Home » Eclipse Projects » Eclipse 4 » how to pass arguments to a Part
how to pass arguments to a Part [message #648536] Thu, 13 January 2011 07:52 Go to next message
sev! is currently offline sev!
hi
I'm new to eclipse e4.
I Have a stack to which I'm dinamically adding parts like this:
	public void openProgram(String prog) {
	    MPart part = MBasicFactory.INSTANCE.createPart();
	    part.setLabel(prog);
	    part.setCloseable(true);
	    part.setContributionURI("platform:/plugin/ch.inteco.wegas/ch.inteco.wegas.app.ProgramView");
	    List<MPartStack> stacks = modelService.findElements(application, null, MPartStack.class, null);
	    stacks.get(1).getChildren().add(part);
	    partService.showPart(part, PartState.ACTIVATE);
Is there a possibility to pass a parameter to the ProgramView class, or maybe injection of a context? It should be available upon creation of the ProgramView part.
Regards and Thank you
Severin
Re: how to pass arguments to a Part [message #648543 is a reply to message #648536] Thu, 13 January 2011 08:22 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Depends on the kind of parameter. If you have string parameters, you
can use MPart.getProperties().put("key", "value")
They'll get populated into your IEclipseContext, and can even be
retrieved by:
@Inject
public void setUid(@Named("key") String uid);
Or is it something else?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: how to pass arguments to a Part [message #648583 is a reply to message #648536] Thu, 13 January 2011 10:14 Go to previous message
Thanks! Exactly what I needed!
Previous Topic:Download is not happeining through git server
Next Topic:XWT and ListViewer
Current Time: Sun May 26 03:04:30 EDT 2013
Powered by FUDForum. Page generated in 0.04100 seconds
