| The selected driver cannot parse the given JNDI Data Source URL. [message #646413] |
Thu, 23 December 2010 15:08  |
Tony Missing name Messages: 3 Registered: December 2010 |
Junior Member |
I am new to birt report. My intention is to use JNDI to connect to my Oracle data source.
Birt V2.6.1
Eclipse 3.6.1
Weblogic 10.3
What I did:
- create a report
- add jndi.properties to [eclipse directory]\plugins\org.eclipse.birt.report.data.oda.jdbc_2.6 .1.v20100909
- add ojdbc driver under [eclipse directory]\plugins\org.eclipse.birt.report.data.oda.jdbc_2.6 .1.v20100909\dirver
- in birt plugin when creating a datasource, I selected the driver, and entered my JNDI name into JNDI URL
- click TEST CONNECTION, then i got
org.eclipse.birt.report.data.oda.jdbc.JDBCException: The selected driver cannot parse the given JNDI Data Source URL.
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.test Connection(JDBCDriverManager.java:573)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.t estConnection(DriverLoader.java:120)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.t estConnection(DriverLoader.java:133)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.testConnection(JDBCSelectionPageHelper.java:687 )
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.access$7(JDBCSelectionPageHelper.java:655)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper$7.widgetSelected(JDBCSelectionPageHelper.java:5 78)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open( BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.providers.EditableD ataSourceNodeProvider.performEdit(EditableDataSourceNodeProv ider.java:73)
at org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:442)
at org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:90)
at org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:214)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:824)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:822)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1421)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1225)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:238)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:235)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Any Help is appreciated
FUDForum. Page generated in 0.04514 seconds
