Home » Eclipse Projects » BIRT » Nested table dataset cache
| Nested table dataset cache [message #644949] |
Tue, 14 December 2010 17:48  |
Pinny Markowitz Messages: 28 Registered: July 2009 |
Junior Member |
Is there any way to have a nested table filter based on a secondary
dataset - without having to query the database one time for each row in
the parent table?
I am trying to use a filter on the nested table instead of a dataset
parameter:
row['customer_id'] == row._outer['customer_id']
Even though the dataset query for the nested table doesn't change, the
query is still going to the database for each row. Can this data be
cached and reused somehow?
| Re: Nested table dataset cache [message #645175 is a reply to message #645145] |
Wed, 15 December 2010 14:14   |
Junior Member |
I was able to recreate the problem with a simple query. If the outer
table (using same dataset as inner) returns 0 rows using the query, it
will run over and over for each row in the middle table. This is
probably happening because the cache appears to be empty. I was able to
fix it in my case by adding a dummy row that always returns and will be
filtered out. Is this considered a bug?
Thanks for you help!
On 12/15/2010 12:03 PM, Pinny Markowitz wrote:
> I recreated the scenario you provided and it worked as you said. Adding
> filters or nesting within group rows worked as well. For some reason I'm
> not seeing this behavior in my own report, which is significantly more
> complex. I'll do some more research to see if I can determine where it
> is coming from.
> Thanks!
> On 12/15/2010 11:20 AM, Jason Weathersby wrote:
>> Pinny,
>> The last report I posted did not call the query every time. The outer
>> most table was bound to the same dataset as the innermost table. The
>> only difference was that is was not filtered.
>> Jason
>> On 12/15/2010 10:39 AM, Pinny Markowitz wrote:
>>> Jason
>>> Thanks for responding. Yes, I am using a separate dataset for the nested
>>> table, and using the solution you proposed I am still seeing the
>>> database being queried for each row in the parent table.
>>> A join on the datasets isn't practical since each set holds quite a bit
>>> of detailed data that the other does not. I was actually nesting the
>>> second dataset within a group footer of the parent table because of
>>> this.
>>> Do you know of any other approach that might work? Also, is there a
>>> reason that BIRT doesn't allow filtering on bound report items? Thanks!
>>> On 12/14/2010 7:44 PM, Jason Weathersby wrote:
>>>> One method I tried was to take the dataset used in the inner query and
>>>> bind it to a table and delete everything in the table but the footer
>>>> row
| Re: Nested table dataset cache [message #645176 is a reply to message #645175] |
Wed, 15 December 2010 14:18   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Not sure if its a bug, but log it anyways and we may be able to pick it
up as an enhancement.
Jason
>> is coming from.
>> Thanks!
>>> Pinny,
>>> Jason
>>>> Jason
>>>> nested
>>>> this.
>>>>> row
Jason Weathersby
BIRT Exchange
| Re: Nested table dataset cache [message #645185 is a reply to message #645176] |
Wed, 15 December 2010 14:54   |
Junior Member |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=332678
Thanks again!
> Jason
>>> is coming from.
>>> Thanks!
>>>> Pinny,
>>>> Jason
>>>>> Jason
>>>>> nested
>>>>> bit
>>>>> this.
>>>>> Thanks!
>>>>>> and
>>>>>> row
| Re: Nested table dataset cache [message #645196 is a reply to message #645185] |
Wed, 15 December 2010 16:24  |
Thanks for logging
> Thanks again!
>> Jason
>>>> I'm
>>>> is coming from.
>>>> Thanks!
>>>>> Pinny,
>>>>> Jason
>>>>>> Jason
>>>>>> nested
>>>>>> bit
>>>>>> this.
>>>>>> Thanks!
>>>>>>> and
>>>>>>> row
Jason Weathersby
BIRT Exchange
Current Time: Fri May 24 11:13:48 EDT 2013
Powered by FUDForum. Page generated in 0.48515 seconds
