Home » Eclipse Projects » XML Schema Definition (XSD) » The content model with 10,006 states is too large
| The content model with 10,006 states is too large [message #64570] |
Tue, 18 October 2005 04:22  |
Originally posted by: NOpcooperSPAM.uk.ibm.com
--------------020007080906040400020902
Content-Type: text/plain; charset=us-ascii; format=flowed
I'm having trouble validating what appears to me to be a perfectly valid
schema. The problem seems to be to do with my minOccurs and maxOccurs
attributes for an element with complex content.
When they are set to minOccurs=5000 maxOccurs=5000 I see the message in
the subject string above. When they are set to minOccurs=1
maxOccurs=5000 then everything is fine. Similarly, minOccurs=4000 and
maxOccurs=4000 works (but is suprisingly slow).
Is there some fundamental limitation with XSD that I'm missing here?
I've attached the sample XSD and a test program.
Paul.
Content-Type: text/xml;
name="example.xsd"
Content-Disposition: inline;
filename="example.xsd"
<xsd:schema
targetNamespace="http://www.example.com"
xmlns:tns="http://www.example.com"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:complexType name="ct">
<xsd:sequence>
<xsd:element name="sortie">
<xsd:complexType mixed="false">
<xsd:sequence>
<xsd:element maxOccurs="5000" minOccurs="5000"
name="s_poste_item">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="s_logonid">
<xsd:simpleType>
<xsd:restriction base="xsd:string">
<xsd:maxLength value="8"/>
<xsd:whiteSpace value="preserve"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_societe">
<xsd:simpleType>
<xsd:maxLength value="1"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_ensemble">
<xsd:simpleType>
<xsd:maxLength value="2"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_surservice">
<xsd:simpleType>
<xsd:maxLength value="3"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_services">
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_responsab">
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_fonction">
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_types">
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:element name="s_nom_prenom">
<xsd:simpleType>
<xsd:maxLength value="20"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="example" type="tns:ct"/>
</xsd:schema>
name="example.java"
filename="example.java"
import java.util.Iterator;
import java.io.File;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
import org.eclipse.xsd.XSDDiagnostic;
public class example
public static void main(String[] args)
try
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put("*", new XSDResourceFactoryImpl());
resourceSet.getLoadOptions().put(
XSDResourceImpl.XSD_TRACK_LOCATION, Boolean.TRUE);
XSDResourceImpl xsdMainResource = (XSDResourceImpl)
resourceSet.getResource(URI.createFileURI(
new File("example.xsd").getCanonicalFile().toString()),
true);
xsdMainResource.getSchema().validate();
Iterator diagnostics =
xsdMainResource.getSchema().getAllDiagnostics().iterator();
while (diagnostics.hasNext())
XSDDiagnostic diagnostic =
(XSDDiagnostic) diagnostics.next();
System.out.println("Message: " + diagnostic);
catch (Exception e)
System.out.println("Caught this: " + e);
--------------020007080906040400020902--
| Re: The content model with 10,006 states is too large [message #64595 is a reply to message #64570] |
Tue, 18 October 2005 12:40   |
--------------090107000305000802080403
Paul,
In order to validate the Unique Particle Attribute rule, the XSD model
builds a finite state machine and that machine can get very large very
quickly. An <all> content model is the worst example of this since it
will produce n! (factorial) states. To prevent disaster (exhausting
memory) we limit the size of the machine we will produce and when that
limit is reached we produce the message your see. It strikes me that
the message should really be a warning and not an error, since it just
means there is a constraint that isn't being validated, not that the
schema is bad...
> valid schema. The problem seems to be to do with my minOccurs and
> maxOccurs attributes for an element with complex content.
> in the subject string above. When they are set to minOccurs=1
> Paul.
><?xml version="1.0" encoding="UTF-8"?>
><xsd:schema
> <xsd:sequence>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
></xsd:schema>
> try
> true);
> catch (Exception e)
<html>
<head>
</head>
Paul,<br>
<br>
since it will produce n! (factorial) states. To prevent disaster
(exhausting memory) we limit the size of the machine we will produce
and when that limit is reached we produce the message your see. It
strikes me that the message should really be a warning and not an
error, since it just means there is a constraint that isn't being
validated, not that the schema is bad...<br>
<br>
<br>
Paul Cooper wrote:
<blockquote cite="middj2b84$45s$1@news.eclipse.org" type="cite">I'm
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Paul.
