Home » Eclipse Projects » BIRT » REMOTE .rptdocument file
| REMOTE .rptdocument file [message #647136] |
Tue, 04 January 2011 12:24  |
Sudesh Bulathsinhala Messages: 173 Registered: October 2010 |
hello,
we're have a requirement to load BIRT .rptdesign file within RAP at run-time and generate it's corresponding .rptdocument file dynamically. this .rptdocument file is refernced by webviewer within RAP to display the contents of the report.
following snippet invokes the .rptdocument file within webviewer.
WebViewer.display(rptdocument_file, browser, report_params)
where is the best path/url to store this dynamically created .rptdocument file during this process, which is required when invoking the Webviewer.display() method ?
the path/url needs to be valid when calling the report from remote RAP client session, so that the path reference is resolved appropriately at run-time.
any suggestion is highly appreciated.
regards,
sudesh
[Updated on: Tue, 04 January 2011 12:26] Report message to a moderator
| Re: REMOTE .rptdocument file [message #647144 is a reply to message #647136] |
Tue, 04 January 2011 12:52   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Sudesh,
Have you tried adding the rptdocument to the report_params map?
HashMap myparms = new HashMap();
HashMap emitmap = new HashMap();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
//myparms.put("RESOURCE_FOLDER_KEY", "c:/myresources");
myparms.put("ALLOW_PAGE", "false");
myparms.put("SHOW_PARAMETER_PAGE", "false");
myparms.put("DOCUMENT_NAME_KEY", rptdocument);
emitmap.put("Top Count", "6");
emitmap.put("Top Percentage", "15");
myparms.put("EMITTER_OPTIONS_KEY", emitmap);
//myparms.put("MAX_ROWS_KEY", "500");
WebViewer.display(rptdesign, browser, myparms);
Jason
On 1/4/2011 12:24 PM, Sudesh Bulathsinhala wrote:
> hello,
> this .rptdesign file is refernced by webviewer within RAP to display the
> run-time.
> regards,
> sudesh
Jason Weathersby
BIRT Exchange
| Re: REMOTE .rptdocument file [message #647232 is a reply to message #647144] |
Wed, 05 January 2011 03:58   |
hello jason,
i tried what you proposed, but didn't work.
i get the following error message :
This webpage is not available.
The webpage at http://127.0.0.1:63828/viewer/frameset?__document=C%3A%2Fins ight%2Fbirt%2Fws%2Fcom.argos.module.accounting%2Fac_account_ codes.rptdocument&__format=html&__svg=false&__lo cale=en_US&__timezone=Asia%2FColombo&__masterpage=tr ue&__rtl=false&__maxrows=500&__cubememsize=10&am p;am p;am p;am p;am p;am p;__resourceFolder=&__dpi=96&__parameterpage=false&a mp;a mp;a mp;a mp;a mp;a mp;Top%20Count=100&-682941018 might be temporarily down or it may have moved permanently to a new web address.
More information on this error
Below is the original error message
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error.
