Home » Eclipse Projects » Eclipse 4 » XWT and ListViewer
XWT and ListViewer [message #645202] Wed, 15 December 2010 16:53 Go to next message
Wolfgang Herbst is currently offline Wolfgang Herbst
Hi, I have the following XWT code
<ListViewer name="client" x:style="SWT.BORDER" input="{Binding Path=clients}" displayMemberPath="name"/>
What type of list has to be used for the clients property in order to get this working?
Cheers!
Re: XWT and ListViewer [message #645752 is a reply to message #645202] Mon, 20 December 2010 07:10 Go to previous messageGo to next message
Yves YANG is currently offline Yves YANG
It should work with any Java class with the property "name".
Best regards
Yves YANG
Re: XWT and ListViewer [message #648966 is a reply to message #645752] Sun, 16 January 2011 16:41 Go to previous message
St Clair Clarke is currently offline St Clair Clarke
Hello Wolfgang,
I am having similar problems.
Did you get the data to displayed in your ListViewer? If you do could you please post the snippets to show how a simple example works - ie the XWT code, code-behind code, model etc.
Thanks.
Previous Topic:how to pass arguments to a Part
Next Topic:e4 source code is giving some unexpected error
Current Time: Sun May 19 01:36:03 EDT 2013
Powered by FUDForum. Page generated in 0.02285 seconds
