Home » Eclipse Projects » Standard Widget Toolkit (SWT) » drag & drop of url link
drag & drop of url link [message #648184] Tue, 11 January 2011 11:48 Go to next message
Eclipse User
Originally posted by: jdevgl.gmail.com
Hi =)
I would like to know if it is possible to drag'n'drop an url link (from
a web browser) into an swt tree and how can one do that?
Thank you :)
Re: drag & drop of url link [message #648308 is a reply to message #648184] Wed, 12 January 2011 06:02 Go to previous message
Lakshmi Shanmugam
Here is an example Snippet --> Snippet284.java
This drags the URL between labels. You can modify the snippet to use a Browser as the DragSource instead of Label and use Tree as the DropTarget.
Also see the Drag and Drop example which does drag and drop between different controls --> DNDExample.java
HTH,
Lakshmi
Lakshmi P Shanmugam
Previous Topic:Problems with scroll synchronization of 2 trees
Next Topic:How to Crop/Trim Image/ImageData
Current Time: Sun May 19 21:43:29 EDT 2013
Powered by FUDForum. Page generated in 0.01893 seconds