following is the code snippet i use to invoke the report document from RAP client
/* initialize config and engine instance */
final IReportEngine _engine;
final EngineConfig config = new EngineConfig();
final IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
config.setEngineHome("");
final IPlatformContext context = new PlatformServletContext(RWT.getSessionStore().getHttpSession( ).getServletContext());
config.setPlatformContext(context);
_engine = factory.createReportEngine(config);
/* variables to store both .rptdesign and .rptdocument files
* .rptdesign file exist where as .rptdocument file gets generated during the process */
String RPTDESIGN_URL = "C:/insight/ide/_rap target/eclipse/plugins/org.eclipse.birt.report.viewer_2.6.1. v20100913/birt/ac_account_codes.RPTDESIGN ";
String RPTDOCUMENT_URL = "C:/insight/ide/_rap target/eclipse/plugins/org.eclipse.birt.report.viewer_2.6.1. v20100913/birt/ac_account_codes.RPTDOCUMENT ";
try {
final IReportRunnable reportRunnable = _engine.openReportDesign(RPTDESIGN_URL);
final IRunTask runTask = engine.createRunTask(reportRunnable);
/* generate .rptdocument file in the specified location */
runTask.run(RPTDOCUMENT_URL);
runTask.close();
System.setProperty(WebViewer.REPORT_DEBUT_MODE, "true");
final HashMap reportParams = new HashMap();
reportParams.put("SERVLET_NAME_KEY", "frameset");
reportParams.put("FORMAT_KEY", "html");
reportParams.put("ALLOW_PAGE", Boolean.toString(true));
reportParams.put("SHOW_PARAMETER_PAGE", Boolean.toString(false));
reportParams.put("DOCUMENT_NAME_KEY", RPTDOCUMENT_URL);
/* invoke the .rptdocument file within the webviewer */
WebViewer.display(RPTDOCUMENT_URL, _browser, reportParams);
} catch (final EngineException e) {
e.printStackTrace();
the above code snippet works fine when RAP client is invoked from the local developer machine (where the RAP instance is running), otherwise when invoked from remote machine using the IP address (192.168.1.55) it throws the error message :
what might be causing this ?
i presume that the RAP renders the calling BIRT report in server and once the page is constructed, it send the page to the remote client. then again, i don't understand why the same works if i invoke from the development machine(SERVER) and not REMOTELY.
does the error message reference to localhost (127.0.0.1) has anything to do with this ?
everything works fine, if i invoke this from the LOCAL machine where RAP entrypoint is invoked.
is it all right to use full path url's for the .rptdcoument ?
ex.
kindly advise me if i'm missing something.
thanks & regards,
sudesh
[Updated on: Wed, 05 January 2011 04:34] Report message to a moderator
| Re: REMOTE .rptdocument file [message #647312 is a reply to message #647232] |
Wed, 05 January 2011 10:00   |
Sudesh,
Try adding this before your display:
WebViewer.startup();
also
try passing the rpt design as the first parameter. You are setting the
document in the params.
Jason
On 1/5/2011 3:58 AM, Sudesh Bulathsinhala wrote:
> hello jason,
> The webpage at
> RAP client
> /* variables to store both .rptdesign and .rptdocument files *
> the process */
> try {
> runTask.close();
Jason Weathersby
BIRT Exchange
| Re: REMOTE .rptdocument file [message #647571 is a reply to message #647467] |
Fri, 07 January 2011 01:32   |
hello jason,
i tried the following changes as you suggested and now the report does not run on the developer's machine either.
CODE :
WebViewer.display(RPTDESIGN_URL, _browser, reportParams);
I tried without WebViewer.Startup() as well..
LOG
!ENTRY org.eclipse.rap.ui 4 0 2011-01-07 11:57:34.365
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/birt/report/designer/ui/ReportPlugin
at org.eclipse.birt.report.viewer.utilities.ViewerClassPathHelp er.getWorkspaceClassPath(ViewerClassPathHelper.java:191)
at org.eclipse.birt.report.viewer.utilities.WebViewer.startWebA pp(WebViewer.java:756)
at org.eclipse.birt.report.viewer.utilities.WebViewer.display(W ebViewer.java:1004)
at org.eclipse.birt.report.viewer.utilities.WebViewer.display(W ebViewer.java:998)
at com.argos.sys.base.controller.widget.editor.CustomReportEdit orPart.invokeRunReport(CustomReportEditorPart.java:400)
at com.argos.sys.base.controller.widget.editor.CustomReportEdit orPart.access$0(CustomReportEditorPart.java:371)
at com.argos.sys.base.controller.widget.editor.CustomReportEdit orPart$1.handleEvent(CustomReportEditorPart.java:101)
at org.eclipse.swt.internal.widgets.UntypedEventAdapter.dispatc hEvent(UntypedEventAdapter.java:651)
at org.eclipse.swt.internal.widgets.UntypedEventAdapter.widgetS elected(UntypedEventAdapter.java:88)
at org.eclipse.swt.events.SelectionEvent.dispatchToObserver(Sel ectionEvent.java:194)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.jav a:44)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.ja va:161)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.jav a:201)
