Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » TPTP with Exe application(TPTP issue with exe application!)
TPTP with Exe application [message #527676] Fri, 16 April 2010 02:05 Go to next message
Gayathri is currently offline Gayathri
Hi all,
Im currently working with TPTP tool to automate eclipse RCP application and it is working fine.
But when i convert the RCP to exe file, and tried automating it, im facing some version problem between exe and TPTP.
The error log is as follows:
Cannot complete the install because one or more required items could not be found.
Software being installed: productconfiguration 1.0.0 (productconfiguration 1.0.0)
Missing requirement: productconfiguration 1.0.0 (productconfiguration 1.0.0) requires 'org.apache.commons.logging [1.0.4.v200904062259]' but it could not be found
Software being installed: productmodellingtool 1.0.0 (productmodellingtool 1.0.0)
Missing requirement: productmodellingtool 1.0.0 (productmodellingtool 1.0.0) requires 'org.eclipse.jface.text [3.5.1.r351_v20090708-0800]' but it could not be found
Software being installed: productmodellingtoolsample 1.0.0 (productmodellingtoolsample 1.0.0)
Missing requirement: productmodellingtoolsample 1.0.0 (productmodellingtoolsample 1.0.0)
requires 'org.w3c.dom.smil [1.0.1.v200903091627]' but it could not be found
Software being installed: nreproduct 2.0.0 (nreproduct 2.0.0)
Missing requirement: nreproduct 2.0.0 (nreproduct 2.0.0)
requires 'org.apache.commons.codec [1.3.0.v20080530-1600]' but it could not be found
Could anyone help us on this?
Gayathri.K
Re: TPTP with Exe application [message #650506 is a reply to message #527676] Tue, 25 January 2011 06:02 Go to previous message
sasikumar  is currently offline sasikumar
Hi Gayathri ,
Just i have started to work with TPTP and need help from you. how to explore the GUI of the project in TPTP. am stuck in the point. only i can record the macro in eclipse GUI but not in RCP project GUI. Pls help me in this.
Thanks in Advance.
Previous Topic:AGR 4.4: Problem with loops
Next Topic:Eclipse Java EE, Glassfish, Tomcat, and TPTP
Current Time: Sat May 25 20:22:08 EDT 2013
Powered by FUDForum. Page generated in 0.01669 seconds
