Home » Eclipse Projects » EclipseLink » problems using metamodel generator in Eclipse
problems using metamodel generator in Eclipse [message #646732] Thu, 30 December 2010 11:09 Go to next message
Martin Geisse is currently offline Martin Geisse
I am trying to get the EclipseLink metamodel generator working from within Eclipse. To do this, I have enabled annotation processing in the Java compiler options and added the following JARs:
- eclipselink-jpa-modelgen_2.1.2.v20101206-r8635.jar
- javax.persistence_2.0.1.v201006031150.jar
- eclipselink.jar
Eclipse generates a folder for the generated source code in the project folder (called "generated" -- I changed this from the default) but no classes inside that folder.
Thanks in advance for any help.
Code for the entity class:
 * Copyright (c) 2010 Martin Geisse
 * This file is distributed under the terms of the MIT license.
package name.martingeisse.leckermittag.experiment;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
 * A simple test entity for EclipseLink experiments.
@Entity
public class Todo {
	 * the id
	private Long id;
	 * the summary
	private String summary;
	 * the description
	private String description;
	 * Constructor.
	public Todo() {
	 * Getter method for the id.
	 * @return the id
	@Id
	@GeneratedValue(strategy = GenerationType.IDENTITY)
	public Long getId() {
		return id;
	 * Setter method for the id.
	 * @param id the id to set
	public void setId(Long id) {
		this.id = id;
	 * Getter method for the summary.
	 * @return the summary
	public String getSummary() {
		return summary;
	 * Setter method for the summary.
	 * @param summary the summary to set
	public void setSummary(String summary) {
		this.summary = summary;
	 * Getter method for the description.
	 * @return the description
	public String getDescription() {
		return description;
	 * Setter method for the description.
	 * @param description the description to set
	public void setDescription(String description) {
		this.description = description;
	public String toString() {
		return "Todo [summary=" + summary + ", description=" + description + "]";
(project)/src/META-INF/persistence.xml
<?xml version="1.0" encoding="UTF-8" ?>
<persistence xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd" version="2.0" xmlns="http://java.sun.com/xml/ns/persistence">
	<persistence-unit name="todos" transaction-type="RESOURCE_LOCAL">
		<class>name.martingeisse.leckermittag.experiment.Todo</class>
		<properties>
			<!-- <property name="javax.persistence.jdbc.driver" value="org.apache.derby.jdbc.EmbeddedDriver" /> -->
			<!-- <property name="javax.persistence.jdbc.url" value="jdbc:derby:/home/vogella/databases/simpleDb;create=true" /> -->
			<property name="javax.persistence.jdbc.url" value="jdbc:postgresql://localhost/leckerMittag" />
			<property name="javax.persistence.jdbc.user" value="postgres" />
			<property name="javax.persistence.jdbc.password" value="postgres" />
			<!-- EclipseLink should create the database schema automatically -->
			<!-- <property name="eclipselink.ddl-generation" value="create-tables" /> -->
			<!-- <property name="eclipselink.ddl-generation.output-mode" value="database" /> -->
		</properties>
	</persistence-unit>
</persistence>
(project)/src/META-INF/orm.xml
<entity-mappings version="1.0"
	xmlns="http://java.sun.com/xml/ns/persistence/orm"
	xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm orm_1_0.xsd">
	<description>description here</description>
	<persistence-unit-metadata>
		<persistence-unit-defaults>
			<delimited-identifiers />
		</persistence-unit-defaults>
	</persistence-unit-metadata>
</entity-mappings>
Re: problems using metamodel generator in Eclipse [message #646737 is a reply to message #646732] Thu, 30 December 2010 11:47 Go to previous messageGo to next message
Neil Hauge is currently offline Neil Hauge
One thing you could try as an alternative would be the metamodel generation capabilities available in Dali Java Persistence Tools. These tools are integrated directly into Eclipse and do not require additional compiler configuration.
See the section called "JPA 2.0 Canonical Metamodel Generation" at the link below for more info.
http://www.eclipse.org/webtools/releases/3.2.0/NewAndNotewor thy/jpa.php
Dali is available via the Helios Software Site and is a part of the Web Tools project. It is included in the Helios Java EE package.
For more info on Dali - http://eclipse.org/webtools/dali/
Neil
Re: problems using metamodel generator in Eclipse [message #646765 is a reply to message #646737] Thu, 30 December 2010 14:42 Go to previous message
That works. Thank you!
Previous Topic:ClassNotFoundException on create of TypedQuery
Next Topic:Using OneToMany or ManyToOne . A Performance issue
Current Time: Sat May 25 13:39:35 EDT 2013
Powered by FUDForum. Page generated in 0.02220 seconds
