Home » Eclipse Projects » P2 » Configure Framework persistent data location
Configure Framework persistent data location [message #649933] Thu, 20 January 2011 23:34
Murthy Bhat is currently offline Murthy Bhat
Is there any way to configure the Framework persistent data location in a p2 enabled eclipse product.
My usecase is that i have a product exported to a location, but the configuration location for the product is in some other location. The product is exported to say c:\product and the configuration is set to @user.home/config using
-configuration @user.home/config
When i install my plugin using dropins (basically p2), i get an exception saying that
The framework persistent data location (C:\Documents and Settings\~user~\config) is not the same as the framework configuration location (c:\product\@user.home/config).
Does anybody have any ideas on the exception ? Or is there any way i could configure my framework persistent data location also point to the config location.
Thanks in advance for help.
Murthy
Previous Topic:P2 Errors when two instances share same configuration
Next Topic:P2 fragment update
Current Time: Tue May 21 17:27:48 EDT 2013
Powered by FUDForum. Page generated in 0.01540 seconds