at org.eclipse.swt.widgets.Display.runPendingMessages(Display.j ava:1100)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1090)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2390)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2351)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 06)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:424)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.jface.internal.databinding.realmadapter.RealmAda pter.run(RealmAdapter.java:44)
at org.eclipse.rap.ui.internal.RealmAdapterHook.runWithDefault( RealmAdapterHook.java:48)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:427)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at com.argos.sys.client.entrypoint._rap.ClientEntryPoint.create UI(ClientEntryPoint.java:18)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:245)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:114)
at java.lang.Thread.run(Unknown Source)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.jav a:102)
Caused by: java.lang.ClassNotFoundException: org.eclipse.birt.report.designer.ui.ReportPlugin
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
... 30 more
one more thing i forgot to mention, our BIRT project is external and it produces .RPTDESIGN files, which we reference using FULL QUALIFIED PATH URL when accessing from RAP client.
thanks & regards,
sudesh
[Updated on: Fri, 07 January 2011 05:47] Report message to a moderator
| Re: REMOTE .rptdocument file [message #647582 is a reply to message #647571] |
Fri, 07 January 2011 02:49   |
hello jason,
when i invoke the report using the following snippet it works fine, only in the developer workstation..
but i get a warning, maybe the warning might help you a bit..
CODE
final String RPTDESIGN_URL = _reportFileFolderURL + _reportFileName
+ RPTDESIGN;
final String RPTDOCUMENT_URL = _reportFileFolderURL + _reportFileName
+ RPTDOCUMENT;
try {
final IReportEngine engine = CustomReportProvider.getInstance()
.getDefaultReportEngine();
final IReportRunnable reportRunnable = engine
/* this method call will set run time parameters */
decorateReportParams(runTask);
runTask.validateParameters();
runTask.close();
reportParams.put("ALLOW_PAGE", "true");
reportParams.put("SHOW_PARAMETER_PAGE", "false");
WARNING
Jan 7, 2011 12:36:42 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://138.fwk820791943/fontsConfig.xml cost 23ms
Jan 7, 2011 12:36:42 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory$2 run
INFO: register fonts in /usr/openwin/lib/locale/ja/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_13/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ru.ansi-1251/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_15/X11/fonts/TrueType cost:0ms
INFO: register fonts in d:/windows/fonts cost:0ms
INFO: register fonts in C:/windows/fonts cost:451ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/truetype cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ar/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/WINNT/fonts cost:1ms
INFO: register fonts in /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType cost:0ms
INFO: register fonts in C:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_2/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/tt cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/th_TH/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_7/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TTF cost:0ms
INFO: register fonts in /usr/openwin/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/truetype cost:0ms
INFO: register fonts in f:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in g:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_5/X11/fonts/TrueType cost:0ms
INFO: register fonts in f:/windows/fonts cost:1ms
INFO: register fonts in d:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/share/fonts/ko/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/windows/fonts cost:0ms
INFO: register fonts in /usr/share/fonts/zh_TW/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/ja/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_CN.GB18030/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/default/TrueType cost:0ms
INFO: register fonts in /usr/X/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/euro_fonts/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/hi_IN.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh.GBK/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/OTF cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_9/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW.BIG5/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_HK.BIG5HK/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/KOI8-R/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/zh_CN/TrueType cost:0ms
INFO: register fonts in g:/windows/fonts cost:0ms
INFO: load font config in bundleentry://138.fwk820791943/fontsConfig_win32.xml cost 2ms
