Home » Eclipse Projects » BIRT » BIRT Problem in Export into Excel sheet(BIRT Problem in Export into Excel sheet)
BIRT Problem in Export into Excel sheet [message #646464] Fri, 24 December 2010 08:48 Go to next message
Debadatta Mishra is currently offline Debadatta Mishra
We have integrated the BIRT web application in our application.
When we add more coulmns in the BIRT design report and we export the report into excel format, the cells are shrinking. As per our requirements, the cells should not be shrinked and should take the width of the data. Please suggest us in this regard. Is there any configuration to set the width of the column ?
Re: BIRT Problem in Export into Excel sheet [message #646558 is a reply to message #646464] Mon, 27 December 2010 12:17 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
What version of BIRT are you using? Are you setting the width in the
report design?
Jason
Jason Weathersby
BIRT Exchange
Re: BIRT Problem in Export into Excel sheet [message #649280 is a reply to message #646558] Tue, 18 January 2011 09:52 Go to previous messageGo to next message
Nolo  is currently offline Nolo
I also have the same problem. I'm using Birt 232.
Re: BIRT Problem in Export into Excel sheet [message #894602 is a reply to message #646464] Mon, 09 July 2012 15:24 Go to previous messageGo to next message
Rama Krishna is currently offline Rama Krishna
I'm facing this problem even with the latest version of BIRT. Isn't this fixed so far.
HTML version appears fine after I have chosen Auto Layout as the Layout Preference. But the excel format still has all the cells shrunk. Please let me know if any one has the solution.
Re: BIRT Problem in Export into Excel sheet [message #894644 is a reply to message #894602] Mon, 09 July 2012 19:57 Go to previous message
Michael Williams is currently offline Michael Williams
What version are you saying is the latest version? In 4.2 and 3.7, if I have auto layout selected and set the width of all columns, I get the expected output. Are you sure you're changing all the column's widths? Or just some?
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:how to change excel sheet name?
Next Topic:Incorrect pagination for a report with chart and tabular data.
Current Time: Wed May 22 23:13:28 EDT 2013
Powered by FUDForum. Page generated in 0.04547 seconds
