Home » Language IDEs » Java Development Tools (JDT) » Why does eclipse try to compile all other open projects when I run a unit test
Why does eclipse try to compile all other open projects when I run a unit test [message #643473] Mon, 06 December 2010 19:59 Go to next message
Sam is currently offline Sam
All I want to do is to run a simple unit test. But before launching the test eclipse is trying to compile all other open projects which takes 10 times more time than just running the unit test. This is so annoying. How can I disable this feature?
[Updated on: Mon, 06 December 2010 20:00]
Report message to a moderator
Re: Why does eclipse try to compile all other open projects when I run a unit test [message #643735 is a reply to message #643473] Wed, 08 December 2010 00:21 Go to previous messageGo to next message
Satyam Kandula is currently offline Satyam Kandula
Are the other projects part of the test's launch configuration?
Re: Why does eclipse try to compile all other open projects when I run a unit test [message #644530 is a reply to message #643473] Mon, 13 December 2010 00:02 Go to previous message
No they aren't. They only share the same parent pom file as I am using maven to organize my project.
Previous Topic:Linking Working Set
Next Topic:[Eclipse Compiler] Differences IDE vs headless build
Current Time: Sat May 25 15:48:36 EDT 2013
Powered by FUDForum. Page generated in 0.01635 seconds
