Home » Eclipse Projects » Plugin Development Environment (PDE) » How to change the name of Custom Menu Item on selecting the parent menu(Plugin Development)
icon5.gif  How to change the name of Custom Menu Item on selecting the parent menu [message #647290] Wed, 05 January 2011 10:18 Go to next message
Dharmang  is currently offline Dharmang
I wan to change the name of my Custom Menu item on clicking the parent Menu.
For that I am using following code:
IWorkbench workbench = Activator.getDefault().getWorkbench(); //PlatformUI.getWorkbench();
Menu menubar = workbench.getActiveWorkbenchWindow().getShell().getMenuBar() ;
menubar.addMenuListener(new MenuListener() {
public void menuShown(MenuEvent arg0) {
public void menuHidden(MenuEvent arg0) { }
but it never calls the public void menuShown(MenuEvent arg0) {} method while the menuHidden method is working fine.
What should I do? Any work around?
Thanks in advance.
Re: How to change the name of Custom Menu Item on selecting the parent menu [message #647359 is a reply to message #647290] Wed, 05 January 2011 13:44 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
You want org.eclipse.platform
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to change the name of Custom Menu Item on selecting the parent menu [message #647360 is a reply to message #647290] Wed, 05 January 2011 13:44 Go to previous messageGo to next message
Sorry, you want eclipse.platform
PW
Paul Webster
Re: How to change the name of Custom Menu Item on selecting the parent menu [message #647414 is a reply to message #647360] Thu, 06 January 2011 02:15 Go to previous messageGo to next message
Hi Paul,
You mean I need to add eclipse.platform as dependencies and then it will work?
If it is so then I tried the same but it is still not working.
Dharmang
Re: How to change the name of Custom Menu Item on selecting the parent menu [message #647445 is a reply to message #647414] Thu, 06 January 2011 07:29 Go to previous message
Sorry, I should have been more clear. Menus are a contribution
controlled by the platform, so you should ask your question in the
eclipse.platform newsgroup.
PW
Paul Webster
Previous Topic:Dynamic target platform
Next Topic:Synchronize product definition to plugin.xml in headless build?
Current Time: Sat May 18 12:40:26 EDT 2013
Powered by FUDForum. Page generated in 0.01620 seconds
