| Re: Error on succesful jet.transform Ant task [message #646136 is a reply to message #494235] |
Wed, 22 December 2010 04:40  |
Elias Balasis Messages: 11 Registered: July 2009 |
Junior Member |
On 10/29/2009 6:47 PM, Miguel Angel Garcia de Dios wrote:
> Hi everyone,
> I have Eclipse Galileo with M2T(JET) updatedwith the latest stable
> release and I have that problem even without any <c:log>. I mean,
> independenly of my tampleates, I always obtain the same message of
> "successful execution". I remember that a few months ago this problem
> does not exist. For me, this is a problem because the message causes
> that the exution of my Ant build file is interrupted and finished after
> the "jet.transform" task so, obviously the subsecuent tasks and targets
> are not executed.
> Does anybody know anything about this?
> Thank you in advance.
> fabio boldrini wrote:
>> i found a workaround.
>> the message successful execution with message was caused by <c:log>.
>> When i rip the log out, the tranformation ended with a Successful
>> Execution and ant exit without error.
>> I had submited the bug with this explanation.
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=278368
>> Bye
>> Paul Elder wrote:
>>> Fabio:
>>> I suggest you file a bugzilla:
>> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=norma l&bug_status=NEW&bug_file_loc=http%3A%2F%2F&shor t_desc=&comment=&commentprivacy=0&keywords=& dependson=&blocked=&maketemplate=Remember%20values%2 0as%20bookmarkable%20template&form_name=enter_bug&as signed_to=m2t.jet-inbox%40eclipse.org&qa_contact=
>>> JET is in shutdown mode for Galileo, so I'm not sure I could do
>>> anything about this until Galileo SR1.
>>> Paul
Same here, using Eclipse 3.5.2 and JET 1.0.2, success produces failure
with message "Successful completion" and build stops prematurely
I hope JET next release however compatible with Eclipse 3.6 functions
correctly. However, the set of tools I am using are not yet compliant
with Eclipse 3.6
FUDForum. Page generated in 0.01711 seconds