Jan 7, 2011 12:36:43 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://138.fwk820791943/fontsConfig_pdf.xml cost 3ms
Jan 7, 2011 12:36:43 PM org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadDriverExtensions
INFO: Found JDBC driverinfo extension: driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
INFO: Found JDBC driverinfo extension: driverClass=org.eclipse.birt.report.data.oda.sampledb.Driver , connectionFactory=org.eclipse.birt.report.data.oda.sampledb. SampleDBJDBCConnectionFactory
Jan 7, 2011 12:36:43 PM org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadExtraDriver
SEVERE: DriverClassLoader failed to load class: org.postgresql.Driver
java.lang.ClassNotFoundException: org.postgresql.Driver
at org.eclipse.birt.core.framework.URLClassLoader.findClass1(UR LClassLoader.java:185)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:154)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClas sLoader.java:1)
at org.eclipse.birt.core.framework.URLClassLoader.findClass(URL ClassLoader.java:149)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.load ExtraDriver(JDBCDriverManager.java:919)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.find Driver(JDBCDriverManager.java:738)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.regi sterDriver(JDBCDriverManager.java:879)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.load AndRegisterDriver(JDBCDriverManager.java:862)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:246)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:212)
at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:235)
at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:160)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:250)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:165)
at org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:222)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:210)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:208)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:406)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:316)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:448)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr oduceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:617)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:80)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1876)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:260)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:85)
at com.argos.sys.base.controller.widget.editor.CustomReportEdit orPart.invokeRunReport(CustomReportEditorPart.java:385)
SEVERE: refreshUrlsWhenFail: true
SEVERE: driverClassPath: null
SEVERE: Registered URLs:
Jan 7, 2011 12:36:43 PM org.eclipse.birt.report.data.oda.jdbc.Connection open
WARNING: JDBC connection: org.postgresql.jdbc4.Jdbc4Connection@53a4c0e2 is opened
Jan 7, 2011 12:36:44 PM org.eclipse.birt.report.data.oda.jdbc.Connection close
WARNING: JDBC connection: org.postgresql.jdbc4.Jdbc4Connection@53a4c0e2 is closed
2011-01-07 12:36:44.052:INFO::jetty-6.1.x
2011-01-07 12:36:44.069:INFO::Started SelectChannelConnector@127.0.0.1:54554
Jan 7, 2011 12:36:44 PM org.apache.axis.utils.JavaUtils isAttachmentSupported
WARNING: Unable to find required classes (javax.activation.DataHandler and javax.mail.internet.MimeMultipart). Attachment support is disabled.
one more thing that i noticed.
if i send the RPTDESIGN_URL to the WebViewer as you suggested earlier, the report does not work with filter parameters i provide during runtime.
for instance report with only account_status = inactive fetches all the records irrespective of the status parameter we provide at runtime.
are we following the right approach when using BIRT reports in RAP ?
thanks & regards,
sudesh
[Updated on: Fri, 07 January 2011 05:50] Report message to a moderator
| Re: REMOTE .rptdocument file [message #647610 is a reply to message #647582] |
Fri, 07 January 2011 05:36   |
hello jason,
i did another interesting test case.
when i invoke the RAP client from the developer workstation(local host machine) using its host IP address as following.
(using the host IP address 192.168.1.54 instead of 127.0.0.1 from the same machine)
http://192.168.1.54 :58081/insight.default?startup=com.argos.sys.client.entrypoi nt._rap.entrypoint
i get error message dialog saying
"The viewing session is not available or has expired."
if the same is invoked using 127.0.0.1 instead of 192.168.1.54
things are working out and you could see the report preview on the WebViewer.
i'm sure this is causing the damage when invoked using IP address from REMOTE workstation, instead of using 127.0.0.1 (localhost)
WebViewer session has something to do with this, i assume.
let me know your thoughts on this.
thanks and regards,
sudesh
[Updated on: Fri, 07 January 2011 06:09] Report message to a moderator
Current Time: Sat May 25 04:24:56 EDT 2013
Powered by FUDForum. Page generated in 0.02401 seconds
