Home » Eclipse Projects » Virgo » password "admin" is not accepted for jmx remote authentication(changed default "springsource" password for "admin" user to "admin" in org.eclipse.virgo.kernel.users.properties and tried to connect remote jconsole by giving "admi)
password "admin" is not accepted for jmx remote authentication [message #646141] Wed, 22 December 2010 05:50 Go to next message
Thiru  is currently offline Thiru
changed default "springsource" password for "admin" user to "admin" in org.eclipse.virgo.kernel.users.properties and tried to connect remote jconsole by giving "admin" as username and "admin" as password, but it is not connecting
Is this is a limitation in virgo web server?
[Updated on: Wed, 22 December 2010 05:51]
Report message to a moderator
Re: password "admin" is not accepted for jmx remote authentication [message #646167 is a reply to message #646141] Wed, 22 December 2010 09:00 Go to previous messageGo to next message
Chris Frost is currently offline Chris Frost
This should be working.
Were you able to log on in the first place with the springsource password?
Have you consulted ( http://www.eclipse.org/virgo/documentation/virgo-documentati on-2.1.0.RELEASE/docs/virgo-user-guide/html/ch04s04.html). To achieve what you have described you should have, just to confirm.
# User definitions
user.admin=admin
# Role definitions
role.admin=admin
Finally, could you tell me if the Admin Console picked up the new password, could you login to that?
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
[Updated on: Wed, 22 December 2010 09:01]
Re: password "admin" is not accepted for jmx remote authentication [message #646203 is a reply to message #646167] Wed, 22 December 2010 11:33 Go to previous messageGo to next message
Hi Chris,
Thanks for your reply.
I have done exactly what u mentioned. But after this change remote jconsole is not connecting with username "admin" and password "admin".
Thiru
Re: password "admin" is not accepted for jmx remote authentication [message #646229 is a reply to message #646203] Wed, 22 December 2010 14:30 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
I've tried the scenario and this worked ok for me.
What I've done:
1) changed user from springsource to admin
2) started Virgo with -jmxport 9090
3) started jconsole.bat
4) choose remote connection and entered localhost:9090
5) filled admin / admin in user / password fields
jconsole connected as expected
Is this what you are trying to do or you have something else in mind?
Re: password "admin" is not accepted for jmx remote authentication [message #646444 is a reply to message #646229] Fri, 24 December 2010 05:15 Go to previous message
Hi All,
Its is working fine.
Not sure why it was not working previously, may bedue to some port conflict.
Thiru
Previous Topic:ArtifactGenerationException: Manifest ill-formed.
Next Topic:Re: Virgo integration with ECF remote services
Current Time: Mon May 20 17:50:59 EDT 2013
Powered by FUDForum. Page generated in 0.02011 seconds
