| Riena Security - Session is null at some calls [message #643497] |
Tue, 07 December 2010 01:54  |
Originally posted by: matthiasrodler.gmx.net
I'm using Riena Security and I'm currently facing the problem, that at
some calls I get a null value from the SessionHolder within the
SecurityCallHook.
The problem will occur at every service call within a
org.eclipse.core.runtime.jobs.Job class (in the run method) but I'm not
sure if this is the reason (but it seems so).
At any further calls - outside a job - the session is set again.
Matthias
| Re: Riena Security - Session is null at some calls [message #644534 is a reply to message #644102] |
Mon, 13 December 2010 01:36   |
The reason for a null pointer is the usage of the help system from
eclipse and with this your way how you decide between client and server
mode.
The help system needs several packages which start with
"org.eclipse.equinox.http" for which you are looking for in the
ContainerModel class. This leads to the usage of
SimpleThreadedSessionHolder which will create a new SessionHolder if it
is called within an eclipse job.
I just have missed your "SERVER Mode" message and was not aware about
the impact the mode decision has on the application.
Maybe a "server" bundle could be used instead of looking at the bundle
names.
Matthias
Am 09.12.2010 14:33, schrieb Christian Campo:
> Hi Matthias,
> the session in the SessionHolder is a singleton on the client. So no
> matter what thread you are in, it should always be available once you
> have logged in successfully.
> Maybe it helps to set break points in SimpleSessionHolder class in
> setHolder and getHolder to see whats going on in your environment. It
> should certainly work.
> christian
> Am 07.12.10 07:54, schrieb Matthias Rodler:
>> SecurityCallHook.
>> Matthias
| Re: Riena Security - Session is null at some calls [message #644548 is a reply to message #644534] |
Mon, 13 December 2010 03:38   |
Stefan Liebig Messages: 124 Registered: July 2009 |
Hi Matthias,
That´s right. It is not a very save way for deciding whether we are on
the server or the client. But it is the fallback if the system property
"riena.container.type" is not set.
==> http://wiki.eclipse.org/Riena_System_Properties
Tschüß,
Stefan
Am 13.12.2010 07:36, schrieb Matthias Rodler:
> mode.
> names.
> Matthias
>> Hi Matthias,
>> christian
>>> Hi,
>>> SecurityCallHook.
>>> Matthias
| Re: Riena Security - Session is null at some calls [message #644580 is a reply to message #644548] |
Mon, 13 December 2010 05:52  |
Christian Campo Messages: 578 Registered: July 2009 |
I have added the use case of Security to the wiki page for the riena.container.type system property.....
christian
Am 13.12.10 09:38, schrieb Stefan Liebig:
> Hi Matthias,
> Tschüß,
> Stefan
>> mode.
>> names.
>> Matthias
>>> Hi Matthias,
>>> christian
>>>> Hi,
>>>> SecurityCallHook.
>>>> Matthias
FUDForum. Page generated in 0.02727 seconds