<br>
<pre wrap="">
<hr size="4" width="90%">
<xsd:schema
targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://www.example.com">"http://www.example.com"</a>
xmlns:tns=<a class="moz-txt-link-rfc2396E" href="http://www.example.com">"http://www.example.com"</a>
xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>>
<xsd:sequence>
<xsd:sequence>
<xsd:complexType>
<xsd:sequence>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema></pre>
<pre wrap="">
try
true);
catch (Exception e)
</pre>
</blockquote>
<br>
</body>
</html>
--------------090107000305000802080403--
| Re: The content model with 10,006 states is too large [message #64818 is a reply to message #64595] |
Wed, 26 October 2005 07:38   |
Thanks for the response, I'll be able to code around this in my own
logic. However, it turns out that there is another related problem. If I
change the testcase below to indicate maxOccurs="4997" minOccurs="4997"
then instead of getting the error message the following NPE is thrown:
org.eclipse.xsd.impl.XSDParticleImpl$XSDNFA.getDiagnostics(X SDParticl
eImpl.java:1780)
org.eclipse.xsd.impl.XSDModelGroupImpl.validateRoot(XSDModel GroupImpl
..java:600)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.validate(X SDComplex
TypeDefinitionImpl.java:1309)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.validate(XSDCo ncreteCom
ponentImpl.java:541)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.validate(XSDE lementDec
larationImpl.java:752)
org.eclipse.xsd.impl.XSDParticleImpl.validate(XSDParticleImp l.java:58
4)
org.eclipse.xsd.impl.XSDModelGroupImpl.validate(XSDModelGrou pImpl.jav
a:487)
4)
TypeDefinitionImpl.java:1305)
org.eclipse.xsd.impl.XSDSchemaImpl.validate(XSDSchemaImpl.ja va:1498)
at example.main(example.java:30)
I'm guessing this is not the expected behaviour :-)
Paul.
Ed Merks wrote:
> Paul,
> schema is bad...
>> Thanks,
>> Paul.
>><xsd:schema
>> <xsd:sequence>
>> <xsd:sequence>
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>></xsd:schema>
>> try
>> true);
>> catch (Exception e)
| Re: The content model with 10,006 states is too large [message #64840 is a reply to message #64818] |
Wed, 26 October 2005 08:00  |
Paul,
No, you guess correctly. ;-) Please open a bugzilla and I'll fix it for
tomorrow's build.
> I change the testcase below to indicate maxOccurs="4997"
> minOccurs="4997" then instead of getting the error message the
> java.lang.NullPointerException
> at
> eImpl.java:1780)
> at
> ..java:600)
> at
> at
> at
> at
> at
> 4)
> at
> at
> a:487)
> at
> at
> 4)
> at
> at
> at
> at
> Paul.
> Ed Merks wrote:
>> Paul,
>> model builds a finite state machine and that machine can get very
>> large very quickly. An <all> content model is the worst example of
>> this since it will produce n! (factorial) states. To prevent
>> disaster (exhausting memory) we limit the size of the machine we will
>> produce and when that limit is reached we produce the message your
>> see. It strikes me that the message should really be a warning and
>> not an error, since it just means there is a constraint that isn't
>> being validated, not that the schema is bad...
>>> and maxOccurs=4000 works (but is suprisingly slow).
>>> Thanks,
>>> Paul.
>>> <xsd:schema targetNamespace="http://www.example.com"
>>> <xsd:sequence>
>>> <xsd:sequence>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> try
>>> { ResourceSet resourceSet = new
>>> ResourceSetImpl();
>>> new
>>> true);
>>> { XSDDiagnostic diagnostic =
>>> catch (Exception e)
| Re: The content model with 10,006 states is too large [message #596982 is a reply to message #64570] |
Ed Merks Messages: 24553 Registered: July 2009 |
Paul,
schema is bad...
> Paul.
><xsd:schema
> <xsd:sequence>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
></xsd:schema>
> try
> true);
> catch (Exception e)
<html>
<head>
</head>
Paul,<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Paul.
<br>
<pre wrap="">
<xsd:schema
<xsd:sequence>
<xsd:sequence>
<xsd:complexType>
<xsd:sequence>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema></pre>
<pre wrap="">
try
true);
catch (Exception e)
</pre>
</blockquote>
<br>
</body>
</html>
| Re: The content model with 10,006 states is too large [message #597081 is a reply to message #64595] |
Paul Cooper Messages: 11 Registered: July 2009 |
Junior Member |
eImpl.java:1780)
..java:600)
4)
a:487)
4)
Paul.
Ed Merks wrote:
> Paul,
> schema is bad...
>> Thanks,
>> Paul.
>><xsd:schema
>> <xsd:sequence>
>> <xsd:sequence>
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> <xsd:simpleType>
>> </xsd:restriction>
>> </xsd:simpleType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>></xsd:schema>
>> try
>> true);
>> catch (Exception e)
| Re: The content model with 10,006 states is too large [message #597091 is a reply to message #64818] |
Paul,
tomorrow's build.
> at
> eImpl.java:1780)
> at
> ..java:600)
> at
> at
> at
> at
> at
> 4)
> at
> at
> a:487)
> at
> at
> 4)
> at
> at
> at
> at
> Paul.
> Ed Merks wrote:
>> Paul,
>>> Thanks,
>>> Paul.
>>> <xsd:sequence>
>>> <xsd:sequence>
>>> <xsd:complexType>
>>> <xsd:sequence>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> <xsd:simpleType>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:element>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> </xsd:schema>
>>> try
>>> ResourceSetImpl();
>>> new
>>> true);
>>> catch (Exception e)
Current Time: Thu May 23 18:15:22 EDT 2013
Powered by FUDForum. Page generated in 0.01873 seconds
