Home » Language IDEs » Java Development Tools (JDT) » Let Eclipse generate Implementation class skeleton for Interface?
Let Eclipse generate Implementation class skeleton for Interface? [message #649725] Thu, 20 January 2011 07:53 Go to next message
Ben Stover
Assume I have got an Java Interface definition file.
Is there a way to let Eclipse automatically geberate a corresponding java source skeleton file for the implementation of this Interface?
Ben
[Updated on: Thu, 20 January 2011 07:53]
Report message to a moderator
Re: Let Eclipse genrate Implem class skeleton for Interface? [message #649737 is a reply to message #649725] Thu, 20 January 2011 08:38 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
Just write the interface and then use Quick Fix (Ctrl+1) on the error.
Another way is to use Source > Override/Implement Methods....
Dani
> Ben
Re: Let Eclipse genrate Implem class skeleton for Interface? [message #649747 is a reply to message #649737] Thu, 20 January 2011 09:15 Go to previous message
shanky sohar is currently offline shanky sohar
create an interface with the methods..
Then at the time of creating a class add the interface,
This class file will automatically have the default implementation of the interface method
Previous Topic:How to change wrap column for "source format" operation?
Next Topic:[SOLVED] How to create hierarchy search scope from a MethodDeclaration instance?
Current Time: Sat May 25 20:28:23 EDT 2013
Powered by FUDForum. Page generated in 0.01588 seconds
