| Re: Eclipse (WTP) [message #649521 is a reply to message #649402] |
Wed, 19 January 2011 09:34   |
Larry Isaacs Messages: 1261 Registered: July 2009 |
On 1/19/2011 2:08 AM, M& wrote:
> i have 2 problems, please help me
> (My versions: eclipse(3.6) helios, jkd: jdk1.6.0_21 & Tomcat v6.0)
> 1) when i debug my web project, right click in project, debug az, debug
> on server: it gives me this error
> SEVERE: Error starting static Resources
> java.lang.IllegalArgumentException: Document base
> D:\workspace\WP\.metadata\.plugins\org.eclipse.wst.server.co
> re\tmp1\wtpwebapps\KicsIdCard does not exist or is not a readable directory
> at org.apache.naming.resources.FileDirContext.setDocBase(FileDi
> rContext.java:142)
> at org.apache.catalina.core.StandardContext.resourcesStart(Stan
> dardContext.java:4048)
> at org.apache.catalina.core.StandardContext.start(StandardConte
> xt.java:4217)
> at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
> at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:722)
> at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
> at org.apache.catalina.core.StandardService.start(StandardServi
> ce.java:516)
> at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
> at org.apache.catalina.startup.Catalina.start(Catalina.java:583 )
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
> at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
> 2) when i open eclipse or restart it, i have this error:
> Preferences --> mercurial
> Mercurial Executable: hg
> problem occurred:
> process start failed: hg -y debuginstall
> can not run program "hg": create process error=2, the system can not
> find the file specified.
> Tnx for Help
For the first problem, does the requested directory exist? That is
where WTP would publish an "assembled" webapp for Tomcat to serve. If
it's not there then Tomcat's complaint is expected. Do you get the same
behavior with Run on Server?
Larry
| Re: Eclipse (WTP) [message #650353 is a reply to message #650168] |
Mon, 24 January 2011 09:36  |
On 1/22/2011 3:39 AM, M& wrote:
> it dose'nt create KicsIdCard in
> wtpwebapps is empty.
> yes when i close eclipse or restart it again and then want to start
> server it gaves error but now its run without problems.
> At all i cant debug and run my project beacuse
> re\tmp1\wtpwebapps\KicsIdCard.
> i do not know how i can solve it, please help, Tnx.
You haven't given many details so it's hard to make much of a guess as
to why this is happening, so here is guess #1.
The KicsIdCard webapp was removed from the Tomcat server in Eclipse, but
somehow the corresponding Context in the server.xml didn't get removed.
This would explain why the directory is not being created. Does the
KicsIdCard project still exist and does it appear as a child of the
Tomcat server in the Servers view?
Larry
FUDForum. Page generated in 0.02146 seconds
