| [MDT-OCL] Defining OCL constraints [message #647482] |
Thu, 06 January 2011 10:42  |
Currently i am aware of process of defining the OCL constraints in EMF Model and using them for validation.
My questions:
1) Is there any way OCL constrains can be defined in some place other then EMF Model ? (Motivation is the developers does not want people to touch their emf model. quite personal to them )
2) MDT OCL, i think support only EMF and UML. What has to be done to implement it for some other MOF based metamodel ? Some guidance will be helpful
3) We have a situation where we convert this MOF based metamodel into EMF model dynamically. So, if i am able to define OCL constraints on MOF based metamodel, can i somehow re-use them EMF model ?
These questions might sound very abstract. Sorry for that, but i am just starting with OCL and this new business scenario.
Ashwani Kr Sharma
[Updated on: Thu, 06 January 2011 10:43] Report message to a moderator
| Re: [MDT-OCL] Defining OCL constraints [message #647516 is a reply to message #647482] |
Thu, 06 January 2011 13:16  |
Ed Willink Messages: 3191 Registered: July 2009 |
[Please use the OCL newsgroup for OCL queries.]
1) MDT/OCL supports Complete OCL (Clause 12 of the OMG specification)
which allows a complementary document for any meta-model. MDT/OCL 1.3.0
allows such documents to be parsed and evaluated programmatically
against Ecore or UML meta-models. MDT/OCL 3.0 Examples provides an
Xtext-based Complete OCL editor for Ecore meta-models that is useful but
far from perfect. Expect much better in MDT/OCL 3.1.0.
2) Work in progress is hiding the Ecore/UML distinctions through use of
a neutral Pivot Model. Other meta-modeling dialects can be supported by
alternate to/from Piovot model converters.
3) The pivot model support should be 100% OMG compliant so use of your
MOF constraints should be no problem.
[The pivot model will appear in the Indigo MDT/OCL 3.1.0 release as
Examples plugins that will be promoted to become the preferred API in
MDT/OCL 4.0 in Indigo+1.]
Ed Willink
On 06/01/2011 15:42, Ashwani Kr Sharma wrote:
> My questions:
> touch their emf model. quite personal to them :) )
> be helpful
> These questions might some very abstract. Sorry for that, but i am
> just starting with OCL and this new business scenario. :)
> Ashwani Kr Sharma
FUDForum. Page generated in 0.01679 seconds
