| creation of .chk files [message #646918] |
Mon, 03 January 2011 02:07 |
Madhushree S Messages: 19 Registered: September 2010 |
Junior Member |
Hi All,
I want to create a check file in a specified xtext project. Firstly i create a xtext project. then i unselect the project. secondly after unselecting i goto File>new>other and select "Check File", the wizard appears. even though no project has been selected, the finish button is enabled.
I want to know if its a bug.???? i'm using helios(3.6) xtext sdk.
so if i create myWizard by extending "check file" wizard, finish button will be enabled even though no project is selected. please hint me if there ia a solution.
Madhu
FUDForum. Page generated in 0.01953 seconds
