Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » JUnit Tests(JUnit Tests)
JUnit Tests [message #643472] Mon, 06 December 2010 19:27 Go to next message
James Kaufman is currently offline James Kaufman
All JUnit tests are now back online. Older tests now all run as JUnit-Plugin tests. Some tests have moved so developers should be sure to get latest and look for new plugins in SVN.
We are also discussing a framework for integration testing. The idea is to provide a folder where developers may contribute validated STEM projects. Any enclosed scenarios would then be run as an integration tests. The folders would contain (in Recorded Simulations) a validated log of the expected results so the execution can be checked against that log. This would permit creation of new integration tests without the need for new code.
Re: JUnit Tests [message #646064 is a reply to message #643472] Tue, 21 December 2010 13:42 Go to previous message
Werner Keil is currently offline Werner Keil
I just got my Hudson instance set up for UOMo.
I understand, all of STEM may be more complex in building, but would at
least parts like these tests also make sense in a CI environment?
Previous Topic:Creating and importing custom graphs in Pajek Format
Next Topic:Earth science data file names changed
Current Time: Wed May 22 21:15:49 EDT 2013
Powered by FUDForum. Page generated in 0.06791 seconds
