Home » Eclipse Projects » EclipseLink » Deadlock during serialization of entities(Deadlock during serialization of entities in Vector.writeObject)
icon5.gif  Deadlock during serialization of entities [message #646152] Wed, 22 December 2010 06:49 Go to next message
Sven Hoffmann is currently offline Sven Hoffmann
We are facing deadlocks during serialization of remote business method invocations on the server side.
Concurrent access on entities which are managed by a shared cache results in a deadlock during serialization of Vector as shown by the extract of a javacore at the bottom of this post.
The service is running on a WebSphere Application Server 6.1 incl. EJB 3.0 Feature pack. Version of EclipseLink is 2.1.1.
In the thread EclipseLink: Deadlock when returning Entities from a remote method call a similar problem is discussed and seems to be caused by the implementation of IndirectList.
In our environment neither on query nor on entity level read-only attribute is set but entities use lazy-loading relations of type java.util.List. Entities are read by a JPA EntitiyManager of a container managed service.
In the mentioned thread James (jsutherl) wrote:
We should provide an option to use ArrayList in IndirectList instead of Vector...
Would this option be part of the related Bug 309822 - Deadlock when returning Entities from a remote method call and when would this option be available?
In the meantime we will replace List- by Set-based relations. Are other options available to avoid this kind of deadlock on JPA level?
Sven
1LKDEADLOCK    Deadlock detected !!!
NULL           ---------------------
NULL
2LKDEADLOCKTHR  Thread "ORB.thread.pool : 29" (0x3EBC8700)
3LKDEADLOCKWTR    is waiting for:
4LKDEADLOCKMON      sys_mon_t:0x3D20FAA8 infl_mon_t: 0x3D20FAD0:
4LKDEADLOCKOBJ      java/util/Vector@86FA49D0/86FA49DC:
3LKDEADLOCKOWN    which is owned by:
2LKDEADLOCKTHR  Thread "ORB.thread.pool : 50" (0x420A0800)
3LKDEADLOCKWTR    which is waiting for:
4LKDEADLOCKMON      sys_mon_t:0x3B7FA660 infl_mon_t: 0x3B7FA688:
4LKDEADLOCKOBJ      java/util/Vector@898B4A98/898B4AA4:
3XMTHREADINFO      "ORB.thread.pool : 29" (TID:0x3EBC8700, sys_thread_t:0x3AE8A6D0, state:B, native ID:0x00101089) prio=5
4XESTACKTRACE          at java/util/Vector.writeObject(Vector.java:890(Compiled Code))
4XESTACKTRACE          at sun/reflect/GeneratedMethodAccessor82.invoke(Bytecode PC:40(Compiled Code))
4XESTACKTRACE          at sun/reflect/DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43(Compiled Code))
4XESTACKTRACE          at java/lang/reflect/Method.invoke(Method.java:618(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.invokeObjectWriter(IIOPOutputStream.java:944(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.outputObject(IIOPOutputStream.java:979(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.writeSerializable(IIOPOutputStream.java:1027(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.simpleWriteObjectInternal(IIOPOutputStream.java:436(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.simpleWriteObjectLoop(IIOPOutputStream.java:464(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.defaultWriteObjectDelegate(IIOPOutputStream.java:567(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/OutputStreamHook.defaultWriteObject(OutputStreamHook.java:132(Compiled Code))
4XESTACKTRACE          at java/util/Vector.writeObject(Vector.java:891(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.writeObjectDelegate(IIOPOutputStream.java:197(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.writeObjectOverride(IIOPOutputStream.java:208(Compiled Code))
4XESTACKTRACE          at java/io/ObjectOutputStream.writeObject(ObjectOutputStream.java:337(Compiled Code))
4XESTACKTRACE          at java/util/Hashtable.writeObject(Hashtable.java:754(Compiled Code))
4XESTACKTRACE          at java/util/Hashtable.writeObject(Hashtable.java:748(Compiled Code))
