outlet path="src-gen" >
				<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
			</outlet>
	</component>
~Christian
Re: [XPand] questions in using AROUND [message #652845 is a reply to message #650860] Mon, 07 February 2011 05:51 Go to previous message
ok, thank you.
The entry in the workflow was missing.
But it seems like that the AROUND Statement isn't the right solution for my problem.
Previous Topic:[Xtend/XPand] Strange behaviour of checks
Next Topic:Binary code generation with Xtend/Xpand/Xtend2?
Current Time: Sat May 18 16:49:07 EDT 2013
Powered by FUDForum. Page generated in 0.07571 seconds
