Home » Eclipse Projects » DSDP - Target Management » SSH Connection Refused
SSH Connection Refused [message #647211] Wed, 05 January 2011 00:40 Go to next message
Mark  is currently offline Mark
Hi.
I created a SSH Only connection to hook up via sftp.
I use something like:
$ ssh -luname -L6666:fileserverip:22 exthost.com
after connecting, on my local machine the following works:
$ ssh -luname -p6666 127.0.0.1
In RSE, I've set up the ssh only connection with its hostname=127.0.0.1 and the port in Sftp Files>Subsystem to 6666. However, I get the following immediately after I try to connect:
'Connect (RSE SubSystem Operation:)' has encountered a problem.
Session.connect: java.net.ConnectException: Connection refused.
I can't figure out it. I'm on mac os x 10.5.8.
Mark
Re: SSH Connection Refused [message #647397 is a reply to message #647211] Wed, 05 January 2011 19:24 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
Hm, this works fine for me on Linux RHEL4 with RSE 3.3M4.
"Connection Refused" seems to point to a Firewall issue, or invalid port being used.
HTH,
Martin
Re: SSH Connection Refused [message #647405 is a reply to message #647211] Wed, 05 January 2011 22:28 Go to previous messageGo to next message
I tried it directly on a network with the server straight on there. The connection worked on port 22, even when I set the port to 6666. So it seems like the port isn't set, and continues to try to connect through port 22.
I checked and the setting is there. Not sure how to set it otherwise.
(PS I also tried connecting to the same server with Terminal inside eclipse, that worked too).
Re: SSH Connection Refused [message #647409 is a reply to message #647397] Thu, 06 January 2011 00:08 Go to previous messageGo to next message
Re: SSH Connection Refused [message #647411 is a reply to message #647397] Thu, 06 January 2011 00:28 Go to previous message
Ok, I've fixed it.
Seems like I didn't use the update site and had downloaded an obscure version of RSE.
After using the update site, it had the latest plugin and even the icons looked different. All is well Very Happy. Thanks!
Previous Topic:Connection errors using RSE
Next Topic:Birt Report Viewer content
Current Time: Wed May 29 03:48:15 EDT 2013
Powered by FUDForum. Page generated in 0.01510 seconds
