Home » Archived » Visual Editor (VE) » VE 1.5 release review
VE 1.5 release review [message #642716] Thu, 02 December 2010 08:39 Go to next message
Yves YANG is currently offline Yves YANG
Hi All,
VE team is pleased to announce the project review of the release 1.5 is
successful, which supports eclipse Helios. A stable release will be
published today and accessible via both local and remote installation.
http://www.eclipse.org/vep/
The installation note can be found here:
http://wiki.eclipse.org/VE/Update
Any feedback and contribution are welcome.
Best regards
Yves YANG
Re: VE 1.5 release review [message #642743 is a reply to message #642716] Thu, 02 December 2010 10:12 Go to previous messageGo to next message
Eclipse User
Originally posted by: pb158.tlen.pl
W dniu 02.12.2010 14:39, Yves YANG pisze:
> Hi All,
Already installed :) thanks
P.S.
Can you add in future versions of VE JFormattedTextField class to the
palette?
Re: VE 1.5 release review [message #644504 is a reply to message #642716] Sun, 12 December 2010 07:38 Go to previous messageGo to next message
No real name is currently offline No real name
Hi Yves,
Thank you for developing VE 1.5 (wonderful job). One of problem that I always have problem is when I move my project to different computer (same OS), the GUI disappear but still able to execute the application without any issue (interface look perfect), just the GUI disappear from development editor. Did I miss any files that need to copy over to my second computer?
Many thanks,
Kang
Re: VE 1.5 release review [message #644688 is a reply to message #644504] Mon, 13 December 2010 14:01 Go to previous messageGo to next message
Eclipse User
Originally posted by: richkulp.us.NOSPAM.ibm.com
By default on a java file the Java editor is the default editor. But
once you open as a different editor (such as VE), that editor then
becomes the default. It stores this in the workspace, not in a CVS/Team/etc.
When you created the class you probably used a VE wizard so that the
class was opened up with VE immediately, and so VE becomes the default
for that class instance.
So when you are on a new computer you are in a new workspace so it
switches to the default java editor. You can then do Open As -> and
select the VE instead.
Rich Kulp
Re: VE 1.5 release review [message #644698 is a reply to message #644688] Mon, 13 December 2010 14:55 Go to previous messageGo to next message
Rich,
Thank you very much, works perfectly!
Kang
Re: VE 1.5 release review [message #644989 is a reply to message #642716] Wed, 15 December 2010 01:16 Go to previous messageGo to next message
Peica  is currently offline Peica
Hi Sir,
I have install the VE1.5 on the Eclipse 3.6.1 over the MAC OS X 10.6.5.
My problem is the VE is running and I could add the Visual Class like others. But there is nothing display on the visual editor no matter what I drop on it from the SWT Controls or SWT Containers.
My eclipse could compile this test project.
Thanks.
Re: VE 1.5 release review [message #644993 is a reply to message #644989] Wed, 15 December 2010 01:39 Go to previous messageGo to next message
Hi Sir,
I think my problem is familiar with it mention at here http://www.eclipse.org/forums/index.php?t=msg&th=158142& amp;start=0&S=3392e7efc08e7fc013308a347bc8fe57 .
Would it be fixed on the future? If not could you please give me some cue to fixed it by myself.
Thanks again.
Re: VE 1.5 release review [message #645283 is a reply to message #642716] Thu, 16 December 2010 07:52 Go to previous messageGo to next message
Marco is currently offline Marco
R.I.P.
http://www.eclipse.org/proposals/tools.windowbuilder/
Re: VE 1.5 release review [message #645290 is a reply to message #645283] Thu, 16 December 2010 08:11 Go to previous messageGo to next message
Thanks. I have found it.
Re: VE 1.5 release review [message #645546 is a reply to message #645283] Fri, 17 December 2010 14:19 Go to previous messageGo to next message
Chemi is currently offline Chemi
On 12/16/2010 1:52 PM, Marco wrote:
> R.I.P.
Is there any reaction or information from VE point of view?
Re: VE 1.5 release review [message #650232 is a reply to message #644688] Sun, 23 January 2011 09:03 Go to previous message
Eclipse User wrote on Mon, 13 December 2010 14:01
Rich Kulp
thanks,Rich Kulp
Previous Topic:Custom SWT-Widget added but not drawn
Next Topic:VE 1.4 and Eclipse 3.6
Current Time: Thu May 23 14:44:58 EDT 2013
Powered by FUDForum. Page generated in 0.02281 seconds
