| Connection errors using RSE [message #645454] |
Fri, 17 December 2010 05:01  |
Martin Tauber Messages: 93 Registered: July 2009 |
Member |
I am using RSE to access files on a remote system (in this case solaris)
using the Filesystem implementation of RSE so that the access is
transperant to my application. Sometimes, when I connect I get the
attached stackdump (on this machine this is reproducable).
In the stackdump I get the message:
Caused by: org.eclipse.core.runtime.CoreException: Could not connect to
host: BLABLABLA.NET subsystem ssh.files
This is confusing, because files where already accessed on the remote
machine without any problems.
Any ideas what might be going wrong?
Martin
!ENTRY org.eclipse.core.jobs 4 2 2010-12-06 12:36:56.795
!MESSAGE An internal error occurred during: "Adding Location".
!STACK 0
com.tabuso.durban.parser.FileParserInput.getInputStream(File ParserInput.java:40)
com.tabuso.durban.parser.baroc.internal.BarocParser.<init>(BarocParser.java:50)
com.tabuso.durban.parser.baroc.BarocParserFactory.createPars er(BarocParserFactory.java:11)
com.tabuso.durban.model.impl.KnowledgeBaseImpl.compile(Knowl edgeBaseImpl.java:3322)
at com.tabuso.durban.model.impl.FolderImpl.compile(FolderImpl.j ava:461)
com.tabuso.durban.model.impl.KnowledgeBaseImpl.build(Knowled geBaseImpl.java:3231)
at com.tabuso.durban.model.impl.ProjectImpl.build(ProjectImpl.j ava:252)
com.tabuso.durban.ui.wizards.NewBEMLocationWizard$1.run(NewB EMLocationWizard.java:60)
!ENTRY org.eclipse.rse.ui 4 0 2010-12-06 13:00:40.157
!MESSAGE RSEG1058
!STACK 0
java.lang.Exception
org.eclipse.rse.ui.messages.SystemMessageDialog.logMessage(S ystemMessageDialog.java:449)
org.eclipse.rse.ui.messages.SystemMessageDialog.open(SystemM essageDialog.java:459)
org.eclipse.rse.internal.connectorservice.ssh.SshConnectorSe rvice$SessionLostHandler.run(SshConnectorService.java:332)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.j ava:327)
at org.eclipse.jface.dialogs.MessageDialog.open(MessageDialog.j ava:357)
org.eclipse.jface.dialogs.MessageDialog.openInformation(Mess ageDialog.java:439)
org.eclipse.rse.internal.connectorservice.ssh.SshConnectorSe rvice$3.run(SshConnectorService.java:542)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:179)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4312)
org.eclipse.rse.internal.connectorservice.ssh.SshConnectorSe rvice$MyUserInfo.showMessage(SshConnectorService.java:540)
at com.jcraft.jsch.UserAuthNone.start(UserAuthNone.java:104)
at com.jcraft.jsch.Session.connect(Session.java:344)
org.eclipse.rse.internal.connectorservice.ssh.SshConnectorSe rvice.internalConnect(SshConnectorService.java:189)
org.eclipse.rse.core.subsystems.AbstractConnectorService.con nect(AbstractConnectorService.java:415)
at org.eclipse.rse.core.subsystems.SubSystem.connect(SubSystem. java:2527)
org.eclipse.rse.internal.efs.RSEFileStoreImpl.getConnectedFi leSubSystem(RSEFileStoreImpl.java:253)
org.eclipse.rse.internal.efs.RSEFileStoreImpl.getRemoteFileO bject(RSEFileStoreImpl.java:318)
org.eclipse.rse.internal.efs.RSEFileStoreImpl.getRemoteFileO bject(RSEFileStoreImpl.java:305)
org.eclipse.rse.internal.efs.RSEFileStoreImpl.fetchInfo(RSEF ileStoreImpl.java:496)
org.eclipse.rse.internal.efs.RSEFileStore.fetchInfo(RSEFileS tore.java:275)
org.eclipse.rse.internal.efs.RSEFileStore.fetchInfo(RSEFileS tore.java:257)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.fastIsSynchronized(FileSystemResourceManager.java:349)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.isSynchronized(FileSystemResourceManager.java:584)
org.eclipse.core.internal.resources.Resource.isSynchronized( Resource.java:1371)
org.eclipse.core.internal.resources.File.checkSynchronized(F ile.java:102)
org.eclipse.core.internal.resources.File.getContentDescripti on(File.java:268)
at org.eclipse.ui.ide.IDE.getContentType(IDE.java:1332)
at org.eclipse.ui.ide.IDE.getDefaultEditor(IDE.java:1277)
at org.eclipse.ui.ide.IDE.getEditorDescriptor(IDE.java:825)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:649)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:1105)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:1046)
com.tabuso.durban.ui.views.WorkspaceView$DoubleClickAction.r un(WorkspaceView.java:209)
com.tabuso.durban.ui.views.WorkspaceView$2.doubleClick(Works paceView.java:162)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:821)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:819)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1195)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:238)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:235)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:296)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at com.tabuso.durban.intro.Application.start(Application.java:2 0)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
!ENTRY org.eclipse.jface 4 2 2010-12-06 13:00:44.845
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.RuntimeException: org.eclipse.core.runtime.CoreException:
Could not connect to host: BALBLABKLA.NET subsystem ssh.files
org.eclipse.rse.internal.efs.RSEFileStore.fetchInfo(RSEFileS tore.java:266)
host: SBE39560-V3.CORPROOT.NET subsystem ssh.files
org.eclipse.rse.internal.efs.RSEFileStoreImpl.getConnectedFi leSubSystem(RSEFileStoreImpl.java:256)
... 49 more
Caused by: java.lang.NullPointerException
at com.jcraft.jsch.Session.read(Session.java:809)
at com.jcraft.jsch.UserAuthNone.start(UserAuthNone.java:85)
... 58 more
!ENTRY org.eclipse.ui 4 4 2010-12-06 13:01:05.033
!MESSAGE Reference item find.ext not found for action null
FUDForum. Page generated in 0.01583 seconds
