| DataException: The new column name or alias... [message #646002] |
Tue, 21 December 2010 09:35  |
Helmut Messages: 2 Registered: December 2010 |
Junior Member |
Hi all,
what does this error message means?
"The new column name or alias abc is already used by the column at index x"
I get this message several times when I run my report against another database, not the one used to create the report. The tables are identical but the column order is different.
I'm using Birt 2.5.2.
Please help
Helmut
[Updated on: Tue, 21 December 2010 09:57] Report message to a moderator
| Re: The new column name or alias... [message #646052 is a reply to message #646039] |
Tue, 21 December 2010 13:07  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
This sounds like a bug. Can you log it?
Jason
On 12/21/2010 12:06 PM, swaczinna@wlp-systems.de wrote:
> Hi Jason!
> No, the query ist really simple:
> select *
> from hsverf_dreh
> where hsv_f_pan = ?
> and hsv_geloescht = 0
> order by hsv_sort
> In the meantime I found a workaround. I listed all columns in the select
> clause instead of using *. Now the column order is always the same. But
> using * is more convenient. I would think of a bug in BIRT 2.5.2.
> Regards
> Helmut
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01693 seconds
