| FK value setting in a ManyToOne relationship [message #646656] |
Wed, 29 December 2010 11:51  |
No real name Messages: 1 Registered: December 2010 |
Junior Member |
Hi, I have a OneToMany relationship between entities Contact and Email. When I create a Contact and add to him 1 or more Email I need to set the FK column in Email table to the right Contact of that email...
I tried this:
@Entity
class Contact{
@Id
@OneToMany(mappedBy="contact", cascade=CascadeType.ALL)
private Set<ContactEmail> email;
@Entity
class Email{
@Id
@ManyToOne
@JoinColumn(name="CONTACT_ID")
private Contact contact;
When in my test package I call:
em.persist(contact); //(where contact has 2 emails associated)
it creates 1 contact, 2 emails records but the FK column "CONTACT_ID" is empty...
how can I set its value with the right Contact ID of that email?
thanks in advance!
[Updated on: Wed, 29 December 2010 11:53] Report message to a moderator
| Re: FK value setting in a ManyToOne relationship [message #647088 is a reply to message #646656] |
Tue, 04 January 2011 09:54  |
Chris Delahunt Messages: 862 Registered: July 2009 |
Your object model implies that each Email in the list of Contact's email must have a Contact. Are you setting the Email->Contact relationship? This relationship is what controls the foreign key in the Email table, not the Contact->Email relationship. JPA requires that applications set both sides of a relationship if it is bidirectional so that the object model is in synch with the database.
Best Regards,
Chris
FUDForum. Page generated in 0.15937 seconds
