Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » Project properties Java ME->Library: how to add libraries?
Project properties Java ME->Library: how to add libraries? [message #647615] Fri, 07 January 2011 06:19 Go to next message
leniviy  is currently offline leniviy
"This page enables you to select the libraries..."
However the list is empty. How to add libraries here?
I assume it's the same thing as Netbeans Project properties "Build->Libraries & Resources". If you add projects or jars there, their classes and resources end up in the generated jar.
[Updated on: Fri, 07 January 2011 06:44]
Report message to a moderator
Re: Project properties Java ME->Library: how to add libraries? [message #647619 is a reply to message #647615] Fri, 07 January 2011 07:10 Go to previous messageGo to next message
Diego Madruga Sandin is currently offline Diego Madruga Sandin
Member
These libs are included via an extension point.
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .mtj.doc.isv/html/guide/ExternalLibrary/ExternalLibrary.html
Diego
Re: Project properties Java ME->Library: how to add libraries? [message #647621 is a reply to message #647615] Fri, 07 January 2011 07:33 Go to previous message
I see. It's probably not the feature I need.
[Updated on: Fri, 07 January 2011 07:39]
Previous Topic:NOKIA NFC WITH ECLIPSE
Next Topic:How to generate JAR file which runs on mobile phone?
Current Time: Wed May 29 02:48:32 EDT 2013
Powered by FUDForum. Page generated in 0.02095 seconds