4XESTACKTRACE          at sun/reflect/GeneratedMethodAccessor114.invoke(Bytecode PC:40(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/IIOPOutputStream.simpleWriteObject(IIOPOutputStream.java:521(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/io/ValueHandlerImpl.writeValue(ValueHandlerImpl.java:167(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/CDROutputStream.write_value(CDROutputStream.java:1534(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/CDROutputStream.write_value(CDROutputStream.java:1554(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/CDROutputStream.write_abstract_interface(CDROutputStream.java:1454(Compiled Code))
4XESTACKTRACE          at com/ibm/CORBA/iiop/UtilDelegateImpl.writeAbstractObject(UtilDelegateImpl.java:476(Compiled Code))
4XESTACKTRACE          at javax/rmi/CORBA/Util.writeAbstractObject(Util.java(Compiled Code))
4XESTACKTRACE          at com/kn/workplace/service/user/_EJSRemote0SLUserAdministrationServiceBean_d6083149_Tie.findUserByLike(_EJSRemote0SLUserAdministrationServiceBean_d6083149_Tie.java)
4XESTACKTRACE          at com/kn/workplace/service/user/_EJSRemote0SLUserAdministrationServiceBean_d6083149_Tie._invoke(_EJSRemote0SLUserAdministrationServiceBean_d6083149_Tie.java)
4XESTACKTRACE          at com/ibm/CORBA/iiop/ServerDelegate.dispatchInvokeHandler(ServerDelegate.java:627(Compiled Code))
4XESTACKTRACE          at com/ibm/CORBA/iiop/ServerDelegate.dispatch(ServerDelegate.java:480(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/ORB.process(ORB.java:512(Compiled Code))
4XESTACKTRACE          at com/ibm/CORBA/iiop/ORB.process(ORB.java:1571(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/Connection.respondTo(Connection.java:2719(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/Connection.doWork(Connection.java:2584(Compiled Code))
4XESTACKTRACE          at com/ibm/rmi/iiop/WorkUnitImpl.doWork(WorkUnitImpl.java:62(Compiled Code))
4XESTACKTRACE          at com/ibm/ejs/oa/pool/PooledThread.run(ThreadPool.java:118(Compiled Code))
4XESTACKTRACE          at com/ibm/ws/util/ThreadPool$Worker.run(ThreadPool.java:1497(Compiled Code))
3XMTHREADINFO      "ORB.thread.pool : 50" (TID:0x420A0800, sys_thread_t:0x420B9388, state:B, native ID:0x003BE0EB) prio=5
4XESTACKTRACE          at com/kn/workplace/service/user/_EJSRemote0SLUserAdministrationServiceBean_d6083149_Tie.findEnhancedByUsername(_EJSRemote0SLUserAdministrationServiceBean_d6083149_Tie.java)
[Updated on: Wed, 22 December 2010 06:50]
Report message to a moderator
Re: Deadlock during serialization of entities [message #647147 is a reply to message #646152] Tue, 04 January 2011 13:23 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
I would recommend you vote for the bug and include you stack trace in the bug log.
You can set the collection class used for a mapping using a DescriptorCustomizer and mapping.useCollectionClass(ArrayList.class). Using a Set instead of List will also work.
You can change the global mapping default in ContainerPolicy.setDefaultContainerClass(ArrayList.class).
If you are using LAZY, IndirectList will still be used, which still uses Vector interally, so you could still have issues.
James : Wiki : Book : Blog
Re: Deadlock during serialization of entities [message #647958 is a reply to message #647147] Mon, 10 January 2011 10:33 Go to previous messageGo to next message
Do you mean IndirectList is still used for LAZY relations even if they are declared as Set?
[Updated on: Mon, 10 January 2011 10:33]
Re: Deadlock during serialization of entities [message #647985 is a reply to message #646152] Mon, 10 January 2011 12:07 Go to previous message
No, IndirectList is only used for List.
IndirectSet is used for Set, which uses HashSet, so will not have the synchronization issue that Vector has.
Previous Topic:Problem using a Converter to convert to list
Next Topic:Error During Delete: is mapped to a primary key column in the database. Updates are not allowed.
Current Time: Thu May 23 08:58:32 EDT 2013
Powered by FUDForum. Page generated in 0.01789 seconds
